trillium 1300 city water hook up leaks - Fiberglass RV
Old 07-07-2018, 05:27 PM   #1
Trailer: in the market
Indiana
Anyone know if a replacement is available for a trillium 1300 city water inlet.
Cant find the right size on any site.Most new ones are round and much larger.
Mine leaks and I see the gasket is leaking.
thanks,
Rich
rjannunziata is offline   Reply With Quote
Old 07-07-2018, 06:28 PM   #2
Vermont
Leak
Are you sure it is the fixture that is leaking? On my new 13' Scamp, there was a leak at the connection which I could not stop until I pulled out the little screen with red rubber gasket around it and reconnected the hose. The leak stopped! I'm not concerned about the missing screen because I use a water filter that attaches to the hose at the faucet which filters out debris!
Tony M is offline   Reply With Quote
Old 07-07-2018, 06:36 PM   #3
John in Michigan's Avatar
Rich, I was not able to find an exact replacement for the city water inlet on my Trillium 4500, which originally had matching white square plastic fitting for the city water inlet, fresh water fill and electrical power inlet. My solution was to remove the center portion of the original square city water inlet and insert the following product in its place, and it works fine:
Valterra A01-0170LFVP White 2-3/4" Plastic Lead-Free Flange Water Inlet
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
John in Michigan is online now   Reply With Quote
Old 07-07-2018, 07:59 PM   #4
I did find this and it might be same as original, you would have to contact them to verify:
RV City Water Fill with Flip Cap $28.46 at tyreepartsandhardware dot com.
Old 07-07-2018, 08:00 PM   #5
My original 40 year city water inlet worked for a while, and then it crumbled.
Old 07-08-2018, 07:20 AM   #6
Indiana
exact replacement
thanks all
tyreepartsandhardware had the exact replacement
leaks, trillium
Trillium 1300 Water Leaks Mel P Care and Feeding of Molded Fiberglass Trailers 21 06-05-2019 08:37 PM
Belly bands and city water and the water drain plugs Cheyanna83 Problem Solving | Owners Helping Owners 0 05-25-2015 07:24 PM
Trillium 1300 City water Faucet Joanne Plumbing | Systems and Fixtures 8 05-21-2012 10:52 AM
Mysterious leaks in Trillium 1300...maybe solved David Swinnard Problem Solving | Owners Helping Owners 3 06-11-2009 08:40 AM
