Toilet Cleaning Idea - Page 2 - Fiberglass RV
Old 03-31-2013, 11:10 AM   #15
cpaharley2008's Avatar
But, I recall Lil Snoozy's toilet does not have it's own water supply, it pulls from your tank so that my procedure only works if the cassette has it's own water supply separate from the rest of the unit. Check with Alan or Nick.
Old 03-31-2013, 12:28 PM   #16
carlkeigley's Avatar
NE Oklahoma
Interesting point. There is plumbing from the water supply back there.
I know there is plumbing back to there for the shower. So it may draw flush water also.
I will check.
Old 03-31-2013, 12:30 PM   #17
If you do not have to add water to your cassette, then it is drawing from your main tank.
Old 03-31-2013, 01:33 PM   #18
Brian B-P's Avatar
Two last comments on the cassette toilet fill:
A cassette toilet is usually (maybe not always) plumbed into the trailer, rather than having a separate water tank, because it is built into the trailer body so the waste tank cassette can be removed through an outside hatch. This antifreeze flush idea seems ideal for a portable toilet, which always has its own supply tank.
A plumbing antifreeze based on propylene glycol would be sticky; one of the alcohol-only types would be more suitable for this non-standard use, and I assume that it would be diluted to just strong enough to not freeze.
Old 03-31-2013, 03:19 PM   #19
Trailer: In the Market
Kansas
We have had 2 cassette toilets and both had their own fresh water supply. I didn't even know it was possible to have one plumbed into the fresh water supply but that would have helped me avoid a lot of spills! I don't know if I would like that though after taking a minute to think about it.
Cathy P. is offline   Reply With Quote
Old 03-31-2013, 04:08 PM   #20
Brian B-P's Avatar
Just curious: why not? I can't imagine why I would want an additional chore of separately filling another tank, unless the trailer had no pump and a toilet having its own tank could run without power.
Old 03-31-2013, 04:19 PM   #21
My cassette had it's own pump and tank built in. Quite nice!!
Old 04-01-2013, 07:12 AM   #22
Kansas
I'm the only one that actually ever keeps track of how full the waste tank is for one and we have a son with Down syndrome who is an adult and likes to "flush" and with an endless supply of water............ Plus, it does give us the ability to anti-freeze the fresh water supply in the toilet and I'm guessing probably easier to replace and cheaper with the water tank just a part of the cassette. I like things to be as simple as possible.
Old 04-01-2013, 10:30 AM   #23
Trailer: Airstream 23D International Serenity
Originally Posted by carlkeigley View Post
<<< snip >>> ADD A CUP OF DAWN <<< snip >>>
Wow! That's a lot!!
Rob & Linda
Our EX-Casita photos: http://www.flickr.com/photos/rfpd300/sets/72157626742329244/
Rob and Linda is offline   Reply With Quote
Old 04-01-2013, 10:58 AM   #24
Kansas
Originally Posted by Rob and Linda View Post
Wow! That's a lot!!
Makes me think of that old Doris Day movie with all the soap suds - open the door to the trailer when you stop..................... I hope everyone realizes that you do have to be careful what kind of concoctions you mix and put in the toilet because some are toxic.
Old 04-01-2013, 11:04 AM   #25
Yes, I try to avoid drinking from mine for that reason.
Old 04-01-2013, 12:29 PM   #26
NE Oklahoma
That's what dogs are for: to test the waters. j/k
Old 04-01-2013, 01:38 PM   #27
Kansas
I should have said "produce toxic fumes". Ever see the toilet "smoke"?
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
any idea what this one is (was)? Cricket General Chat 7 01-30-2013 02:18 PM
Need help with AC idea. Faith Modifications, Alterations and Updates 5 08-29-2010 06:57 AM
Idea??!! Veronica81 General Chat 11 04-27-2006 11:37 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
