Subaru's towing specifications make absolutely no sense!! - Fiberglass RV
Old 11-21-2016, 04:57 AM   #1
Connecticut
The 2013 and earlier Foresters have a towing capacity of 2,400 lbs. with the 2.5 L 4 cylinder engine. The 2014 and later model Foresters have a towing capacity of 1,500 lbs.with the same engine. The CVT is not the culprit as the ratings for the standard transmissions are the same. The 2014 Outback with the same 4 cylinder 2.5L engine and torque specifications and weighing two to three hundred pounds more has a towing capacity of 2,700 lbs. The six cylinder is rated for 3,000 lbs., only 300 lbs. more than the 4 cylinder. I called my Subaru dealer and spoke with the service manager who had no logical explanation. I don't get it! Can anyone explain it?? Tony
Tony M is offline   Reply With Quote
Old 11-21-2016, 05:54 AM   #2
South Carolina
I can't explain it, but I can add to the confusion. Check out the European specs for the same vehicles. Apparently pounds are lighter on the other side of the pond since you can tow much more there with the same model. At least that was the case back when I was trying to figure out what the Forester I had at the time would handle.
p@
patrick crawford is offline   Reply With Quote
Old 11-21-2016, 06:39 AM   #3
To further muddy the waters, the Outback is only rated for 200 pounds tongue weight. That effectively limits you to a 2000# travel trailer if you follow the 10% minimum tongue weight recommendation.
Based on real world postings I've read, 2000# is about right. That makes a 4 cylinder Outback good for a 13' trailer, no more, and expect to take it easy on long grades. The 6 cylinder has a bit more grunt for hill climbing but the same chassis limitations re tongue weight. I haven't read any posts about real world towing with the new Forester.
As to Euro towing, that's a hot button topic. I will observe that vehicles, trailers, towing laws and practices, and other factors are different. If something were to go south, issues of liability and/or warranty coverage will not be decided in Europe.
Old 11-21-2016, 09:56 AM   #4
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Subaru's 2012 manual says 8-12% (or something like that) for tongue weight. I don't think I'd like the 8% but that may depend on the trailer and it's characteristics re sway. I usually run at 10% or greater so yes, that limits the overall weight, plus you have to have trailer brakes if over 1000 lbs. And at least one person has had problems with the hill holder on the manual (which imho is better for towing- manual, not hill holder)- starting on a hill from a stop is a potential problem. But my manual 2012 Forester tows fine within those limits.
Old 11-21-2016, 10:06 AM   #5
Trailer: 1992 Casita Spirit Deluxe
Virginia
Usually you can narrow the USA tow rating of a vehicle down to one of four things (in my defined order of probability):
1. Lawyers (specifically, manufacturer liability when you do something stupid and your heirs and assigns sue). If marketability of some classes of vehicles didn't require tow ratings, all vehicles would have zeros for towing capacity because the legal department likes it that way.
2. Sales/Marketing (Pickup trucks and sport utes are much more profitable than sedans and wagons for manufacturers that make both...you figure it out
3. Nobody bothered to test this vehicle to limits according to the SAE standard test, so an arbitrarily low number was chosen (see 1 and 2, above)
4. The vehicle has some engineering limitation that makes it unsuitable to tow more than the rated weights.
As Subaru doesn't make big pickup trucks, I'm guessing that #2 is not a factor. If there was no platform or suspension change between the years, than #4 is not a factor. That leaves 1 and 3.
To muddy the legal waters, you could import a European spec Sube with the appropriate option packages to get the EU tow rating. It would be quite a hassle, though.
steelypip is offline   Reply With Quote
Old 11-21-2016, 10:06 AM   #6
Trailer: interested in HC1.
Are the brakes different on any of these vehicles? Or the suspension? That's about all I can think of that might explain this madness.
TomandCallie is offline   Reply With Quote
Old 11-21-2016, 10:31 AM   #7
Trailer: In the market
Subaru towing
You may want to search towing with a Subaru, I recall reading threads where towing was really hard on a Subaru causing premature wear and a lot of stress to the vehicle. I just rented a 4 cylinder Outback for a week in Montana it got great gas mileage but struggled up mountain grades with 3 passengers.
Ronlehman is offline   Reply With Quote
Old 11-21-2016, 10:33 AM   #8
Trailer: Trillium Outback 2004
Subaru's Towing Specifications Make Absolutely No Sense
Hoping this discussion continues as I am looking at either the Outback or Forester for my next vehicle in the near future.
I have a 4 cylinder Toyota Tacoma pickup truck right now that tows just fine, albeit in 3rd gear (manual) going up any hills, but I'm not in a hurry. It's rated for 3500 lbs. and I like this margin of safety.
Please continue...... I understand the legal bit and knew about the different rating in Europe....????
Thanks for your input all you knowledgeable people. Is there a Subaru forum of some sort where someone might have some input?
BarbinBC is offline   Reply With Quote
Old 11-21-2016, 10:59 AM   #9
Trailer: Still shopping...
Kentucky
Maybe I can help (maybe not). We bought a '16 2.5i Outback, and were perplexed/surprised/saddened by the same info.
As a member of the Outback Forum, there are rather lengthy threads regarding the real world towing capacities of the 5th gen Outbacks (with either engine). There seems to be a common consensus that the limit is around 2,000 lb.
That being realistic, that limits us to small fiberglass campers in the 13 foot range.
For us, that's kinda small.....so we'll just tow with our 4Runner, which has a 7,000 lb tow rating.
The Outback has a LOT of virtues - towing ain't among them.
KYBubblehead is offline   Reply With Quote
Old 11-21-2016, 11:07 AM   #10
Thanks for the input, Bubblehead.
I have a 13 ft. - Trillium - so maybe a Sub. is still a possibility. I love all the other features of the Sub.'s outside of something I read recently about head gasket issues.
Still time to consider other options, like a Honda CRV or Toyota RAV.
Old 11-21-2016, 11:11 AM   #11
Can't explain your problem with ratings but I'd not try towing with a 4 cylinder. We had a Chev S-10 Blazer and a Chev Trailblazer with 4.2 and 4.3 engines. We wouldn't have wanted anything smaller. Weight plus braking would have been a problem. Usually they don't even put a class 3 hitch on a small SUV so that you won't put to much weight on the vehicle. The suspension won't hold the weight. Class 3 hitch is what most trailers require. Putting the equalizer hitches and all that on to be able to tow with an underrated vehicle is asking for problems plus the weight of the heavy hitches just adds more weight to the underrated vehicle.
Old 11-21-2016, 11:37 AM   #12
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
I towed a 13' Casita, no brakes, with a 2000 Forester for about 1 1/2 years and 10,000 miles.
Never had any towing issues other than feeling pushed a little going down very long grades.
When I upgraded to a 16' in 2010, I replaced the Subaru too, but it was still going strong. I did add an aftermarket tranny cooler to it.
Walt
Old 11-21-2016, 02:30 PM   #13
Connecticut
Thanks all for your input. I will pick the 13' Scamp up in Backus when it is ready with my Forester and see how it goes. It will either pull the camper adequately in which case I will keep the car or it will not pull it adequately, in which case I will trade the vehicle in for another. Tony
Old 11-21-2016, 03:12 PM   #14
JLF
Wisconsin
Would you share with me the year of your 4Runner? I own a 2000 and have only a 5000lb tow rating and don't know of any higher rating for any 4Runner built after that. I'd sure like a higher tow rating and love the 4Runner. Since mine has 281,000 miles on it a more recent and higher rated edition would be idea. Thanks.
JLF is offline   Reply With Quote
Absolutely no way to treat a customer! Tony Rubi General Chat 37 08-18-2014 04:44 AM
13 foot actual / real weight specifications Denis Ferkany Problem Solving | Owners Helping Owners 19 08-11-2012 06:52 PM
Confused about Scamp 13 interior height specifications VinceB Problem Solving | Owners Helping Owners 1 02-07-2009 04:02 PM
» Virginia Campgrounds
