Sticky??? - Fiberglass RV
Old 01-29-2008, 12:34 PM   #1
Trailer: 1989 16 ft Casita Freedom Deluxe
Ok, why are regular trailers called sticky? Or are they?
SharonNDean is offline   Reply With Quote
Old 01-29-2008, 12:45 PM   #2
Because they typically have a wood (stick) body framework with metal or fiberglass panels (and silicone) screwed (or stapled) to the wood. When they start leaking (and they will) think "dry rot." Some "sticky" RVs have an aluminum framework, but the panels will still leak.
Old 01-29-2008, 12:46 PM   #3
Orlen Wolf's Avatar
'cause they are built of sticks of wood (usually a pretty low grade wood at that)
Orlen Wolf is offline   Reply With Quote
Old 01-29-2008, 12:48 PM   #4
Because they're made of "sticks".
The major construction is framed something like your house. The framing material is usually wood around 2x2" is size. The inner and outer covering are then attached to the wooden frame.
Old 01-29-2008, 12:57 PM   #5
Well, thank you. I learned a lot. Didn't know they were made of wood. I thought they were made of plastic siding over metal.
Old 01-29-2008, 02:35 PM   #6
james kent's Avatar
Trailer: Boler 1984
First little Piggy built a house of straw and the big bad Wolf blew it down.
Second little piggy built his house of sticks and covered it with thin metal panels. The big bad Wolf blew it down.
The Third Little Piggy built his house from FIBERGLASS and it has lasted to this day.
Old 01-29-2008, 04:21 PM   #7
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
NOTE: This topic has been split.
"How to fix cracks..." has been moved to Owners helping Owners.
Old 01-29-2008, 05:09 PM   #8
Pete Dumbleton's Avatar
Some of them do have metal frames instead of wooden ones. Airstream, for example, has aluminum skin on aluminum framework.
I had a Jayco 16' with fiberglass panels on wooden frame and a slow leak from water heater led to dry rot and Carpenter Ants.
Old 05-12-2017, 07:09 PM   #9
Trailer: Searching
Thanks for responses. I was hoping s sticky like a Jayco wouldn't have issues. I guess the bottom line is the FG is definitely supeior all the way around.
Thanaks again.
Dwainkitchens is offline   Reply With Quote
Downsizing from a Sticky Karalyn General Chat 18 10-27-2009 09:28 AM
sticky no more? Coach George Jessup Forum Admin, News & Announcements 6 12-30-2008 11:38 PM
sticky mod drew l. Modifications, Alterations and Updates 1 11-29-2005 08:18 AM
