Snoozy Waterheater ?s - Fiberglass RV
Old 05-19-2017, 08:09 AM   #1
Trailer: LilSnoozy 12/01/16, Tug 2012 Dodge Citadel
I remain nervous about turning on the water heater, but need to do so before it is an emergency (really really cold out).
The LilSnoozy came with the heater unplugged. I filled the onboard water tank to the brim (water shooting out the input after I removed the hose. ) I had turned on the hot water on the faucet while filling and it immediately had water running so I am guessing that the water heater is full?
Can anyone tell me if I have forgotten anything prior to plugging it in?
Heading out this afternoon for a long weekend in NC, and I will probably definitelyneed to use it in June in Canada.
That's my job. I read...and I know things
Mitzi Agnew-Giles is offline   Reply With Quote
Old 05-19-2017, 12:57 PM   #2
charlsara's Avatar
Trailer: 2014 Lil Snoozy
If you have water coming from the hot water faucet you can safely plug it in. Check the control panel and make sure the hot water switch is on.
Old 05-19-2017, 12:59 PM   #3
charlsara's Avatar
I leave mine on during camping season. It is fine to do that as long as it has water in it. It will start working when you plug the trailer to outside power.
Old 05-19-2017, 02:36 PM   #4
Joe & Cherie's Avatar
Trailer: 2013 EggCamper & 2011 Silverado Reg Cab 4x4
Ohio
Just make sure you don't have bypass valves set to bypass the water heater thus leaving it empty. You should get quite a bit of air out faucet when filling water heater
2013 EggCamper #120
Joe's EggCamper Journal
Joe & Cherie is offline   Reply With Quote
Old 05-19-2017, 04:38 PM   #5
charlsara's Avatar
There are no bypass valves on the LIL Snoozy water heater
Old 05-19-2017, 05:11 PM   #6
So, when you go to winterize the trailer, you have to put six gallons of RV antifreeze in the water heater?
Old 05-19-2017, 10:16 PM   #7
charlsara's Avatar
Can't speak for the new ones but my 2014 has a 4 gallon heater that has no drain. You can either take it out and pour the water out or use enough antifreeze to fill it and the pipes. I use antifreeze.
Old 05-19-2017, 10:19 PM   #8
No anode? No drain?
Old 05-21-2017, 07:31 PM   #9
charlsara's Avatar
Yes it does have an anode. According to the manual you pull the heating element to access the anode.
Winterizing and Waterheater Bypass Mod papa-t Modifications, Alterations and Updates 7 08-26-2014 05:09 PM
Lil Snoozy vs Scamp discussion (split from Classifieds) melissab General Chat 98 01-20-2013 12:03 PM
New Camper - Lil Snoozy Old Man Snoozy General Chat 7 08-08-2011 07:12 PM
Back from Lil Snoozy with Eye Candy!! melissab General Chat 222 04-22-2011 05:54 PM
» Virginia Campgrounds
