spare tire - Fiberglass RV
Old 03-07-2010, 10:56 AM   #1
Vicki A.'s Avatar
Trailer: 1984 Perris Pacer ('Tillie')
Where do you have your spare tire?
If it is mounted to the back of you egg - how is it mounted?
If it not on the back, what do you do with it?
I'm asking these questions because:
1. Mine was mounted on the back - bolts leaked, wood rot - yuk yuk yuk
2. Wanting ideas on how to do this better.
Vicki
Vicki A. is offline   Reply With Quote
Old 03-07-2010, 11:48 AM   #2
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
This is what I'm planning to do:
Old 03-07-2010, 12:28 PM   #3
I carry mine in the back of the truck. Easy to remember to check the tire pressure, when I store it in the garage... because I'm touching the tire, I remember!
Old 03-07-2010, 06:41 PM   #4
Talking
  1. Where do you have your spare tire?
  2. If it not on the back, what do you do with it?
My Fiber Stream has 12" wheels; total diameter of wheel and tire is about 25".
When I bought it, a previous owner had made a cargo hatch under the starboard (right, or curbside) bunk; 9" tall by 27" wide.
This was a perfect size to put the spare tire inside, under the bunk.
My tongue weight was only 7% though. In order to increase it to 10% and open up space in that cargo compartment,
(I like to call it "the basement") I moved the spare to underneath the tongue, using a simple spare tire bracket.
This works well because of my "flipped" leaf spring suspension, gaining ground clearance.
Old 03-07-2010, 06:43 PM   #5
Mike Taylor's Avatar
Trailer: Hunter Compact II
I carry mine in the camper shell of my truck. I bolted a piece of plywood with a carpet mat on top of tire to make a step to get into the trailer that helps my dog climb in trailer.
Mike Taylor is offline   Reply With Quote
Old 03-07-2010, 08:33 PM   #6
james kent's Avatar
Trailer: Boler 1984
I made a bracket from some 1X1 tubing a bit of pipe and some bolts and washers. When mounted on the rear bumper with the spare in place it's very stable.
Old 03-08-2010, 06:28 AM   #7
I LIKE this idea! And to think I had a step welded to the frame (and I have to be careful to make sure it doesn't get scrapped off) and the solution to a step was in the back of my truck
Great double-duty solution
Old 03-08-2010, 06:43 AM   #8
Alf S.'s Avatar
Hi: All...I'm afraid to say it but I carry mine with me all the time. It's mounted around my waist .
Old 03-08-2010, 10:31 AM   #9
Robin G's Avatar
Trailer: 2007 Casita
On the Casita it's mounted on the back. But every boat we had has always had it mounted like Fredericks is mounted. No problems!
Old 03-09-2010, 01:00 AM   #10
Perry J's Avatar
Alf, I have the same problem.
Until I was about 39, many years ago, I had a 34" waist. When I turned 40 my stomach muscles took premature early retirement and it's been a losing battle ever since. Actually I've lost the battle.
John
Spare Tire Holder Bonnie Towing, Hitching, Axles and Running Gear 18 08-30-2007 03:04 PM
Spare tire Lainey Problem Solving | Owners Helping Owners 1 08-12-2007 06:48 AM
Spare Tire Rim Nancy and Don Ostaff Problem Solving | Owners Helping Owners 5 08-08-2007 06:52 PM
under spare tire christineb Problem Solving | Owners Helping Owners 10 01-25-2007 06:58 AM
Spare tire cover General Chat 0 01-01-1970 12:00 AM
