03-04-2013, 06:29 PM
Trailer: Own a 2013 BF 21 foot.
Took the plunge
Drove 440 miles to one of two dealership on the west coast and bought a 2013 21 footer with rear bed. BF is being built even as I type this with delivery scheduled for end of this month.
Got a fair trade in on my Lance 950 camper so I'm happy.
David
Socal
03-04-2013, 06:33 PM
Congratulations. That is a very nice trailer.
03-04-2013, 06:44 PM
Trailer: U-Haul 1985
Nice!! Please post photos when you get it! Congrats!
03-04-2013, 07:32 PM
I think you're gonna love your new BF. Congratulations!!
03-04-2013, 07:57 PM
I better love it considering what it cost. The good news is I don't have to put gas in it.
David
Socal
03-04-2013, 08:13 PM
David
Socal
And you will, post pictures won't you... with big ole grins!
03-04-2013, 08:49 PM
No pics yet. Being built even as we speak and should be delivered end of this month they tell me. My truck is over kill being a diesel 1 ton dually but paid for so will keep the truck. I can't imagine needing sway control with this truck, any opinion on the sway control? Thanks.
David
Socal
03-04-2013, 09:25 PM
Trailer: none
us
Congratulations on the 21RB! You're gonna love it. BTW, how will it be optioned?
As for the sway control, I initially towed my 21RB with an F250 for about 1500 miles without sway braces (standard hitch) and didn't have a problem. I later bought a Hensley and frankly, it towed about the same. The only benefits I've gotten out of the later is some peace of mind and being able to lower my tailgate completely after also installing a power tongue jack. The tongue weight on my trailer can get a little light, especially if the water tank is full but even then it has never given a hint of sway.
03-04-2013, 09:35 PM
Well I don't think I'll need a sway bar. I do have a weight distribution hitch and may use that. Options, no genny or solar panels or electric jack but everything else. I do have a Honda 2k and if the weather is too hot I'll plug in somewhere. I usually boondock but wondering, is thete a compartment for the genny that can be used for storage?
03-04-2013, 09:52 PM
Trailer: none
us
You probably need a weight distribution hitch less than some type of sway control given that you will be towing with a 1 ton truck. I think you'll be surprised how little the tongue weight will be on your 21RB.
The only outside storage on the 21RB is a fairly good size compartment (under the bed) with access on the entry side of the trailer. I don't think it's tall enough to fit a Honda 2000. Besides, it's probably not a good location to store a heavy generator considering the effect it would have on tongue weight. The only other sizable compartments are under the dinette bench seats but I don't think the generator will fit there either. What's wrong with the bed of the pickup?
03-04-2013, 10:30 PM
I'll use the truck bed for the genny and all the rest of items that I was unable to carry in my lance camper. Looking forward to getting this thing. I had an airstream once that was 1000 pounds lighter than the BF and pulled it with a 3/4 ton, went coast to coast with no sway bar and never had a problem. I'm sure the dealer would tell me I need it for the sale. Just don't know.
03-04-2013, 10:58 PM
Trailer: none
us
FWIW, I don't think you need sway either but I would still watch your tongue weight.
03-05-2013, 07:06 AM
So what do I need to be aware of regarding the tongue weight, is the concern too heavy or not heavy enough? What causes the sway, I though it was too much trailer for the tow vehicle? Thanks.
David
Socal
03-05-2013, 07:31 AM
Sway is caused by tongue weight being too light. The heavier up front weight, the less sway. Too much trailer for the tow means you need a weight distribution to shift some weight to the tow's front wheels and some to the rear of the trailer.
03-05-2013, 07:46 AM
Either of the holding tanks up towards the front of the trailer? Seems to me the fresh water is 34 gallons and at over 8 lbs per gallon would add in excess of 280 lbs. Am I on the right track here? Thanks.
03-05-2013, 08:04 AM
Trailer: none
us
David
Socal
Perhaps I sounded too much like an alarmist. Your trailer will be fine. I never had even a hint of sway with my 21RB but the tongue weight has always been less than the 10% of trailer weight that seems to be the target ratio. I'm sure others more experienced than me will chime in and explain the causes of sway but one goal is to have a well balanced trailer. I never heard of too much tongue weight causing sway. I don't think the tow vehicle has anything to do with affecting trailer sway but it has a lot to do with how it reacts to it. Obviously the "tail wagging the dog" is much less affected by a large dog. But I think it's possible to have trailer sway regardless of the tow vehicle size. Again, I think others are better suited to explain more about trailer sway.
Don't take this as a recommendation but what I did to ease my concerns about trailer balance is weigh the tongue with the fresh water tank full/empty. I also factored in the weight of propane as if the tanks were empty and full. All of the weighing was done with the trailer outfitted as if it was actually being used for a trip.
03-05-2013, 08:23 AM
Trailer: none
us
The fresh water tank on my 2005 21RB is at the furthest point aft of the trailer and under the bed. The gray/black water tanks are also aft and under the axles. And yes, all of this including how the trailer is stocked will affect the trailer balance.
03-05-2013, 08:26 AM
Sounds as tho when loading the trailer I want to load most the weight up front. Maybe 2 six volt batteries wired together would add a few pounds. Am buying this trailer unseen as it is under construction now. I think I'll be fine.
03-05-2013, 08:42 AM
Trailer: none
us
I'm sure you'll be fine too. You may want to check out the Bigfoot Owners Club International (BOCI) online. You're eligible for a free membership because of your recent purchase. They have tons of information on the 21RB including battery modifications. BTW, did you opt for the front cargo box?
03-05-2013, 08:47 AM
Trailer: none
us
I forgot to mention that you might be interested in attending the annual Bigfoot rally this year considering that your trailer will most likely arrive in time for the September meeting. It will be in Cody, Wyoming this year. Information on it is on the BOCI website.
