Hi Dale,
You are welcome. Here is a thread that should interest you:
http://www.fiberglassrv.com/forums/f...00s-46068.html
I went to measure the reinforcements on my 1300. Here you go:
Outside reinforcing plate is 1/4" thick and 16" long.
Bottom reinforcing plate is 1/8" thick by 6" long.
Steel angle mounting bracket is 1 1/2" angle 3/16 thick and
about about 1 1/4" long. It is mounted about 6" ahead of the
frame crossmember.
When you remount the body to the frame after the welding
you should renew all the mounting bolts.
Have fun with your project.
Larry H
