Trillium Door woes - Fiberglass RV
Old 08-28-2012, 06:00 PM   #1
Trailer: "Limelyte" Trillium 1976
Trillium Door woes
Hi! All Here we are 2 days away from our Labour Day Weekend get-away and the screws on the hinge of our 1976 Trillium door have decided to pop out. Can anyone enlighten us how to fix this problem?
Lynners is offline   Reply With Quote
Old 08-28-2012, 06:38 PM   #2
Scouter Dave's Avatar
Trailer: Bigfoot
Newfoundland & Labrador
The door hinges on my Trillium 1300 are bolted on. The previous owner drilled through and replaced screws with bolts. Not the prettiest but functional.
Scouter Dave
Embark upon this journey with enthusiasm and eagerness.
If we were expected to remain in one place we would have been created with roots
Scouter Dave is offline   Reply With Quote
Old 08-28-2012, 08:37 PM   #3
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
I'm not sure how a trillium door is made, but we had problems with our burro door early summer. We are doing a complete repair now, but for the summer, we injected epoxy, allowed it to set up and drilled and re-screwed. It held fine for the 3,000 miles we did.
Sue and Henry is offline   Reply With Quote
Old 08-28-2012, 09:57 PM   #4
For a temp fix, make a wooden plug the same size as the screw hole, dip it in glue and tap it in, let it set overnight and insert a SS screw. Me, I'd just pop a bolt thru there and be done with it.
Richard Hayes is offline   Reply With Quote
Old 08-29-2012, 12:37 AM   #5
Trailer: 2010 Scamp 16
JB Weld or epoxy to fill hole and re-drill. I love JB Weld for this type of thing, bonds well to fiberglass and as hard as metal. Just mix a little on a piece of cardboard and put around inside of worn screw hole with a tooth pick. If a little flows over the inside of the wall and won't show that will be an even stronger hold.
Wait 24 hrs. drill and re-screw.
You may well find this is a permanent repair. I have filled a stripped bolt hole this way, re-drilled and tapped new threads and it did not fail. Car died a couple years later but that bolt hole was still good.
Might take two applications to totally fill hole but it does not sound like you need that, just something for the screw to grip
Old 08-29-2012, 12:42 AM   #6
Trailer: 1978 Trillium 4500
I concur. Fill the hole with epoxy or bondo glass; then redrill.
I did this on my trillium last month. I used about 3 or 4 toothpicks to fill up the space along with the filler. Once dry, I cut this off flush, then redrilled.
Note: use caution about how deep you drill.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 08-29-2012, 04:46 AM   #7
Raz
Raz's Avatar
Hello Lynne and welcome to the forum. We bought a new Trillium that came with poorly installed hinges (at no extra charge ). Yours will have wood that the door hinge screws go into. Unfortunately, over time it rots. To do a permanent fix you have to remove that wood and replace it with something that will hold the screws. We used metal plates and replaced the screws with bolts. While it looks daunting, it really is not that bad. Since your hinges came from the factory properly aligned, you can use the existing holes. As such you simply need to access the back of the screws and replace the wood. Here's what we did. The pictures of the door frame might be useful. Raz
http://www.fiberglassrv.com/forums/f...air-47624.html
Old 08-29-2012, 08:31 AM   #8
Thank you all, for your advise on fixing the hinge. My husband is using the epoxy and re-insert screws fix for now and will look into a permanent fix later when time permits. If required!)
As novice FG ers, I really appreciate the knowledge and information that is so readily shared on this site.
Lynne
Old 08-29-2012, 11:06 AM   #9
Roy in TO's Avatar
I used the putty Alf describes in this thread and it is still holding fine.
http://www.fiberglassrv.com/forums/f...lem-44504.html
Old 08-29-2012, 12:05 PM   #10
Trailer: scamp 13
my guess,,,having never seen this one,,,is the jb weld type epoxy fix.
though i have enough redneck in me to think duct tape,,,,but thats probably not a good idea.
john warren is offline   Reply With Quote
Old 08-29-2012, 03:55 PM   #11
If your using the duct tape around the bungee hooks that hold the door on to keep them from scratching up the FG why wouldn't it be a good idea?
trillium
Trillium City Water Inlet Woes David Swinnard Plumbing | Systems and Fixtures 32 02-19-2018 05:11 AM
bed woes Hazel in Sk Problem Solving | Owners Helping Owners 24 06-03-2011 02:41 PM
Scamp Converter Woes Adrian W General Chat 15 09-08-2010 09:12 AM
Furnace Woes Joseph Olajos Problem Solving | Owners Helping Owners 5 06-23-2007 03:23 AM
Propane woes Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-05-2002 04:50 PM
