Stainless Steel Fasteners - Fiberglass RV
Old 06-13-2009, 08:50 PM   #1
Trailer: Bigfoot 21 ft Rear Bed
Isn't it customary to use stainless steel fasteners on the outside of the trailer? I have a mixed bag of stainless and non-stainless fasteners on my Bigfoot 21RB. Some of the non-stainless ones are beginning to rust and leave an ugly stain on the fiberglass. I've already changed some of them.
Steve Dunkel is offline   Reply With Quote
Old 06-14-2009, 11:12 AM   #2
peterh's Avatar
Scamp uses non-rusting aluminum blind (or "Pop") rivets to attach most things through the shell. Rivets have some advantages . . . they never come un-screwed. Wood cabinets are attached with galvanized screws (not stainless).
When I replace rivets or screw something into the hull I use stainless steel fasteners for the external part of the job and nickle-zinc plated fasteners on the inside.
Old 06-14-2009, 06:28 PM   #3
Bruce H's Avatar
Trailer: Bigfoot 25 ft RQ
Steve,
Bigfoot was pretty bad about using zink coated screws on the exterior of their trailers. They do rust if you give them enough time. I replaced all the exterior screws in my Bigfoot with stainless screws. I purchased my stainless screws on line from this outfit:
http://www.manasquanfasteners.com/de...screws_panhead
I ordered several different sizes and lengths because there are several different sizes used on the trailer. Check all your sizes before you order. They have them in the square bit drive. As I remember they did combine shipping.
I replaced the old screws one at a time. I would remove one then dip the threads of a new stainless replacement in RV caulking and install it before removing the next old one. You do not want to take all the old screws out at one time because the part they are fastening might fall off. I used a hand screw driver to be sure I did not over tighten and strip out the fiberglass. It was an easy job and did not take very long.
Regards,
Bruce H
Stainless Steel Tissue Box Frederick L. Simson Modifications, Alterations and Updates 2 06-26-2009 10:57 PM
ultra mini stainless steel stove bonnie w General Chat 6 12-17-2008 08:20 PM
Drilling stainless steel sheet metal? Tom Myers Problem Solving | Owners Helping Owners 8 11-02-2007 08:13 AM
Stainless Steel and Aluminum d_wildemann Problem Solving | Owners Helping Owners 5 08-16-2006 01:33 PM
Stainless steel stove Maggie O. Care and Feeding of Molded Fiberglass Trailers 24 11-19-2005 08:43 PM
