10-29-2021, 03:40 PM
#441
Mid Left Coast
so... don't put more than about 250 lbs in the trailer or you'll exceed the trailer's GVW.
remember, water is about 8 lbs a gallon, so a 10 gallon tank is 80 lbs (I have no idea if your trillium has any plumbing or water storage)
10-30-2021, 06:39 AM
#442
Trailer: Trillium Jubilee '79
Newfoundland
Yup. Pretty sobering numbers. I'm curious to see if anyone else with a Jubilee discover similar numbers. We've towed our trailer over 30,000 kms in the last 8 years and I'm sure we've exceeded the 250 lbs threshold, mind you, the car is the main carrier. There is a 12 gallon fresh water tank which we've never used. Instead, we bring 5 or 6 gallons and refill as needed. At 8+ lbs per gallon that still adds up. Not to mention our Honda 2000 generator.
01-10-2022, 11:15 AM
#443
Trailer: Hunter I
Kansas
Originally Posted by Frederick L. Simson
This is a spreadsheet of all of the weigh-in results that I have from the past several years.
Several trailers were weighed multiple times.
8 trailers were weighed by others and reported in this thread.
Sorted 1st by TOTAL, 2nd by TONGUE, and 3rd by Length
Items 13, 14, & 19 are the same trailer, it was weighed 3 times
Items 33 & 37 are the same trailer, it was weighed 2 times
Items 39, 46, & 55 are the same trailer, it was weighed 3 times
Items 61 & 98 are the same trailer, it was weighed 2 times
Items 75 & 91 are the same trailer, it was weighed 2 times
Items 66 & 71 are My Trailer it was weighed 2 times
Item 02 is also My Trailer It is totally gutted*, consisting of just the Frame & Wheels, Floor, Fiberglass Body, Windows, and Door.
Item 105 has a generator on the tongue
Items 55 & 71 These 2 trailers had a FULL fresh water tank up front
ITEM_LENGTH_MAKE_______MODEL________AXLE__TONGUE__ __TOTAL
01___13_____Burro______B13___________718______90______808
02___13_____Hunter_____Compact Jr____800______60______860*
03___13_____Hunter_____Compact Jr____980_____140_____1120
04___13_____Hunter_____Compact Jr___1200_____100_____1300
05___13_____Boler______B1300________1160_____140__ __1300
06___13_____Burro______B13__________1100_____200_____1300
07___13_____U-Haul_____CT13_________1260_____180_____1440
08___13_____Burro______B13__________1260_____260__ __1520
09___13_____Perris_____Pacer________1260_____260__ __1520
10___13_____U-Haul_____CT13_________1400_____150_____1550
11___13_____U-Haul_____CT13_________1400_____160_____1560
12___12.5___WeisCraft__Little Joe___1380_____180_____1560
13___13_____Hunter_____Compact Jr___1540______60_____1600
14___13_____Hunter_____Compact Jr___1480_____120_____1600
15___13_____Scamp___________________1420_____200__ __1620
16___13_____U-Haul_____CT13_________1440_____240_____1680
17___13_____Hunter_____Compact II___1640______80_____1720
18___13_____Scamp______Standard_____1480_____240__ __1720
19___13_____Hunter_____Compact Jr___1600_____150_____1750
20___13_____Boler______B1300________1580_____220__ __1800
21___13_____Trillium___T1300________1600_____240__ __1840
22___13_____Hunter_____Compact II___1700_____160_____1860
23___13_____Scamp______Standard_____1720_____230__ __1950
24___15_____Trillium___T4500________1804_____170_____1974
25___13_____Hunter_____Compact II___1900_____120_____2020
26___13_____Escape__________________1780_____240__ __2020
27___16_____Casita_____Standard_____1780_____240__ __2020
28___14_____Surfside___EEE-TM14_____1880_____240_____2120
29___13_____Boler______B1300________1920_____280__ __2200
30___16_____Casita_____Liberty Dlx__2060_____280_____2340
31___13_____Casita_____Patriot Dlx__2120_____240_____2360
32___16_____Scamp___________________2100_____320__ __2420
33___16_____Scamp______Standard_____2280_____240_____25 20
34___16_____Scamp______SideDinette__2240_____280__ __2520
35___13_____Casita_____Patriot______2280_____280__ __2560
36___17_____Boler______B1700RGH_____2365_____220_____2585
37___16_____Scamp______SideBath_____2400_____200_____26 00
38___13_____Casita_____Patriot______2380_____260__ __2640
39___17_____Escape_____Plan B_______2340_____320_____2660
40___16_____Fiber Stream____________2560_____180_____2740
41___19_____Bonaire____Oxygen_______2420_____320__ __2740
42___17_____Casita_____Liberty______2260_____480__ __2740
43___16_____Scamp______Deluxe_______2440_____360__ __2800
44___16_____Casita_____Freedom______2580_____240__ __2820
45___17_____Casita_____Spirit_______2260_____560__ __2820
46___17_____Escape_____Plan B_______2500_____340_____2840
47___17_____Escape_____Plan B_______2560_____320_____2880
48___19_____Scamp______5th Wheel____2420_____480_____2900
49___16_____Casita_____Spirit_______2640_____300__ __2940
50___17_____Escape_____Plan B ______2560_____380_____2940
51___17_____Casita_____Spirit_______2560_____380__ __2940
52___16_____Fiber Stream____________2800_____160_____2960
53___17_____Boler______B1700________2730_____240_____2970
54___17.5___Bigfoot_________________2600_____380__ __2980
55___17_____Escape_____Plan B_______2500_____500*____3000
56___17_____Casita_____Freedom______2680_____360__ __3040
57___17_____Casita_____Spirit ______2660_____380_____3040
58___17_____Casita_____Freedom______2620_____420__ __3040
59___17_____Casita_____Spirit ______2740_____380_____3120
60___17_____Casita_____Freedom______2700_____420__ __3120
61___19_____Escape_____Dual Axle____2670_____460_____3130
62___19_____Escape_____Dual Axle____2920_____220_____3140
63___17_____Casita_____Freedom______2760_____420__ __3180
64___17_____Casita_____Liberty______2860_____360__ __3220
65___17_____Casita_____Freedom______2880_____360__ __3240
66___16_____Fiber Stream____________3000_____250_____3250
67___17_____Casita_____Spirit_______2860_____390__ __3250
68___16_____Casita_____Spirt________2960_____300__ __3260
69___17_____Burro______Wide Body____2900_____360_____3260
70___17_____Burro______Wide Body____2820_____440_____3260
71___16_____Fiber Stream____________2760_____500*____3260
72___17_____Casita_____Spirit_______2980_____300__ __3280
73___17_____Casita_____Spirit_______2900_____400__ __3300
74___17_____Casita_____Liberty______2880_____420__ __3300
75___17_____Casita_____Liberty______2840_____460_____33 00
76___17_____Casita_____Freedom______2980_____340__ __3320
77___19_____Scamp______5th Wheel____2640_____680_____3320
78___17_____Escape_____Plan B_______3020_____320_____3340
79___20_____CustomLite_5th Wheel____2820_____520_____3340
80___17_____Casita_____Spirit_______3040_____310__ __3350
81___17_____Casita_____Freedom______3000_____360__ __3360
82___17_____Casita_____Spirit_______3000_____360__ __3360
83___17_____Casita_____Spirit_______2960_____400__ __3360
84___19_____Scamp______5th Wheel____2780_____580_____3360
85___18_____Trillium___T5500________3060_____340__ __3400
86___17_____Casita_____Spirit_______3020_____480__ __3400
87___17_____Casita_____Spirit_______2960_____440__ __3400
88___19_____Scamp______5th Wheel____2720_____700_____3420
89___17_____Casita_____Spirit_______2980_____450__ __3430
90___17_____Casita_____Spirit_______2960_____470__ __3430
91___17_____Casita_____Liberty______3000_____460_____34 60
92___17_____Casita_____Spirit_______3140_____360__ __3500
93___17_____Casita_____Spirit_______3020_____480__ __3500
94___17_____Casita_____Spirit_______3000_____520__ __3520
95___17_____Casita_____Liberty______3100_____460__ __3560
96___19_____Scamp______5th Wheel____3000_____580_____3580
97___19_____Escape_____5.0__________2860_____780__ __3640
98___19_____Escape_____Dual Axle____3305_____450_____3755
99___19_____Escape_____Dual Axle____3440_____360_____3800
100__17_____Casita_____Liberty______3140_____680__ __3820
101__19_____Escape_____Dual Axle____3620_____240_____3860
102__19_____Scamp______5th Wheel____3300_____560_____3860
103__17_____Oliver_____Elite________3560_____340__ __3900
104__19_____Escape_____5.0__________3220_____680__ __3900
105__17_____Casita_____Liberty______3300_____660_____3960
106__19_____Escape_____Dual Axle____3740_____240_____3980
107__17.5___Bigfoot_________________4040_____360__ __4400
108__20_____Bigfoot____5th Wheel____3600____1060_____4660
109__20_____Bigfoot____5th Wheel____3780____1000_____4780
110__20_____Bigfoot____5th Wheel____4420_____640_____5060
111__21_____Bigfoot____Rear Bed_____5200____1160_____6360
112__25_____Bigfoot____Rear bed_____6420____1420_____7840
Does anyone have a dry weight on a 1975 Hunter I? It does not have as much equipment as a Jr or II.
01-11-2022, 08:44 PM
#444
Trailer: Hunter I
Kansas
1975 Hunter I dry weight.
I was able to get a dry weight on my 1975 Hunter I yesterday. It was 1200 lbs. It does have a propane tank on the tongue. I will add stabilizers jacks on 4 corners,a spare tire and carrier, and a battery.
01-26-2022, 10:20 AM
#445
Trailer: 2020 Escape 19 (was 2005 16 ft Scamp Side Dinette and 2005 Fleetwood (Coleman) Taos pop-up)
Originally Posted by gordon2
Jon maintains a spreadsheet so you really don't need to read all the posts in the thread, although you might pick up a little more information if you do.
There are eight Scamp 16's in the database. The first one is a DLX. The last two are not specified. (You likely want a tow rating of 3500 / 350 and watch the total weight limits, esp if there is a lot of cargo or people in the tow vehicle.)
The columns are:
D: Axle weight
E: Tongue weight
F: Total weight
H: Year weighed (not the year of the trailer).
That 3,080 Scamp was ours! It was loaded for a long 3 month trip and still had partially filled gray/black tanks. Our Scamp had the front bath and most options, including awning, microwave, furnace, dual propane, A/C, big fridge (loaded), solar panel on top, larger/heavier 155 amp golf cart battery and full fresh water tanks.
That same Scamp would only weigh 2,540 lbs when I took the extra propane tank off and loaded lightly for trips with our Subaru Outback.
Sharpsburg, GA
radar1-scamping.blogspot.com
01-26-2022, 01:25 PM
#446
Wisconsin
3060 lbs
I at one time posted mine as the heaviest in the group, then I was corrected. Mine at 3060 was loaded for travel with two full fresh water tanks but gray and black were empty. (and equipment for three hobbies loaded)
10-23-2022, 11:31 AM
#447
Trailer: 2006 Scamp 19 Deluxe
Enchanted Mountains of Western New York State on the Amish Trail in Cattaraugus County!
Guess I should add my 2018 Chevy Colorado LT Crew Cab/ 1006 Scamp 19 combination to the list here. Can't tell you the tongue weight. Steer Axle: 2920 lbs, Drive Axle: 2960 lbs, and Trailer Axle: 2800 lbs, for a gross weight of 8680 lbs. Nothing in fresh water tank, gray tank empty and black water tank deleted. Was loaded for travel along with about a bushel of apples and a peck of different types of squash for the wife's sisters in the south where you can't get them fresh. Also about 5 gallons of spring and distilled water. I'm "high maintenance" so have to haul along the CPAP breathing machine, blood pressure monitor, and blood sugar monitor.
I came down Boot Jack hill in Ridgeway, Pa and I should have taken the truck route. Have always taken the truck route when I was running big rigs, except before it was built. Never thought about being overweight!!! If you got here, you have gone to far! There is a church parking lot at the bottom of the hill. Before the truck route was built, a friend of mine who was hauling a gas tanker went right thru that parking lot just after church let out on a Sunday morning. Luckly everybody had left the parking lot!
Next trip I will remember my weight!!!
10-23-2022, 12:33 PM
#448
Everywhere
That's a pretty low gross weight for a detour. An empty 1-ton diesel would exceed it.
10-23-2022, 06:01 PM
#449
Trailer: Escape 21C
If you did your weighing at a CAT scale, all you need to do is a second weighing (much cheaper than the first) of the truck alone to calculate the tongue weight.
The gross weight (truck axles + trailer Axle) minus the truck alone weight = the trailer weight. The trailer weight minus the axle weight = the tongue weight.
10-24-2022, 12:16 AM
#450
Trailer: Oliver
By a couple of thousand pounds.
Steve and Tali - Dogs: Rocky and our beloved Reacher, Storm, Maggie and Lucy (waiting at the Rainbow Bridge)
2022 Silverado High Country 3500HD Diesel 4x4
12-11-2022, 01:20 PM
#451
Trailer: Fiber Stream
Just weighed the Fiber Stream on the Cat scale on the way home from 2 nights camping - ordinary duty.
Both propane tanks full
Fresh water empty
Gray water half full
Black water quarter full
2260 lbs
Fiber Stream 16 1986
12-11-2022, 01:26 PM
#452
On the way home from 2 nights camping
Fresh water empty
2260 lbs
Is that axle weight or total weight? Would it be possible to get the tongue weight for a complete data set?
12-11-2022, 01:36 PM
#453
Axle weight. The Durango came in at 5000 even with us in it - 7260 total.
I'll add a tongue weight someday. It took two years to do this
12-11-2022, 08:31 PM
#454
I hear you. I haven’t managed to get a weight in a decade of ownership. Once it’s actually loaded, we’re usually on a tight schedule to get to our destination. We drive right past a scale as we leave town, but it’s always closed when we go by.
12-12-2022, 09:29 AM
#455
Trailer: 2016 Bigfoot 25RQ
There are two Bigfoot 25B25RQ models. The original is 25' 6" long, but most sold in the last 12 years have had the front storage box. The front storage box models are 27' 6" and over 700 pounds heavier when normally loaded. We found it extremely hard to find a 2010 or newer 25RQ without the front storage box.
Our 2003 25RQ was the 25' 6" version. We have a Shurline Scale. When I weighed the camper alone the first time it weighed slightly over 6,200 pounds with a tongue weight of 1,100 pounds, with the fresh tank full (45 gallons), at the high end for our 2015 F150, EB, Max Tow.
We decided to not carry everything under the sun, and got the weight down to 5,900 pounds and a tongue weight of under 950 pounds, again with the fresh tank full (45 gallons).
We pick up our new-to-us 2016 25B25RQ Bigfoot on January 11th, south of Vancover. Then head to AM Solar to rip the single panel 140 watt solar off the roof and install 600 watts on top and a new Victron controller and battery monitor.
It will be interesting to see how heavy a post-bankrupcy 25RQ weighs. From my experience with our 2003 25RQ, and looking at the weights on the spreadsheet, most of the Bigfoots weighed were probably with the front storage box.
Food for thought,
Perry
12-18-2022, 02:00 PM
#456
ETA 250 lb tongue weight
16 Fiber Stream 2260 250 2510
