Tire size? - Fiberglass RV
Old 05-05-2011, 03:29 PM   #1
Trailer: currently shopping
Tire size?
Is it better in general to have 14 inch tires vs 13 on an rv?
15 foot rv, about 2400 lbs loaded?
aimeelightsey is offline   Reply With Quote
Old 05-05-2011, 03:41 PM   #2
I believe most people opt for the larger tire and wheel sizes.
Mike
Michael W A is offline   Reply With Quote
Old 05-05-2011, 03:54 PM   #3
Mike
Yes, you are right -- people have a preference there. Just wondering if there is a reason why...
Old 05-05-2011, 04:06 PM   #4
Generally the larger sizes have greater carrying capacity and perhaps a wider selection of tire brands available. Tires and their failures cause many an issue with trailers.
Mike
Old 05-05-2011, 04:11 PM   #5
honda03842's Avatar
Name: Norm and Ginny
Tires are rated for their abilty to support a load in pounds. Generally the larger the diameter, the larger the load that can be supported.
For example, the best 13 inch Goodyear Marathon is rated to support 1480 pounds at maximum inflation per tire.
The best 14 inch Goodyear Marathon is rated to support 1870 pounds at maximum inflation per tire.
Larger tires simply provide more margin and is the reason some people go up one size.
Hope this helps,
Norm
Old 05-05-2011, 04:53 PM   #6
Greg H's Avatar
Trailer: 72 Boler American
Indiana
The larger tire also makes less revolutions per mile. 15" tow tires and 13" trailer tires,
think of a Great Dane and a Wiener dog in a foot race.
Old 05-05-2011, 04:54 PM   #7
Thanks for the info!
Old 05-05-2011, 05:20 PM   #8
Trailer: Fiber Stream
Talking I resemble that remark...
I have dual axles with 12" tires. I like that Wiener Dog analogy!
Old 05-05-2011, 05:24 PM   #9
Greg H's Avatar
Indiana
I have three Wieners and a Great Dane so it was easy.
Old 05-06-2011, 07:13 AM   #10
Victor Benz's Avatar
Remember, the 12", 13", or 14" being quoted is the diameter of the rim, not the tire. What is as, or more important, is the tire profile itself; the distance from the rim bead to the tread. It is possible to have a 14" rim with a very low profile tire that has a smaller "tread" diameter than a 12" rim with a high profile tire.
Generally, a larger "tread" diameter is preferable because:
  1. higher load rating
  2. more tread to wear per mile travelled
  3. lower rpm, meaning wheel bearings should last longer.
Of course, this assumes the larger tire will fit within the wheel well. As Frederick says, our Fiber Streams have 12 " rims. Having said that, the tires do have a high profile. We cannot really put in a higher profile because the spacing between the two axles is quite limited!
Vic
Victor Benz is offline   Reply With Quote
Old 05-06-2011, 02:38 PM   #11
Trailer: 1980 Burro
Vic
If all other things are equal, a higher profile tire will be more susceptible to trailer sway.
Andy B is offline   Reply With Quote
Old 05-06-2011, 07:10 PM   #12
Raz
Raz's Avatar
Vermont
Is this because it increases the ground clearance, changing the center of gravity and air flow around the trailer? Raz
Old 05-06-2011, 08:15 PM   #13
Trailer: 1980 Burro
No, I said if all other things are equal, (not a larger diameter tire, just a taller tire sidewall) so the trailer would not be any higher. It is because the tire sidewall is taller and can flex more. If there are 2 tires of the same diameter and side wall thickness, and one uses a 13" rim and the other uses a 15" rim, the 13" rim tire can flex side to side more than the 15" rim tire.
Old 05-07-2011, 04:09 AM   #14
Raz
Raz's Avatar
Vermont
This is new stuff to me. Most folks talk about going from say a 13" to a 14" tire to gain ground clearance. What you are saying is that another reason might be to reduce sway. One could get a larger rim and smaller profile tire and the diameter would be the same so the tire would fit in the same wheel well.
Tire Size Pat C Problem Solving | Owners Helping Owners 2 04-08-2010 09:46 PM
Scamp 19' tire size? Randya General Chat 15 06-11-2009 04:54 PM
scamp 13 tire size jmacchi Problem Solving | Owners Helping Owners 2 04-12-2009 06:21 PM
Tire Size for Trillium Barry Konkin Problem Solving | Owners Helping Owners 11 03-10-2009 11:22 AM
Boler tire size? Cory K Problem Solving | Owners Helping Owners 5 05-13-2007 11:49 AM
