Trailer Weights in the Real World - Page 11 - Fiberglass RV
Click Here to Login
Old 12-07-2012, 11:49 PM   #201
Originally Posted by David Tilston View Post
Frederick, what do you guess the margin of error is?
Since my wheel-weighers display weight in 20 pound increments, "Tolerance" is +/- 20 pounds, making the margin of error 40 pounds.
Old 12-08-2012, 02:03 PM   #202
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by Frederick L. Simson View Post
And you've returned the favor. I think we're even.
I'm not picking on you, despite any impression(s) some may have to the contrary. I don't expect perfection...it's just that your formal invalidation of the Burro weight results appeared to me to say that you do.
I'm still unclear as to why the (knowable) couple of inches height difference across his six foot axle makes his results invalid while at the same time the (unknowable) height of the coupler across the longer axle-to-ball distance on various trailers evidently doesn't matter at all.
I just don't understand why it matters in the one dimension but not in the other, that's all.
And I ask not to harass you, but because you're considered the expert around here, and since I'm experimenting with a weighing method of my own it's important for me to understand the dynamics involved.
Thanks!
Francesca
Old 12-08-2012, 10:41 PM   #203
I will grant you that. I had added my opinion to the spreadsheet in post #1, and upon reflection re-edited it to remove my opinion from that Location. It is, after all just an opinion. For all I know that fully equipped Burro DOES weigh less than a gutted and stripped Compact Jr. I can acknowledge being wrong, as I have been more than once.
Old 12-11-2012, 03:40 PM   #204
Ice-breaker's Avatar
Thanks!
Francesca
Depending on the height of the center of mass of your trailer, any side to side "tilt" on a single axle trailer (one wheel higher than other) would effect the distribution of weight on the two wheels due to the center of mass shifting to one side or the other. So if you weigh each side with one wheel off the ground and the other on the ground, your total weight could be in error as each measurement may be inaccurate.
Similar issues could exist with tilt in the front to back direction. In this case, the proportion of load supported on the wheels and the hitch could be changed if the trailer is not level.
Ice-breaker is offline   Reply With Quote
Old 01-03-2013, 10:35 PM   #205
There was a suggestion to link this post to this thread:
Originally Posted by samcrimm View Post
Hey everyone,
Took my stripped out trailer to the scales today and it has an stripped out weight of 1120 pounds, A little heavier than I would have guessed but that's me. I also hauled off all the crap I took out of the trailer and it weight 560 pounds. It was not a complete trailer on the inside when I got it, so I am sure it weighted more than 1680. Hope this helps someone down the road.
Sam
Old 01-13-2013, 12:04 PM   #206
Trailer: 1980 Burro
"Originally Posted by Andy B
I weighed my 1980 Burro 13 when I brought it home. There was no battery and the propane tank was half full. There was no camping gear in the trailer, all the cabinet doors, cubby covers, cushions, sink, ice box, and cook top were installed. There is no water tank, water pump. or furnace and no spare tire or leveling jacks.
I jacked up 1 side, put two bathroom scales with a short piece of 2x8 bridging the scales, under the tire, lowered the jack and added the weights from both scales together. I then measured the other side the same way and measured the tongue weight using only 1 scale.
The weights were:
Door side 398 lbs
Street side 320 lbs
Hitch 90 lbs
Total weight 808 lbs
When I removed the body to replace the floor, I weighed the frame including the axle, but no wheels and it weighed 235 lbs."
After review of this explanation, I believe I found the flaw in this result that I failed to see before. Because he weighed one tire at a time without noting whether the trailer remained level (correct) or was tilted due to the height of the scales under just one tire (incorrect) I must believe his result to be invalid.
Since I am the one who's weight measurement is being questioned, I will respond with some additional information.
Prior to weighing the trailer I thought about the angle difference by having the scales under one wheel and considered putting blocks of the same height under the other wheel, but decided that the error would be so small that it was not worth the effort. Since this has generated some discussion I made some measurements. The distance between the center of each tire tread is 62.5". The height of the scales plus 2x8 bridging is 3.5". I made a mock assembly with these dimensions and measured that the weight shift on each wheel due to the angle is only 0.16" inboard (less than 3/16"). I calculated that the shift results in an error of 1 pound on the heavier side and 0.8 pound on the lighter side. Lets call it a 2 pound error. This confirms that it was not worth the effort to put spacer blocks on the side without the scales.
I was wondering how accurate the bathroom scales are, so I took the same 2 scales used to weigh the trailer, used the 2x8 bridge and piled a bunch of large unopened dog food and birdseed bags on the bridge. With the weight on the bags totaling 152 pounds, the scales read 147 pounds. Assuming the weights on the bags are accurate there is an error of 5 pounds.
Assuming the scale error is linear (it may not be) the scale accuracy would result in the following errors:
measured 398 may actually be 411.5 pounds
measured 320 may actually be 330.9 pounds
measured 90 may actually be 93.1 pounds
This totals up to 836 pounds rounded off, add the 2 pounds for the angle inaccuracy and that comes to 838 pounds. So the total inaccuracy is 30 pounds and the Burro may actually weigh 838 pounds rather than 808 pounds.
Using Frederick's scales and method, the 2 pound angle inaccuracy would be eliminated. His scales only display in 20 pound increments, applying 20 pounds to each of the 3 measurement locations is considerably larger than the bathroom scale method. In addition the accuracy of the scales would need to be added since the 20 pounds is only what the display indicates not the scale accuracy. The bathroom scales show 1 pound increments.
Andy
Andy B is offline   Reply With Quote
Old 01-13-2013, 12:16 PM   #207
Excellent clarification...thanks a bunch, Andy!
Francesca
Old 04-09-2013, 03:35 PM   #208
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
If you want to make the .xls format available and assuming it is OK with Fred, email a copy to me & I will post it (and, of course a link to it) on my website.
Old 04-09-2013, 04:24 PM   #209
GMike A's Avatar
I happened upon this thread that was started by Fred a good while back and have taken the liberty of converting his first page to the data that was last shown. I have saved it in 2 formats for excel 2010 and older copies prior 97-03 sw. I could format into a RTF or word doc if desired. Hats off to a lot of measurements that I saw were taken and the forum exchange on the last 15 pages. I am posting the document in a PDF searchable format. Landscape format
Please send me a PM if you would like me to email you a spreadsheet copy since the forum wont allow a excel format.
Fed if this is not acceptable then please delete the attachment.
thanks
More than one way to skin a cat (with all due respect to PITA).
I should have looked at it closer when I printed it.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 04-09-2013, 04:30 PM   #210
GMike A's Avatar
No problem. If fred says okay then will do. In mean time I printed in landscape mode to capture all the data.
Mike
K5NAN
"Miss Adventures"
Old 04-09-2013, 04:38 PM   #211
Thomas G.'s Avatar
Great work, Mike.
Thanks.
Old 04-09-2013, 05:54 PM   #212
David Tilston's Avatar
OK, I am biased, but we need more Trilliums on that list.
Old 04-09-2013, 07:23 PM   #213
Brian B-P's Avatar
I think more Escapes would be great. Frederick, are you willing to make a trip to British Columbia for June 7 to 9... there will be 82 Escapes there!
Old 04-09-2013, 07:30 PM   #214
deryk's Avatar
New Jersey
Heh how about some ParkLiner's too! Lol
deryk
Old 04-09-2013, 09:14 PM   #215
Red face
I think that's a great idea!
I wish I could.
Anybody got $35,000 USD that I can have to finish paying off my mortgage?
Then I could quit my job and just travel to all of the rallys weighing trailers!
Old 04-09-2013, 09:55 PM   #216
While there are a number of Escapes on the list there should be more due to the number of them that attend the Bandon meet were Frederick did the weigh ins for a few years. Actually Escape was the second (in numbers) most popular trailer at the meet last year. Unfortunately not all those who attended the rally (just not Escape owners) bothered to have their trailers weighed.
Old 04-10-2013, 07:20 AM   #217
GMike A's Avatar
Fred I am going to throw this out for discussion. Is there any merit to putting another column next to the "total" column and put in Manufacturer's recommended spec? I'm not quite sure if there is value but think we could graph variations and percentages. See whats above and or below the spec. Perhaps Rabbit could come up with some mathematical interpretations of the data.
Mike
K5NAN
"Miss Adventures"
Old 04-10-2013, 07:54 AM   #218
Brian B-P's Avatar
Recommended spec for what - gross trailer weight, axle weight, or tongue weight? Manufacturer's values for gross trailer weight and axle weight are maximum limits, not recommendations; there is usually neither a recommendation nor a limit provided for tongue weight by by trailer manufacturer.
I hope that no significant fraction of trailers are over their maximums, although of course some likely are.
Old 04-10-2013, 09:16 AM   #219
honda03842's Avatar
Name: Norm and Ginny
Mike,
This post is truly valuable. I wish that the tow vehicle associated with each trailer was posted for additional perspective.
As well, most people post their trailer but neglect under their posting name but rarely do people post their tow vehicle. This is another area where a small amount of additional information would be valuable.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-10-2013, 09:24 AM   #220
deryk's Avatar
New Jersey
Good Point Norm, I will add my tv on
deryk
weighing, weight
Trailer Weights...What are They Really? Pamela H Care and Feeding of Molded Fiberglass Trailers 55 12-01-2009 02:21 PM
List of trailer real weights? Cory Lewis Towing, Hitching, Axles and Running Gear 10 11-11-2009 08:17 AM
World's smallest trailer... Roger H General Chat 3 12-27-2008 08:21 PM
Realistic Tow/Cargo Weights V'sGlassSleeper General Chat 25 07-18-2007 12:11 PM
Real world weight issues Legacy Posts General Chat 2 05-02-2003 05:52 PM
