Solar - Fiberglass RV
Old 05-09-2016, 04:27 PM   #1
Trailer: 2015 Escape
Solar
Have ruled out getting a generator due to cost. $1100 plus whatever a propane conversion would cost. I don't think I'd use it enough to justify the cost. I wonder about solar sufficient to charge my battery. No idea of size needed or cost. Anything you can tell me will be appreciated. Thanks
Old 05-09-2016, 04:34 PM   #2
Myron Leski's Avatar
Trailer: 19' Escape
NM
Do a search and you'll find solar is a subject covered to utter exhaustion on this form.
Myron Leski is offline   Reply With Quote
Old 05-09-2016, 05:02 PM   #3
And not only on this forum, but all over the net. The advice you get on the forum is likely to be very basic and incomplete due to the nature of the medium.
So here is my first suggested read:
https://handybobsolar.wordpress.com/...ging-puzzle-2/
And be sure to check out the other links at the top of the page.
Old 05-09-2016, 08:38 PM   #4
Mike Magee's Avatar
Trailer: Li'l Hauley
If you are not running a DC fridge or using the furnace a lot, a 75W-100W panel probably would keep your battery topped up. I had good results with my 75W panel and Morningstar (SG-4, I think?) solar controller from Solarblvd.com. It cost me about $150 for everything. I kept it portable and plugged it into the trailer cord that otherwise goes to the vehicle (7 pin plug). But if you mount yours permanently, it can provide charge even while you're driving.
If you have a DC-only fridge, or if you typically run the furnace all night, you may need 200W or maybe more.
How to prepare Tofu
Step 2: grill some meat
Old 05-09-2016, 08:50 PM   #5
With out really knowing your camping style or durations it's pretty hard to give meaningful advice.
If you're a weekend camper the chances are you wont need any recharging while camping at all or if only stay in one place for two days you still won't need solar or generator. Your tow vehicle should take care of it.
The best way to extend your battery power is reduce you battery needs. Change lights to LED is easiest and simplest way to increase battery charge life.
I've been doing this for over 10 years. The first couple of years camping was week-end and a week or two in the summer. Never had to worry about recharging. After retirement we camp for about 3 months at a time, last winter was 40 days in one spot, then I needed the solar.
Old 05-10-2016, 05:34 PM   #6
Mike Magee's Avatar
rgrugg camps for months at a time, like you, Byron.
How to prepare Tofu
solar
ENERWATT SOLAR EWC-30 Solar Controller Robert50 Electrical | Charging, Systems, Solar and Generators 7 09-14-2014 04:00 PM
Crank'n'go solar/crank am/fm radio Legacy Posts General Chat 12 09-03-2006 11:12 AM
Solar charger questions Steve Rosenberg Care and Feeding of Molded Fiberglass Trailers 17 12-01-2005 01:00 AM
Solar System Advice Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 05-13-2003 10:03 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
