Tarp for Shade? - Fiberglass RV
Old 03-17-2012, 01:40 PM   #1
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
Tarp for Shade?
Hello! Me and the girls are going camping with friends over Spring Break. We plan to use tarps for shade over the picnic tables and as awnings etc. What we cant figure out is if you are not allowed to tie ropes to trees, how do you support the tarps (like an awning)? We could probably park 2 vehicles the appropiate distance apart and use the minivan roof racks to create one dry/shaded areas but what about creating other dry/shady spots for the other sites? Any tips/tricks for making shade out of tarps would be much appreciated. I figure with all the prior backpackers/tent campers here I should get some great suggestions for creating shade when you cant use the trees.
Thanks!
Melissa in Florida
2016 Honda Odyssey
melissab is offline   Reply With Quote
Old 03-17-2012, 01:45 PM   #2
Gilda's Avatar
Trailer: 2011 Scamp 13'
Try this: ShelterLogic ShadeLogic Quick Clamp Canopy ShelterLogic ShadeLogic Quick Clamp Canopy 7ft. x 10ft., Green, Model# 14550 | Canopies | Northern Tool + Equipment I've not used it, but I've seen it at another campsite. Seems to be just the ticket! GPS
Old 03-17-2012, 06:26 PM   #3
melissab's Avatar
That's great for over a table but a bit pricey. What about for creating shade/dryness over a tent though? How would you support that?
Melissa in Florida
2016 Honda Odyssey
Old 03-17-2012, 07:13 PM   #4
Trailer: Casita 17 ft Spirit Deluxe 2007
Would tent poles and rope work for you?
Terry R. is offline   Reply With Quote
Old 03-17-2012, 07:15 PM   #5
melissab's Avatar
Tent Poles???? Can you buy tent poles by themselves??
Melissa in Florida
2016 Honda Odyssey
Old 03-17-2012, 09:02 PM   #6
ceilityme's Avatar
Trailer: 1973 Honey Boler...
Instead of putting wires, ropes or bungee cords through the holes or grommets, put a bunch of dirt or a biggish rock and create a pocket, then tie or attach your rope etc. around the pouch, that way your tarp wont tear.. I hope this make sense.
ceilityme is offline   Reply With Quote
Old 03-17-2012, 09:06 PM   #7
Greybeard's Avatar
Name: Richard & Carolyn
Trailer: 2000 Casita SD 17'
Gabriola Island, BC
Send a message via Skype™ to Greybeard
I have seen references to "No Tarps" on the notice boards in some parks recently. Same applies to clothes lines so unless you know it is allowed where you are planning to go, it may be a waisted effort.
Richard
Greybeard is offline   Reply With Quote
Old 03-17-2012, 09:11 PM   #8
teri85's Avatar
Trailer: Trails West Campster
Melissa,
found these at Campmor. Sure there are others out there.
Kelty Noah's Staff - Aluminum Pole, 28096 | Tent Accessories | Tents | GEAR | items from Campmor.
Teri
teri85 is offline   Reply With Quote
Old 03-17-2012, 09:14 PM   #9
DaveK's Avatar
Trailer: 2011 Escape 5.0
You can, yes. WalMart had fairly inexpensive ones the last time I looked. Or you might try your local Goodwill/Salvation Army/St Vincent de Paul/etc. Or even your parent's garage.
Tarps being heavy, they tend to sag in the middle. If you need to use a center pole, don't make a hole in your tarpaulin even by accident. Stick a tennis ball on the end of the pole to protect the tarpaulin.
If you use a bungee cord between your guy line and your stake you can avoid those horrible little clips that never work that well to keep your line tight. Of course there is always the venerable Taut-line hitch - Wikipedia, the free encyclopedia
Ceilityme's tip is a good one to save a quality tarp but if you're planning to use blue polypropylene tarps you might as well use the grommets Imho. The tarps will be raggedy by the end of your trip in any case.
You can ask Byron: tarp camping is practically a mandatory rite of passage in the Northwest.
Dave
DaveK is offline   Reply With Quote
Old 03-18-2012, 07:03 AM   #10
OneTim's Avatar
Trailer: Escape
Rhode Island
Consider buying a Kelty Noah tarp and a couple of their adjustable poles. You'll need four guylines and four stakes. The tarps are available in several sizes. The shape of the Kelty tarps make them much easier to set up and less flappy than rectangular tarps. Here's a link to Campmor...
Campmor: kelty tarp]Campmor: kelty tarp]Campmor:
OneTim is offline   Reply With Quote
Old 03-18-2012, 08:34 AM   #11
Trailer: 1978 Boler
Manitoba
If the issue is simply <not tying things to trees> , fling water bottles tied to a long string (attatched to the corners of the tarp or even better an old tent fly) over high branches. If the water bottles aren't heavy enough, you can peg the ropes down. To take the tarp down, just detatch the water bottles. Ta-dah. Hope this makes sense, I'll see if I can find a photo...
We're fans of the kitchen tent but use the tarp method on canoe trips..
travel_buzz is offline   Reply With Quote
Old 03-18-2012, 08:42 AM   #12
jenbooks's Avatar
Trailer: Casita Spirit Deluxe 2003
Melissa, get four kelty adjustable poles--campmor, REI, amazon all sell them. They are great--and they fold up, they're strong, really well made. For a tarp I would get Equinox urethane coated tarps--they fold up small, last forever, don't crinkle, and are really nice. Those are on sale at all the above online places too.
The kelty poles have a metal thing at one end that goes through the tarp grommet, and nice sturdy rubber caps on the bottom. They are adjustable from 6 to 8 feet. If used properly they'll hold against high wind.
With the Kelty adjustable poles you can put two poles a little higher than the other two so your shelter "leans" so that rain will run off it. You will have to guy out each pole--with bungee cords and stake them well. You'll want the bungee cord/guylines to slant out so that the entire structure holds well. Get a bunch of bungee cords at Walmart, in camping section.
jenbooks is offline   Reply With Quote
Old 03-18-2012, 08:48 AM   #13
Humm. I really, really dislike tarps. Didn't like them when I was a tent camper, won't use them now with my trailer. I'd rather use my E-Z up (which isn't) than deal with tarps, poles, guy lines and stakes. The thing I remember the most, is spending a lot of time getting it "just right," then the flipping sun would move and now most of my tarped area was in the sun... like late afternoon. If you are going to be in an area where you NEED shade all the time... I'd suggest buying something that's free standing and can be moved around. One way or the other, you're making an investment. Whether you choose to invest in tarps, lines, poles and stakes or something that I consider more "usable" is certainly your choice. I buy for now and the future, not for one trip. YMMV
I'm putting this one my Christmas list, yes.. it's a lot of money, but after seeing several in use... I wanna!
Overstock PahaQue 10x10 Orange Overstock is selling it for about $60 cheaper than Amazon right now. Melissa... it's just your color! I wish it was yellow for my trailer...
Old 03-18-2012, 10:12 AM   #14
jenbooks's Avatar
See, Donna, I am just the opposite. I dislike bulky big canopy and screen shelters and having to clean them and carry them. The Equinox tarps are top of the line, and I love the versatility. I can make anything I want out of them in any shape or form. But I come from a tenting experience of a year and a lot of research into backpacking ultralite gear. So the idea I can fold something up and it's lightweight and can serve multiple purposes is just great for me. We had a screen shelter and ditched it. Too big, bulky, and got too dirty too often, hard to clean.
What kind of tarp would make a good awning? Vickie B. Problem Solving | Owners Helping Owners 30 03-24-2011 09:21 AM
Converting old plexiglass into new sun shade VIDEO kevin61 Modifications, Alterations and Updates 6 07-28-2008 07:46 AM
Awning -- Shade Pete Dumbleton Problem Solving | Owners Helping Owners 0 07-22-2006 03:42 PM
Egg in Shade II Legacy Posts Modifications, Alterations and Updates 11 08-22-2003 01:19 PM
Privacy Shade Legacy Posts Modifications, Alterations and Updates 16 07-03-2003 12:16 PM
