Towing w/ full or empty tanks ? - Page 2 - Fiberglass RV
Old 05-19-2013, 09:02 AM   #15
IllAnnoy
Originally Posted by jerrybob View Post
Load em up guys.......I stay with minimum weight as much as possible and drive conservatively. That includes my tow vehicle and back pack. Works for me and my mileage is better. Safe travels!
Minimum has an amorphous definition.
Your TV would be lighter without fuel. Your trailer would be lighter without water. Do you carry water in your backpack?
We forgot one thing though... It is "official" administration policy that all we really need to do to save fuel is to air-up our tires.
Old 05-19-2013, 09:11 AM   #16
jerrybob's Avatar
Trailer: casita
I also make my wife walk when we go up a hill!!
jerrybob is offline   Reply With Quote
Old 05-19-2013, 09:40 AM   #17
Trailer: Casita 17 ft DLX SD
Water & Air
We travel with 3 to 5 gallons of fresh water and about 1 gallon each in the grey and black water tank. We stopped at Dixon Spring SP in southern Illinois on our way home from Scamp Camp last year and there was no water available in the park so thank God for the 5 gallons we brought with us. . (Parks water system had a leak and they had lost 250,000 gallons of water in a day and a half)
Floyd : Since it is policy ,How much air should I add to my tires to get unlimited mileage?
and How come the park ranger in Dixon Springs SP had not heard of you .I was really surprised when he asked if you we're in the Illinoy legislature !
Old 05-19-2013, 11:22 AM   #18
IllAnnoy
Infinite pressure,of course!
The park ranger doesn't get out much.
It's spelled "Illannoy" as in "sick and bothersome"!
Why don't you post on Scampers about that great looking 16SD of yours?
That stance looks really cool!
Old 05-19-2013, 11:29 AM   #19
Spelling /Scampers
Thanks Floyd , I completely forgot about Scamper and I will work on my spelling . You can test me next year at Scamp Camp and see how much I have improved!!
Old 05-19-2013, 11:41 AM   #20
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Weight matters to me since so much of my 4-cyl. travel seems to be straight up a mountainside... or back down again. If I'm not worried about the clutch and/or RPMs in second gear, I'm fretting about the brakes!
Seriously, though: in my close-to-the-max setup, I fret more about the placement of the hundred pounds or so of water than I do about its presence. I like the trailer weight to be as stable as possible, and fluctuations in water level/weight in my behind-the-axle onboard tank had a negative effect on that.
That's one of the reasons I took the tank out in favor of a "gravity-feed" system: Portable 2-gallon containers that are mounted as-needed on the trailer wall, and spares distributed elswhere as the rest of the trip's load demands.
This probably wouldn't matter to most folks with bigger setups, but for my particular tug-tow combo, it does make a difference.
Francesca
Old 05-19-2013, 02:27 PM   #21
Brian B-P's Avatar
... I fret more about the placement of the hundred pounds or so of water than I do about its presence. I like the trailer weight to be as stable as possible, and fluctuations in water level/weight in my behind-the-axle onboard tank had a negative effect on that.
I agree that this may be a bigger factor than total weight for some rigs. My Boler's 100 litre of so (100 kg/220 lb or about 25 US gal) water tank is behind the axle, but not by much; with other rigs it could significantly affect balance.
Empty Shell Stoney General Chat 9 10-07-2009 05:37 AM
Towing a 13' Boler with full water tanks Chris de Haan Towing, Hitching, Axles and Running Gear 6 06-18-2009 08:51 PM
Towing a full egg Rick kl Towing, Hitching, Axles and Running Gear 14 10-26-2008 11:41 AM
Empty Shell Help Heather V. Care and Feeding of Molded Fiberglass Trailers 8 09-07-2007 05:57 AM
How to know if Grey and Black tanks are full? Karen Fisch Plumbing | Systems and Fixtures 21 05-04-2006 09:24 PM
» Trailer Showcase
tbd
robz5
trillium
spud
