Tires you dig - Fiberglass RV
Old 12-26-2012, 08:14 AM   #1
Trailer: Looking!
Idaho
Tires you dig
After tons of research and a huge first post in this forum, I'm picking up a 17' Casita Spirit Deluxe in January. In the end, my budget allowed for the Casita over the Escape. I'm pulling this trailer on tour across 48 states for 8 months and I figure 40,000+ miles. Last year I drove 75,000 miles!
Here is the first discussion, if you're interested: My pick: Escape trailer - Fiberglass RV
But! I'm here about tires!
I have a 1999 Tacoma 4x4, Ext Cab, TRD, 5 speed with the 3.4L. The truck has a Class III hitch, but not the factory towing package. It also has a 2" Old Man Emu lift. The lift sounds more extreme than it is, really it's just a great heavy duty off road suspension.
Right now I'm running 33x10.5 R15 - BFG A/T KO tires. I get about 16mpg with these tires @ 65mph on cruise with these tires. My particular Tacoma came stock with 31x10.5 tires, because of the TRD package. I know I'll need some smaller more friendly tires for towing.
For that generation, there are other stock tire sizes:
225/75-15
265/75-15
31X10.5-15
What will be my best tire option? Although it might look a little silly, would the 225/75's be a good option, so I could gain extra torque? What brand model of tires do you love?
tjhva is offline   Reply With Quote
Old 12-26-2012, 09:13 AM   #2
I would look at what the actual axle gearing is and pick the appropriate tire for the gearing that the factory used for that gearing. This will work to put the truck in its proper torque band thus saving gas and allowing you to properly run over drive. You could also regear the truck to your current tire size and achieve the best of both worlds if that wasnt done when swapping to the 33" tires. For a street type tire I like the Michilin LTX tire it will take you anywhere you want to go and last a long time. Getting the tire size right to its proper gearing will get you all the torque the truck has avaliable and make your trip so much better.
Old 12-26-2012, 12:09 PM   #3
Brian B-P's Avatar
Originally Posted by tjhva View Post
Right now I'm running 33x10.5 R15 - BFG A/T KO tires. I get about 16mpg with these tires @ 65mph on cruise with these tires. My particular Tacoma came stock with 31x10.5 tires, because of the TRD package...
225/75-15
265/75-15
31X10.5-15
Are those fuel economy and cruise speed numbers adjusted for the odometer/speedometer error due to the oversize current tires?
Old 12-26-2012, 01:07 PM   #4
Raz
Raz's Avatar
Vermont
Congratulations on the Casita. I will be interested in your impressions when you get it. On tires, I have always had good luck with Michelin tires, only in my case it's always been their snow and ice tires. For your situation I will be curious what others recommend. Raz
Old 12-26-2012, 01:26 PM   #5
Trailer: FunFinder
I would suggest to you that as you have figured, using a tire of stock diameter will help you keep the engine higher in the rev range, and likely in the better part of the torque curve.
I would shop carefully and find a LT tire that you can run at higher inflation pressures than a comparable "P" tire.
The Taco is a good choice.....no make that a GREAT choice of tow vehicle for your application.
Expect a certain forum member to come along here shortly and tell you "you-don't-gotta-have-a-pickup" to tow that little 'ol camper.
It's ok.....you can always ignore bad advice.....you done good choosing your TV....
( pickups RULE )
Have a happy new year everyone !
gmw photos is offline   Reply With Quote
Old 12-26-2012, 03:14 PM   #6
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I thought you were asking about tires for the trailer but I see not...I've no opinion about tires for the pickup, but I'd like to say this about your opener:
I love it- referring us to the "My pick is the Escape" thread to find out you bought a Casita!
A perfect illustration of the flexibility necessary when looking for the ideal trailer....
I think you chose wisely, given the similarity in size/weight of the Casita and the Escape...and you're getting the molded fiberglass interior to boot!
You'll certainly need all the tongue weight-carrying capacity your existing TV has for the tongue, though...so as stated, don't let anyone try to persuade you otherwise. I'm a great believer in getting a trailer that matches up with one's existing tug!
Francesca
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 19 12-30-2014 01:14 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 10:33 PM
The "BIG DIG" in Maine Gerry General Chat 17 04-07-2008 03:45 PM
