Click Here to Login |
Of course VW USA is not serious about towing except with the Touareg or Tiguan, The rest of the world (ROW) tows with no problems. In Europe all towbars must be tested and approved etc. |
04-21-2015, 05:16 PM | #44 | |
The Outback, Forester, Baja, Tribeca have always had Subaru's Symmetrical all wheel drive system as does the newer Crossteck. They did offer the Impreza at one time in both all wheel or front wheel drive but I am not sure you can get a front wheel drive anymore. The BRZ if I am not mistaken is the only Subaru that is not full time all wheel drive and its a rear wheel drive.
BC Glass Eggs Fiberglass Trailers on Facebook |
04-21-2015, 05:20 PM | #45 | |
04-21-2015, 05:27 PM | #46 |
04-21-2015, 06:18 PM | #47 | |
Name: RogerDat Trailer: 2010 Scamp 16
I'm betting that no matter how good the technology is there are those that will be able to overcome it with a massive dose of being stupid. Even the simple safety chain can be defeated by those that don't hook them up. If on the other hand folks really like something the manufacturers will start including it. Think air bags and cruise control. Simple solutions can easily get you to 80% of max safety the other 20% depends on the person. Trying to get that 20% with technology just makes for expensive vehicles and repairs. Properly loaded and towed sway should NOT be an issue. Requiring one to purchase enhanced safety built in is sort of like making us all pay to have breathalyzer ignition lock outs in our cars. Bummer about the Willys Jeep getting smacked like that. The driver on the other hand earned getting scared half to death. Just glad they did not cause an accident for the other drivers on the road. |
04-21-2015, 06:51 PM | #48 |
Name: Rob Trailer: Oliver Legacy Elite II, #70
Montana
04-21-2015, 07:01 PM | #49 |
I think that my point was that airbags do not redistribute weight and that a WDH does.
I don't think Subaru's drive system is relevant to that discussion.
What happens to the hole when the cheese is gone? - Bertolt Brecht |
04-21-2015, 09:25 PM | #50 |
Not sure it isn't. They also state that WDH systems are not recommended for use on there Outbacks in the manual - believe the Foresters reads the same - not sure about other models. When I enquired of Subaru's head office as to why that was, I was told there was concern that the redistribution of weight may interfere with the handling of the vehicle due to the All Wheel Drive system they use.
04-21-2015, 09:34 PM | #51 |
At least you got an answer from Subaru. I've been trying to get Toyota to give me an answer to no avail.
04-22-2015, 06:07 AM | #52 |
Name: Paul Trailer: '04 Scamp 19D, TV:Tacoma 3.5L 4door, SB
I wish I knew the reasons Toyota has for discouraging 5th wheel towing with the Tacoma, but I have not tried to pry it out of them. I just do it, like some of the other users here.
04-22-2015, 06:12 AM | #53 |
Name: JD Trailer: Scamp 16 Modified (BIGLY)
My point on the airbags is not that they distribute weight, but rather the tests show that the use to level the car gave much the same improvement in towing stability as the WDH.
Testing showed that the airbag equipped car was approximately 1/2 way in stability between the unmodified car and the WDH. It also will correct the aiming of the headlights. As to the suspension differences in the Mexican and ROW VWs the spring might be different, but there are towing springs available for the VW wagon as well. Others experience may vary, but my Sportwagen tows quite well and is very stable when the trailer is correctly setup. Mt own thought is that a well behaved car with trailer is better than a car with poor handling when towing the same trailer. Many CUVs and trucks handle miserably compared the the JSW and continue to be pretty miserable towing as well. Connie (SHE WHO MUST BE OBEYED) and I looked to freshen up the vehicles we drive and tried almost all of them and found them lacking in power and handling compared with our 2009 JSW with 234,000 miles. We ended up buying another 2013 JSW with 30,000 miles. I have ordered the towbar and electrical wiring kit from Germany for it. One limitation as mentioned above is on slick roads stopped on a hill the car has enough power to spin the front wheels, but the stability system handles that by stopping the spinning wheel making it a non event. This is not so much a traction problem as putting too much power down for the conditions. When this happened I let the car idle and it accelerated from a stand still through 3rd gear with no problem. Not s much to argue with Carol H. but I think that VW US has a different agenda on towing that is not shared with VW ROW. One issue with the factory towbar setup is the 5 MPH bumpers which go away with that setup. ranted there is very little difference, but it has not been tested. Also the towbar does not have the factory provisions for two chains since the Euro setup is different using a breakaway system instead. Also there are no provisions for electric brake controllers and this has to be added (like many cars). However the trailer module has programming for the North American market. This module tells the caar there is a trailer attached and modifies the programming of the ESP, transmission, cooling, and engine to account for it. I am posting the setup of my new car on the TDI forum along with purchasing information if anyone is interested. |
04-22-2015, 11:48 PM | #54 | |
Trailer: Compact Jr 1972
Hit the gas to pull it out? or no?
Should I hit the gas to pull my trailer out of a sway or not? Sometimes I get swaying not from the setup's fault, but just from my stupid driving. |
04-22-2015, 11:53 PM | #55 |
With some enthusiastic driving on a gravel road, I found my tent trailer coming up alongside of my Subaru. I hit the gas and managed to pass it. And then, I gently slowed down.
04-23-2015, 09:25 AM | #56 |
Darn if you do and darn if you don't. That is the best answer.
04-23-2015, 09:32 AM | #57 | |
There really is not a real good way to stop the sway without possible creating more issues - hitting the gas to increase speed MAY pull the trailer out of a sway situation but speed is also more often than not a cause of sway in the first place so it may help to go fast or it may not. If your going down hill when you hit the gas you may be sorry you did. Putting brakes on hard on the tug is also a pretty good way to create a way bigger problem - tapping them lightly is something some folks do and seem to think it works for them .... its kind of one of those things that can either go ok or not so ok....
04-23-2015, 12:34 PM | #58 | |
1. No braking... Results in the ditch possibly upside down. No possibility of regaining control. 2. Any Braking... Results in the ditch possibly upside down. No possibility of regaining control. 3. Accelerating... A chance of regaining control. Without accelerating when there is no brakes you're not going to regain control. Even with trailer brakes braking the tug could also result is the ditch. Applying the trailer brakes alone will create the necessary tension to put the trailer back behind the tug.
Byron & Anne enjoying the everyday Saturday thing. |
04-23-2015, 12:38 PM | #59 | |
Name: Dave W Trailer: Escape 19 and Escape 15B
Dave W - 2013 Escape 19', 2013 Escape 15B and 2011 Toyota FJ Cruiser "You've got to be very careful if you don't know where you are going, because you might not get there." - Yogi Berra |
04-23-2015, 12:40 PM | #60 |
I'll relate another story that happened to me that makes me a firm believer of trailer brakes. In Los Vegas, on I-215 north bound, there's a slight hill with curve as it goes over the top. Blind, you can't see very far in front of you at that point. At that point all traffic in front of me had stopped for some reason. No choice but brake as hard as I could. I glanced in the side mirror towards the outside of the curve, there's my trailer trying pass me. Still no choice but the keep braking hard. I figured that my trailer would be gone. When stopped I looked in the center mirror and there was the trailer right where I wanted. If feel certain that without the brakes and good controller I would have lost the trailer.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Are you ready for a disaster | Tom McRae | General Chat | 36 | 04-22-2012 10:26 AM |
Earthquake Disaster Survival | Frederick L. Simson | General Chat | 6 | 08-11-2008 04:33 PM |
OREGON 2006: Disaster Avoidance for Newbies | Frederick L. Simson | Rallies, Get-togethers, Molded Meets (Archive) | 0 | 06-27-2006 04:51 PM |
Disaster strikes | Legacy Posts | General Chat | 35 | 08-21-2003 11:16 AM |
» Trailer Showcase | |
ET Al Bear |
Little Joe The Minimalist |
» Featured Campgrounds |
