Thom and Cari's Parkliner - Page 12 - Fiberglass RV
Old 04-20-2013, 04:20 PM   #155
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by Brian M. in NY View Post
You may not be old enough to remember, but with all those cupboard doors standing open, I felt just like Andy Griffith in "No Time For Sergeants" when he got all the toilet seats in the latrine to pop to attention for the General.
Old 04-20-2013, 04:29 PM   #156
Brian M. in NY's Avatar
Trailer: 2013 ParkLiner
Upstate New York
Precisely! Thanks!
Brian M.
Always remember you're unique, just like everyone else.
Brian M. in NY is offline   Reply With Quote
Old 04-20-2013, 04:38 PM   #157
You know...looking at it again, I'm thinkin' your solution is the one that works- the props both Glenn and I posted look like they're for doors that close flat on the frame surface...
Francesca
Yup. My doors do stand proud of the frame. I would think there is probably a version or installation technique for flush fitting doors though.
Old 04-20-2013, 05:01 PM   #158
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
You may not be old enough to remember...
well not when it was a new release anyway! i was only a year old...being the Sputnik Baby that i am.
Thanks for sharing the video, way funny.
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 04-20-2013, 06:12 PM   #159
Mike Magee's Avatar
Trailer: Li'l Hauley
When I get ready to load my cupboards, I'll just ask Francesca to come over and hold the doors open for me. Problem solved! (although that solution might lead to other problems, like trying to explain to my wife...)
How to prepare Tofu
Step 2: grill some meat
Old 04-20-2013, 06:24 PM   #160
O.K...
But don't expect me to make 'em all salute at the same time!
Francesca
Old 04-20-2013, 09:13 PM   #161
Trailer: Chalet
Send a message via Yahoo to Lynn Musgrave
It shouldn't be to much of a problem....remember Francesca "might not " be real....after all she "has Never been sighted". Sooooo if you can't see her maybe the wife couldn't ether .Of course you might have to explain your way out of how you got the doors to stay open for you????
Although I do suspect that Francesca is Real...I mean after all someone using that name does have some very nice & helpful post....of course well you just never know for sure ...untill someone is sighted
Lynn Musgrave is offline   Reply With Quote
Old 04-20-2013, 11:25 PM   #162
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Another simple prop is to use a spring mounted to the door and to the cabinet, all you do is open the door and the spring becomes a straight prop like the dowels, but when you want to shut the door, you just give the spring a little tap in the middle to bend/flex it and the weight of the door shuts it as the spring is now a "U" shape.
Old 04-21-2013, 07:23 AM   #163
accrete's Avatar
Astoria Oregon
Originally Posted by David B. View Post
Another simple prop is to use a spring mounted to the door and to the cabinet...
THX David, i did see a post on that and even saved the images to my PC. When i visited HD to look for parts i priced things out and the springs we had available that i thought would be properly sized ended up being ~$3 each x 10 upper cabinets, plus epoxy to glue wood blocks to inside of fiberglass cabinetry/frame, plus wood put the project at around $40ish...so i stuck with the dowel idea. . . at ~$6ish.
Old 04-22-2013, 05:32 PM   #164
accrete's Avatar
Astoria Oregon
Lightbulb
Many thanks to Brian (PL#034) for doing the research on replacement LED bulbs for the interior lights in our Parkliners. Here are some images and captions. I really like the light of the LEDs, easy on the eyes for reading.
You will need six of these bulbs from dyersonline.com it took ~5 days from order to receiving them:
Here is what you will receive (All packs contain both dual pin and bayonet style adapters. The only bayonet style bulb is the one on the ceiling) :
Here is a comparison of bulbs outside of housing:
Here is a comparison of bulbs in use:
Cheers!
Thom
Old 04-22-2013, 06:15 PM   #165
Tim Wood's Avatar
Trailer: Class B for now
NY
Brian, Nice job on your cabinets also, the camper looks great.
Old 04-22-2013, 06:34 PM   #166
Upstate New York
The great thing about this forum is the way people work together to find easier/better solutions for all of us. Thom has given me some great ideas, like the cabinet props. I'm just glad I was able to return the favor. I found a source for these lights when retrofitting our teardrop and really like the whiter color. If you and Rita had not been so hospitable, we would not have a ParkLiner sitting in our driveway now. Which I will start prepping (draining anti-freeze) tomorrow for the spring "Icebreaker" on Lake Ontario this coming weekend. It is so great to know that there is a history of of experience going back for decades on fiberglass RVs. If you need an answer to a question, someone has probably had the same problem and has a solution. What a great resource!
Brian M.
Old 04-22-2013, 07:04 PM   #167
Upstate New York
Thom, (PL#35)
Glad these worked out for you. We prefer the whiter color and were pleased with these when we retrofitted our teardrop. Should extend battery life considerably! We got the bulb and amber lens for the porch light, which I described to you previously. The lens was an exact replacement for the OEM clear lens and we are well pleased.
Have a great time at the NOG if anyone lets you have any spare time between tours. We are headed to Lake Ontario this weekend for a "Spring Icebreaker" and are looking forward to being on the road! Thanks for all the great photos. We hope to take a lot at the "Icebreaker" and will put them up next week.
Brian M.
Old 04-23-2013, 06:50 PM   #168
accrete's Avatar
Astoria Oregon
Lightbulb
So today's project actually began last nite...
I filled the fresh tank with water and turned on the water pump, turned the kitchen faucet on and watched...as the sink filled up with water! Then, very slowly, over the next ~20 minutes i watched the water level go down until the sink was cleared of water. I knew something must be up. I remembered there was talk of a new style of P-Trap in the sink and i wondered if something was out of adjustment. Also knowing that the cooler would benefit from some more insulation i went ahead and removed the cooler. Here is a picture of the stock placement of the "HepvO" waterless P-Trap:
And while i was poking around i noticed that there was no cooler-frame-screw support wood on the right side of cooler like there was on the left side...so i epoxied some wood for support just in case.
So after some measurements and research on the HepvO and realizing that the flow rate could be improved typically by simply installing the HepvO from the stock horizontal position to an approved vertical placement i went to the plumbing store and picked up the appropriate parts (less than $11.00)...here is how it looks before placing cooler back in:
And here is a close up. It rests nicely on top of bubble foil insulation on top of cooler:
Last for this project is a close up of the grey tank inlet. As noted in image text i re-routed the flex tube and made it as efficient a path as possible:
That's it! Easy mod with really nice benefits. And the HepvO really works. It truly is a one way valve. No way smells or fluid is coming up that thing into sink/cabin!
Happy trails,
thom
parkliner
Thom & Cari's Adventure Blog accrete General Chat 40 12-09-2014 04:05 PM
WA: Parkliner Thomas G. Referrals: Molded Fiberglass Trailers 19 04-15-2013 09:37 PM
Went to see a Parkliner Ruthies Radiola General Chat 3 06-09-2012 06:32 PM
Parkliner, Anyone? GingerB Hi, I am.... 6 04-25-2012 06:56 AM
