Tire Sizes and Type for Scamp? - Fiberglass RV
Old 05-30-2014, 09:21 AM   #1
Seth and Desiree's Avatar
Name: Seth & Desiree
Trailer: 1987 Scamp 13'
I was just wondering how to know what size wheel/tire is right for the 13-foot Scamp. I think I've seen 13-inch wheels are common but could you put a 14-15 inch on there as long as the bolt pattern is the same? Or will it rub?
Also, I've seen things like load type B, C , D. What are those for? Thanks!
* Professional Photographers at Zelo Photography
* Maker of Stuff and Doer of Projects at Stuff Seth Makes
* Proud Owners of Scamptastic
Seth and Desiree is offline   Reply With Quote
Old 05-30-2014, 11:48 AM   #2
Trailer: 77 Scamp 13
The B,C,D are ratings that relate to how strong the tire is. Typically the further down the alphabet you go the more pressure you can inflate the tire to. Creating a stiffer tire. Not exactly equal to load capacity but related. More a description of how well the tire can handle the given load capacity.
Understanding Tire Load Range - Town Fair Tire
If you scamp has a 4 bolt rim I think 13 inch is the only one offered, at least commonly at tire stores. 14 and 15 inch rims will use up more wheel well space and make the condition of your torsion axle rather critical. If the torsion suspension is getting a little old the trailer wheel well will sit low on the tire.
Typically changing tire rim to 14 or 15 inch involves replacing the axle with one having more down angle to make it fit in the wheel well if the original was a 13 inch rim.
Scamps sit low as stock but that does help with wind drag when towing.
Old 06-05-2014, 09:12 AM   #3
Thanks for the info!
Frustrated with wrong rivot sizes sent from Scamp courtney Modifications, Alterations and Updates 9 06-22-2013 10:34 PM
AC fans - type and how many CFM? ericw Modifications, Alterations and Updates 4 08-24-2012 07:55 PM
Bigfoot 5th whl trailers - 2 sizes? 19 and 20? Wayne Hill General Chat 3 03-26-2011 05:34 PM
3 way fridge.(and best type of batterie). The Hobo General Chat 5 03-14-2009 12:58 AM
2003 Scamp 16SD tank sizes Chris Z Care and Feeding of Molded Fiberglass Trailers 4 05-30-2006 06:16 AM
