Trailer Vent and Storage - Fiberglass RV
Old 01-08-2015, 10:53 AM   #1
honda03842's Avatar
Name: Norm and Ginny
We purchased a Park Model this year and our Scamp 16 is in storage. We keep the bathroom window cracked and the top vent cracked about 1/2 inch to allow air to circulate.
Today a park attendant stopped me to let me know my vent was flapping, still properly connected but open enough to flap as a cold front passes through (for you in northern climes, today's cold front means 62 F).
I went to storage to find the vent open 6 inches. It appears that the vent in a breeze can open by itself. I have neve seen this before.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 01-08-2015, 11:22 AM   #2
It doesn't surprise me. Mine will gradually work itself from tightly closed to open in a fairly short distance of fairly smooth highway driving. It's also happened a couple of times while it was stored at home during windy conditions. Cranking it down fairly tightly helps, but it's something I have to check often. I've thought about rigging something inside to hold it closed in addition to the crank mechanism. Your problem is harder: how to hold it slightly open. Our climate is dry enough that I haven't had to provide ventilation when in storage.
Old 01-08-2015, 11:30 AM   #3
honda03842's Avatar
I might put a light bungee cord on the inside so I can still keep it cracked. I haven't seen any mold build up in the trailer after 8 weeks. This is our first time not using it our RV over the winter in 14 years.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 01-08-2015, 11:40 AM   #4
darn right balmy to those of us in this part of NA at this time of year - time to bring out the flip flops!!
Norm in these parts its not uncommon for vents to work there way open higher than you want due to wind - I actually had the side bathroom window work its way from being open by an 1" to fully open position in one wind storm. You can tape the handle on the inside of the vents to stop them from moving when in storage but the risk is if you secure it to tightly the vent can and will rip right off the trailer in real high winds - that happened to a few folks at a trailer meet we held one year when a crazy wind came up for about an hour.
To avoid the vent/wind issue, I added the Window/Maxx vents to the rear side windows of my trailer so I can leave one open an inch or so (normally on the side the wind is least likely to blow directly at) to allow venting when trailers in storage. If *really* high winds combined with rainy conditions are forecasted I just shut the trailer right up rather play it safe than sorry.
Old 01-08-2015, 11:54 AM   #5
What I've noticed is that, because the vent is fairly large and not very stiff, any wind that gets under it creates a vibration that loosens the crank mechanism. I suspect a light bungee cord would still allow the vibration to occur. I thought about putting some blocks on the outside at the corners to hold it open the desired amount, and then using a fairly strong bungee inside to pull the cover down tightly against the blocks.
Old 01-08-2015, 12:00 PM   #6
Norm; how about a piece of wood under the edge of the vent and crank it down against that to keep pressure on the mechanism. Would it be a good idea to put some kind of dehumidifier in the Scamp, the kind that doesn't require power. One of our pillows that is in the rear corner of our Casita got some mold on it so we are looking into a dehumidifier. Others here at Jekyll are using various types. Our "cold front" today started at 28 degrees at 8 AM, now at 2 PM it's still only34. Florida is starting to look good. What are your average normal temps this time of year?
Old 01-08-2015, 12:03 PM   #7
HA! while I was slowly typing my idea, Jon came up with the same thing. There you go, two people that agree.
Old 01-08-2015, 01:27 PM   #8
Timber Wolf's Avatar
North Florida
I don't know about average normal but in N. Florida this morning my dog's water spigot was frozen. I think it got into the mid to lower 20's last night. We usually get a few nights like that a winter, but not too many thank goodness. As to the dog being outside and cold, well my very fury Australian Shepard is really enjoying this not-hot weather!
Old 01-08-2015, 01:58 PM   #9
I'm surprised our water hookup wasn't frozen this morning. Maybe it was because the temperature didn't go below freezing early in the night. It was mid 40's at 11 PM last night.
Old 01-08-2015, 02:41 PM   #10
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Norm, I've had a small bungie around the handle for a few years now...works perfect. I do keep it cracked and it hasn't moved even in last years 100 mph wind storm. On my cargo trailer I have Maxair vent covers and leave the vents open 24-7. I have never noticed the vent lids ever move from where I left them and they have no bungie on them.
Old 01-08-2015, 03:05 PM   #11
Dave, part of the problem is that the vent I believe Norm is talking about is an oversized vent/escape hatch. It's something like 14"x 23", and the plastic cover doesn't have a lot of torsional rigidity, so it doesn't take a lot of wind to vibrate and twist the cover. It's great for catching light breezes, but as soon as real wind picks up I close it down tight and ventilate through windows only. I can easily see it tearing off in a high wind as Carol described.
The couple of times I have felt a need to leave something open for an extended time unattended, it's always been the little crank-out window over the stove.
Old 01-08-2015, 03:46 PM   #12
I agree with you Jon, it could be ripped off. I only crack the bungie corded one a 1/4" or less, just for a little air. I'm in the desert, we call 30 mph wind just a breeze
Another thought, I changed out a plastic cover for metal to get away from UV problems and heat transfer also.
Old 01-08-2015, 03:53 PM   #13
honda03842's Avatar
To help the UV situation a previous owner coated the plastic with white 'I don't know what it is'.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 01-08-2015, 04:12 PM   #14
Originally Posted by Borrego Dave View Post
Another thought, I changed out a plastic cover for metal...
That's a thought. It's an unusual size though, and the screen opens separately (for use as an escape hatch), so I don't know if there is something out there that would work or not. Haven't run across any discussions here yet.
Maxxair vent vs Fantastic vent? MinnesotaJill Modifications, Alterations and Updates 33 07-26-2014 08:54 PM
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 04:41 PM
Storage, Storage, and Storage Legacy Posts Problem Solving | Owners Helping Owners 18 11-20-2002 09:43 AM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
