The Burro and the bad tranny - Page 3 - Fiberglass RV
Old 08-17-2006, 08:15 AM   #29
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
I had an '88 Ranger 4WD auto that was capable of being towed on flat-four with the mechanical transfer case lever in "N". It's an absolute no-no with Toyotas. Each brand and model is set up differently. I also lock OD out when I tow. The RPMs at speed are only about 10% different, and the mileage isn't much different at all, but there's a lot more power with the torque converter locked out.
Roger
Old 08-17-2006, 04:05 PM   #30
Brian B-P's Avatar
...I also lock OD out when I tow. The RPMs at speed are only about 10% different, and the mileage isn't much different at all, but there's a lot more power with the torque converter locked out.
Roger, I'm confused : are you locking out overdrive (OD), which is the top gear ratio, or are your locking out (disabling) the torque converter lockup feature?
Both controls have been offered in various vehicles. For example, my Sienna allows me to select "4" instead of "D" (so the highest gear ratio - 5th gear - will not be used), but it does not have a way to tell the transmission to never use the lockup clutch on the torque converter. On the other hand, some cars have had a button to disable the lockup clutch.
Old 08-17-2006, 04:57 PM   #31
Roger H's Avatar
Iowa
On both my Excursion and my Tundra, I believe that the OD "off" switch locks the torque converter, and doesn't allow the overdrive to operate or the torque converter to slip.
Roger
Old 08-24-2006, 11:46 AM   #32
Myron Leski's Avatar
Trailer: 19' Escape
NM
A check just came in today's mail, bringing to a happy ending the AAA part of our aborted try to get to Gilbert Lake. So triple A, who initially would not come tow our trailer when we got stuck did in fact reimburse us fully for the tow expense incurred. It wasn't peanuts. Came to $285.00.
No, we did not tell them the local tow guy State Police called had towed the entire rig. No, he did not include this information on his bill, which we sent a copy of with the reimbursement request. So no, the question we really want an answer to, "Why did they refuse to tow the Burro?", has not been addressed.
Maybe it is simply an aberraton, a one-time case involving an ill-informed dispatcher. Maybe not. All I know is, one in the hand is worth two in the bush. Knowledge may be priceless, but money...is green.
Myron Leski is offline   Reply With Quote
burro
Burro Widebody, Burro and UHaul Nancy Reeves Problem Solving | Owners Helping Owners 15 06-27-2011 08:41 PM
Project Burro- 1978 Burro 13 foot Scott B. Classified Archives 0 08-09-2009 11:19 PM
I've got a Burro Manual and Burro Waxing Tips!! Amy P Problem Solving | Owners Helping Owners 9 07-28-2009 08:20 AM
Still looking: for Burro or Burro clone, wide body, 14' to 17' Penney H. & Mike E. Wanted: Molded Fiberglass Travel Trailers 0 08-29-2007 07:48 PM
