The Swing-Out Screen Door is made with a
fiberglass screen and is mounted on a spring bar attached to the cabin. A catch at the end of the spring bar holds the screen shut. Velcro strips on the both sides hold the screen to the door frame. A weighted tube at the bottom of the screen holds the screen tight against the door frame.
The screen is opened and closed by lifting the side tab and the spring bar releases or engages the screen and allows the screen to swing out. The cabin door may be closed without removing the screen. Removing the screen takes about 30 seconds.
Installation takes less that 30 minutes using a power drill and screw driver.
$59, plus $7.50 shipping to U.S. and Canada.
(Was $95)
Send questions to
GraceInDesign@gmail.com[/QUOTE]
