Solar Panel Trickle Charger? - Fiberglass RV
Old 02-19-2010, 02:50 PM   #1
Trailer: Bigfoot 21 ft Rear Bed
I'm considering purchasing a small solar panel to maintain the charge on our trailer battery while being stored. House current is a little too far away to be convenient. What size panel is recommended for this purpose assuming that the trailer will sit idle for at least a month between trips? Any suggestions on brands? Seems to me that the efficiency of the panel is not critical for this application and the cheaper panels should work equally as well. Are there any precautions that should be taken to make sure the battery isn't damaged while it is hooked up to the panel?
Steve Dunkel is offline   Reply With Quote
Old 02-19-2010, 03:40 PM   #2
Harry Young's Avatar
Post
I use the below to maintain the battery, two to trickle charge it.
They are small enough to put anywhere, I suggest one on the rising sun and another on the setting sun.
Happy Camping, Safe trails.
Harry
Harbor Freight panel
Old 02-19-2010, 03:58 PM   #3
Thanks Harry! Looks like I was on the right track. I was considering this 5W panel ....
Costco panels
Old 02-19-2010, 06:11 PM   #4
Adrian W's Avatar
Trailer: Lance 1985~'Casita de Campo' ~23' 4"~Dinette Slide Previously: Scamp 16 ft Side Dinette, Front Bath
New Mexico
Arrow
I have thinking about the same thing.
I use one to boost the live of the battery charge while camping, and have used in while stored one year.
I would think one of these would be good to keep them going longer while camping and maybe while stored as well. I have a smaller one, much like this but is a folding one which can be seen in the photo below. Just above the front window.
DesertHawk- Las Cruces, NM USA
2015 Lance 1985 ~ Casita de Campo ~23' 4"
~Previously ~ 2005 16' Scamp
2009 White Ford F-150 Reg. Cab Longbed ARE Topper
Adrian W is offline   Reply With Quote
Old 02-19-2010, 08:04 PM   #5
Steve look at this one, it folds up and stows away...
Harry
http://www.northerntool.com/webapp/wcs/sto...80032_200380032
Costco panels
Old 02-19-2010, 08:43 PM   #6
Harry
Interesting but I think it's a little redundant with the battery pack.
Old 02-19-2010, 09:13 PM   #7
Post
I am sorry Steve,
I am reading to fast and clicking my bookmarks in the wrong order...
http://www.northerntool.com/webapp/wcs/sto...28565_200328565
Old 02-19-2010, 10:15 PM   #8
I am sorry Steve,
Good one Harry! It even has a charge controller and automatic desulfator. Apparently there's also a 5W version for a little less money. Decisions, decisions ....
Old 02-20-2010, 06:20 AM   #9
Roy in TO's Avatar
I got a 5W solar panel similar in size to the one Steve was looking at from James Kent this summer. I left it lying on the bed under the window facing south for the winter. When I get the trailer out of storage this spring I will be able to download the charge data from my solar controller and post the results.
I recall reading here recenlty that some of the older fridges will draw a small amount of current even when the fridge is off. I don't remember if I pulled the fuse on the fridge or not before storage.
Old 02-20-2010, 09:23 AM   #10
I understand a charge controller isn't necessary with panels less than 15W but does it provide any benefits for the smaller panels? And what about the desulfator?
Old 02-20-2010, 09:51 AM   #11
David and Nancy's Avatar
Trailer: Bigfoot 25 ft (25B25RQ)
Steve - My 21RB Bigfoot has what I believe to be a factory installed 15W solar panel. It does not have a charge controller. My trailer also has a battery disconnect switch which I always use when the trailer is parked to eliminate discharge from all the "phantom" power bleeders. Since the panel is wired directly to the battery, it still puts in a trickle charge even when the disconnect switch is the power-off position. However the 15 watt panel does not always keep up if the battery has even a minor draw on it. My battery is a group 27. I'm thinking that a 5 watt panel may not be enough for you since my 15 watt panel barely gets the job done.
David and Nancy is online now   Reply With Quote
Old 02-20-2010, 10:38 AM   #12
Thanks for the input. We obviously have a similar setup except for the factory installed solar panel. A roof mounted unit wouldn't work for me because the trailer is covered when not in use. I plan to place the panel in front of the trailer, possibly mounted on the tongue, where it has a southern exposure. Anyway, I checked current flow when the disconnect switch was placed in the store mode and couldn't detect any power bleeds. So I don't expect to loose much power while it's in storage except for normal battery drain while sitting idle. However, when we return from a trip the battery is partially depleted. I was hoping to top off the battery with the solar panel during that time. That's the plan anyway. On paper the 5W panel is more than adequate considering the amount of time it has to do its magic. Or is there something I'm missing?
Old 02-20-2010, 05:11 PM   #13
peterh's Avatar
Once you understand what solar charge controllers do you'll have a better understanding of why you may or may not want one with a 15 watt panel.
A solar charge controller does several things that help keep your battery charged and in good health.
The first, and most basic, function of a solar charge controller is to prevent your hard-won battery charge from bleeding out backward through your solar panels after the sun goes down. Most solar panels come with "blocking diodes" (also called "blocking resistors") that do the same thing, but, because "most" is no "all," quality charge controllers have blocking diodes as well.
The next, basic function is a charge controller works like a simple on/off switch that connects the solar panel to the battery when the battery voltage falls below a pre-set voltage, then disconnects it when the circuit voltage rises back up to 14.2 or 14.5 volts. In other words, it disconnects the solar panels when the battery is near full charge and reconnects them once the battery has lost some of its charge.
Cutting off the charging process at 14.2 to 14.5 volts is important when you're pushing a lot of watts into the battery because once the battery approaches its fully charged state much of the extra energy going into the battery turns into heat. That heat, in turn, boils off the battery electrolyte (battery water) and causes other chemical changes that reduces the battery's lifetime and ability to hold a charge.
That said, letting a fully-charged battery sit isn't a good idea, either. Batteries store and concentrate energy through chemistry, and chemical energy doesn't like to sit still. Leave a fully charged battery on a shelf and it will gradually loose charge and start to "sulphate," or damage itself. You can combat this loss of charge and sulfation process by using a "trickle-charger" that sends just a trickle -- ideally 1-2% or so of the battery's Amp-Hour rating -- of electricity into the battery. THat trickle of energy pushes the chemicals inside the battery to stay in their full-charged configuration rather than going downhill like nature and physics expects it to.
And that's the answer to your question: Can you connect a 15-watt panel to your battery without a charge controller? Yes! For an 80 amp-hour an input of 8-16 watts is ideal for maintaining the battery, as long as it has a blocking resistor . . . or one 15w panel's worth. Before you go out and buy a bare panel, what good can having a charge controller -- particularly a BatteryMinder controller -- do?
By now you're guessing that better-quality solar charge controllers are also trickle-chargers that keep the battery fully charged and prevent sulphation when you're not using the battery. If you have more than 15 watts of solar this is the first, most valuable feature of an advanced solar charge controller.
Another thing advanced solar charge controllers do is squeeze more battery charge into your battery. Remember I said that basic solar charge controllers disconnect the solar panels when the battery reaches "near full charge" at 14.2 - 14.5 volts to stop the battery electrolyte from boiling? When batteries run down they tend to accept a fresh charge very easily, but as the battery starts to fill up and reach capacity it resists accepting more charge, and if you push more power at it than it can handle the excess electricity once again dissipates as battery-damaging heat.
Advanced controllers recognize this problem, but instead of just shutting of the juice at 14.2 - 14.5 volts they reduce the amount of electricity they send to the battery as it reaches capacity. It's a half-way point between fully engaging the panels and trickle-charging that allows the battery to reach its fully charged state without overheating.
There are two ways to figure out how much power to send the battery as it gets full. One is to monitor the charging circuit and make an educated guess at when the battery is starting to get full based on voltage. The other is to mount a sensor on the battery and use that monitor battery temperature and slow the charge rate down when the battery gets too warm. Both methods will get your battery fully charged when you have ample solar panel capacity and sunlight, and neither will get you fully charged if you don't. The difference between one and the other is what happens when you have just enough sunlight to top your batteries off.
The temperature method controllers will squeeze that last little bit of charge into you battery on days that there's just exactly enough sunlight to top the battery off. The voltage-method chargers tend to work more conservatively to protect your battery, and will leave the battery a few percent (say two or three percent) below its max charge when there's just enough sunlight to do the job.
My take on this is that I'm more worried about days when I don' get enough sunlight to charge my battery in the first place than I am about getting my battery to the absolute top of its charge curve, and since temperature-sensitive chargers cost well over $100 where voltage-sensitive chargers cost $40-$75, I'd rather spend that extra money on a few more watts of solar panels than the more complicated system.
Now, what about BatteryMinder controllers? BatteryMinder controllers are a variation of the voltage-sensitive charger concept that have a special, and very cool, trickle charger feature. When a BatteryMinder charger is working in trickle-mode it emits higher-voltage pulses at the precise frequency that makes sulfate crystals vibrate and fall apart. What that means is a BatteryMinder controller will keep your batteries from sulphating, so they'll last longer and hold more charge.
Spending money on a BateryMinder solar charger will do you no good if you plug your trailer in and keep the battery charged when you store it. (For that I'd suggest a traditional plug-in BatteryMinder battery charger.) It'll only do the job right if you leave your trailer out in the sun when you store it and don't a second battery charger or converter in.
Other good choices (IMHO) in Solar Controllers are the Sunsei and Morningstar Sunsaver products.
The Sunsei CC-10000 is a 10-amp (120 watt) controller that has the three-level charging capability of an advanced controller. It's similar in capability to the BatteryMinder controller, but doesn't have the desulfation feature. They cost $40-60 and work really well for those with smaller solar systems who boondock. It's what I use with my 105-watt solar system, and I have no complaints.
The Morningstar SunSaver doesn't have desulfation, either. What it does have is an internal switch that disconnects your battery from your trailer electrics when its charging voltage reaches 11.5 volts, and is 75% discharged. This is good because after reaching 11.5 volts you can do serious and irreversible damage to your battery, but once in a while the dim lights in your trailer will suddenly go out when the furnace tries to start up and your circuit voltage drops to 11.5 volts. Then you'll find yourself in a suddenly cold, dark trailer. The SunSaver automatically re-connects when the battery charging voltage gets back to 12.6 volt, a safe point to start drawing power again.
Old 02-20-2010, 06:32 PM   #14
Thanks for the excellent response Peter. I'm a little confused about the following paragraph though.
Spending money on a BateryMinder solar charger will do you no good if you plug your trailer in and keep the battery charged when you store it. (For that I'd suggest a traditional plug-in BatteryMinder battery charger.) It's only a good deal if you leave your trailer out in the sun when you store it. (If you do store your trailer out in the sun that $110 BatteryMinder controller with a 15-watt panel is a pretty sweet deal.)
My trailer will be parked in a covered area but I planned to have the solar panel immediately outside facing south. We're in San Diego so we get plenty of sun. The battery will most likely be partially depleted just prior to storage. I was hoping to set up the solar panel, etc. and leave it hooked up until the next trailer use, about a month later. Is that the "sweet deal" scenario you mentioned? If so, I think Harry hit the sweet spot with the BatteryMinder controller and 15W panel suggestion.
Old 02-21-2010, 12:11 AM   #15
peterh's Avatar
What I was trying to say there was that having two chargers on your trailer at the same time, one standard plug-in battery charger or trailer converter, plus a BatteryMinder charger/desulfation unit won't work. If you use a BatteryMinder it has to be the only charger on the system. So, assuming you don't "plug in" when you store your trailer, the solar BatteryMinder would work just fine for you.
BatteryMinder sells two Solar Controller/Solar Panel combos. Both have the same 15 Amp (180 watt) BatteryMinder charge controller and either a 5 or 15w amorphous (low efficiency) solar panel. They cost $110 and $150, respectively.
Since the Battery Minder itself runs about $100, that means for $10 you'd get a 5-watt panel (about $2/watt), which is a pretty good price; the 15-watt panel adds $50 (about $3.30/watt), which is about average pricing for a panel on a per-watt basis these days.
If I were installing my solar system from scratch today I might buy the package with the cute little 5-watt panel and install it on the frame extension where my 5th-wheel's hitch is. That makes sense for me because, when I park the trailer, the hitch faces south and outward from under the roof it's parked under. It'd get enough sunlight to keep the battery desulfated and fully charged.
I would not get the $150 kit. My reasoning is, if I'm going to have big panels I want them to be big, cheap efficient panels, and for the same physical size as the BatteryMinder 15-watt panel I can buy a 30-watt panel that'll last longer under the sun for around $100. Better yet, buy a pair of 50-watt panels for about $175 each. A 100-watt solar system can keep my trailer lit, my water pump pumping, my furnace furnacing, and my little 12v, 10.2" AM/FM/DVD/LCD TV wasting my brains away all summer long without electric hookups.
Old 02-21-2010, 08:51 AM   #16
Roy in TO's Avatar
In my case the charge controller lets me track 365 days of activity. The amount of sunlight and the amount both in and out of the battery including voltages.
Old 02-21-2010, 11:21 AM   #17
Thanks once again Peter! The 5W panel seems to be the perfect match for me. I like the idea of the smaller size and it will not be a major loss if it somehow finds legs.
Old 02-21-2010, 01:42 PM   #18
peterh's Avatar
Just a note. I went back and did some major editing on my earlier post about solar charge controllers. I didn't change what I was saying, just tried to make it more readable.
solar, solar panel, solar power
Solar Trickle Charger & Dead Battery V'sGlassSleeper Problem Solving | Owners Helping Owners 11 03-19-2010 07:29 PM
Solar Charger and Panels Frederick L. Simson Modifications, Alterations and Updates 109 08-11-2008 10:41 PM
trickle charger Ericpa3 Problem Solving | Owners Helping Owners 8 10-30-2007 05:57 AM
Solar Powered Battery Charger Rich S Electrical | Charging, Systems, Solar and Generators 6 10-17-2006 09:19 AM
Solar charger questions Steve Rosenberg Care and Feeding of Molded Fiberglass Trailers 17 12-01-2005 02:00 AM
