Trailer Alignment - Fiberglass RV
Old 05-15-2009, 09:47 AM   #1
Keith Williams's Avatar
Trailer: None at the moment :-(
I bought one of the Ball Alignment Kits at Harbor Freight because I've always wanted to try one and they are on sale now for $10. If you are interested, now's your chance.
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=95684
I'll let you know how well it works.
Keith
Keith Williams is offline   Reply With Quote
Old 05-15-2009, 10:10 AM   #2
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
I have one and it's useful but I have a hard time placing it on the trailer end. I'd like it to be right on top of the ball receptacle but it's rounded so it doesn't stay on it well. Maybe I need to make an offset base.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 05-15-2009, 10:23 AM   #3
I haven't been out to the trailer yet, to look at my situation, but I'll bet it's the same issue. The first thing that I'll do, if it is, is attach a small flat plate of steel to the top of the ball socket on the trailer, so the magnetic base will have a firm seat. Since I can't weld anymore, and I really wouldn't want to weld / heat the socket end up that much anyway, I'll just roughen both surfaces nicely and use my favorite "duct tape in a tube" (J B Weld) to stick the plate on. Since it has no structural funtion, the JB Weld should work just fine.
Thanks for the heads up.
EKW
Old 05-15-2009, 10:34 AM   #4
ronsmith100's Avatar
I haven't been out to the trailer yet, to look at my situation, but I'll bet it's the same issue. The first thing that I'll do, if it is, is attach a small flat plate of steel to the top of the ball socket on the trailer, so the magnetic base will have a firm seat. [b] Since I can't weld anymore, and I really wouldn't want to weld / heat the socket end up that much anyway, I'll just roughen both surfaces nicely and use my favorite "duct tape in a tube" (J B Weld) to stick the plate on. Since it has no structural funtion, the JB Weld should work just fine.
EKW
I've been a machinist and at one time I welded good enough to get a union millwright certificate. So I know what its like to "loose it".
I just ordered one... as a loner I need help getting lined up.
Thanks
ronsmith100 is offline   Reply With Quote
Old 05-15-2009, 11:11 AM   #5
John Hussey's Avatar
Trailer: 2000 16 ft Casita Spirit Deluxe
Strange...but I bought one too at a somewhat local Harbor Freight store a little south or my city yesterday, for $9.99. Along beside it was a new sway bar, Haul Master,complete with all pieces and parts for $32.00 and I got it too, to replace my older but rusty sway bar that came with my used trailer. I was getting tired of getting in and out of the vehicle to hook it up and anything that will save me an entrance/exit or two is certainly worth that! I'll try it out soon...
John Hussey is offline   Reply With Quote
Old 05-15-2009, 12:54 PM   #6
Thanks
My problem is that I have a Defibrillator implanted and I can't be close to Magnetic Fields or it shuts the critter off. Can't even lean over a running car engine. So, I sold my Arc Welder since I couldn't use it.
Thanks,
EKW
Old 05-15-2009, 04:33 PM   #7
Adrian W's Avatar
Trailer: Lance 1985~'Casita de Campo' ~23' 4"~Dinette Slide Previously: Scamp 16 ft Side Dinette, Front Bath
New Mexico
Post
I bought one last year and used it several times, often by myself, at other times with my wife helping as well. That was with our Ford Ranger, I have used it a few times this year with the Ford F-150 with the same results, ei worked well. I place it on the "lip" of the trailer's hitch & behind the ball on the tow.
DesertHawk- Las Cruces, NM USA
2015 Lance 1985 ~ Casita de Campo ~23' 4"
~Previously ~ 2005 16' Scamp
2009 White Ford F-150 Reg. Cab Longbed ARE Topper
Adrian W is offline   Reply With Quote
Old 05-15-2009, 05:23 PM   #8
Patrick Mc's Avatar
Trailer: Casita Spirit Deluxe 17 ft
I use two of these:
They're easy to stow in the glove box and useful for other jobs. Plus they're cheaper.
I bought the 6# ones which are extreme overkill. Everytime I take them out of the glove box, half the crap in there comes out stuck to them.
Pat
Patrick Mc is offline   Reply With Quote
Old 05-15-2009, 10:07 PM   #9
Robin G's Avatar
Trailer: 2007 Casita
Since buying a truck with a backup camera, I don't need it, or at least I shouldn't after I get use to the back up camera ( takes a little getting use to) but I may still pick one up as another target. But sure wish I had one with the old truck. Since Dh can't help so wellllllllllllll. I was forever jumping out and checking till I got it just right. Great find Keith
Old 05-15-2009, 10:27 PM   #10
Raya's Avatar
"Okay, about three feet back and way to the left."
Get back in car, reverse, stop. "Oh, maybe a bit farther back."
Back up towards hitch.
Get out of car and walk to back.
"Okay, 2 feet back and eight inches to the left"
Get back in car, reverse, stop. Consider backing a bit more. Reverse. Stop.
"Okay 9 inches back and three to the left"
Get back in car.....
Old 05-16-2009, 05:29 AM   #11
I get some of my best exercise when hitching up... or trying to hitch up!. I've tried all sorts of helpful hints and tools, none have been all that great (for me). Next up to try is to build one of these: Mirror - in New Theory topic
Old 05-17-2009, 10:30 PM   #12
Trailer: 2008 Casita Liberty
Ive used the Harbor Freight 'tennis balls' for some time. I put on under the latch on the trailer and the other on the hitch just behind the ball. I make sure that the trailer is raised above the ball and when the one on the truck is pushed back, stop, pull the parking break, and make only minor corrections to get it on the ball.
They work for me!
genebland is offline   Reply With Quote
Old 05-18-2009, 07:43 PM   #13
MikeCM's Avatar
Trailer: Actively shopping for a project, again.
Keith
I get the Harbor Freight email specials, yesterday the weekly coupons have these for $7.99.
Former 83 Burro Owner (destroyed in fire)
Looking for a new Fiberglass Project Trailer in New England.
MikeCM is offline   Reply With Quote
Old 05-31-2009, 12:30 PM   #14
Keith
I got mine and since it has a flat bottom it wont stay aligned on the round hitch casing.
Here is how I fixed that.
Used two nuts on each side and just squeezed them in until the tennis ball was straight up.
AXLE ALIGNMENT D Tharp Towing, Hitching, Axles and Running Gear 8 09-10-2009 10:43 PM
Magnetic Trailer Alignment Kit Patrick M. Modifications, Alterations and Updates 23 08-08-2008 08:15 PM
Trailer Alignment Kit Greg A General Chat 3 03-02-2008 04:45 PM
Hook-up Alignment andre robillard Problem Solving | Owners Helping Owners 1 04-26-2007 07:21 AM
