Tug Question - Page 2 - Fiberglass RV
Old 03-24-2007, 11:17 AM   #15
Trailer: 13 ft Scamp
I assume this is the reason the Owner's Manual for my 2002 S-10 Extended Cab pick-up includes a warning 'not to be use for a truck bed mounted camper'.
Yea, My 2004 Ford Ranger Edge Manual says the same thing in. Don't use slide in Campers.
dsheets70 is offline   Reply With Quote
Old 03-24-2007, 11:22 AM   #16
Matt O'Bryan's Avatar
Trailer: Eco 12 ft
If the Edge is the model I think it is, probably also has to do with the fiberglass bed.
Not sure I'd trust a composite bed for that purpose.
Matt
Matt O'Bryan is offline   Reply With Quote
Old 03-24-2007, 06:31 PM   #17
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
And later, IIRC, though the concept of a "3/4 ton" toyota makes me nervous.
Matt
Here's one on eBay right now... an '86 Sunrader!
Roger
Old 03-24-2007, 07:46 PM   #18
Brian B-P's Avatar
... though the concept of a "3/4 ton" toyota makes me nervous.
Toyota also had a one-ton version. I can see expecting poor acceleration, but why be nervous? Even my minivan has over half a ton of payload.
I believe many of them were the subject of a lawsuit relating to failed rear axle bearings due to the fact that the axle was over capacity as they were delivered and before adding any "stuff" to the motorhome.
That seems strange to me. The Toyota-based Class C I have looked at had different hubs front and rear, due to the use of a dual-wheel axle different from the standard truck. <strike>Also, this was a cab-and-chassis - to be overloaded without the RV attached, the rear axle capacity would need to be nearly nothing, much less than the single-rear-wheel pickup. I can believe there was a lawsuit, but I think there has also been some exaggeration.</strike>
Okay, I misread Lee's post and had to come back and cross out the above babble...see my later post.
Of course, the motorhomes may have been overloaded. Some seem to have an extraordinary rear weight bias, and I've even seen them with a load deck added on the back.
Old 03-24-2007, 08:06 PM   #19
Trailer: 1991 16 ft Casita Freedom Deluxe
Here's some info on the Toyota axle problems.
Lee Hillsgrove is offline   Reply With Quote
Old 03-24-2007, 08:36 PM   #20
Trailer: Casita 2000 17ft. Liberty
I had one of theses for 9 happy years. Unfortunatly it was the aluninum sided model an it finally started to leak. It a little slow powered but so what? The entire rear axle was paid for by Toyota as a recall. Of course they quit making that design because an American "engineer" sold Toyota on the flaky concept.
jim munson is offline   Reply With Quote
Old 03-24-2007, 09:42 PM   #21
Trailer: Eco 12 ft
Nervous because of a lack of width and wheelbase create instability both directly and indirectly.
Directly, the bigger the footprint, the less it sways. Indirectly, the comprimises needed to shove 7 1/2 pounds of "stuff" into a 5 pound bag create all sorts of handling issues, wheel hop and steer axle instability at the top of the list.
Of course, I'm probably a little skewed, my "3/4 ton" pickup has an actual payload of ~ 3500lbs.
Matt
Old 03-25-2007, 04:36 PM   #22
Pete Dumbleton's Avatar
According to what I've read on various forums over the years, Toyota had to put out a recall on the axles to upgrade them to a full 1/2 ton on dual wheels (I believe the unmodified axles have 4-bolt hubs and the modified have 5) -- Turns out the various camper manfs were buying the platform vehicle from Toyota and them proceeding to overload them (or put them so close to overload that addition of personal/wet stuf was putting them into overload) -- Toyota withdrew from the camper platform supplier market as a result.
Old 03-25-2007, 07:56 PM   #23
Brian B-P's Avatar
Exactly. Half the payload - half the size of truck.
There's nothing wrong with 3/4 ton of bricks or other dense material in a truck this size. The problem with the Toyota-based Class C's (aside from someone apparently messing up the axle spec) is that the load is too bulky for this wheelbase, and probably centred too far back.
I think the fact that in North America we have had the luxury of using ridiculously oversized vehicles has made us forget what is really required to do the job.
Old 03-25-2007, 08:03 PM   #24
Brian B-P's Avatar
Sorry, Lee, I must have been caffeine-deprived yesterday, and I misread your original comment. Of course you were saying that adding the coach (RV body) overloaded the chassis as delivered to the end consumer, even before adding cargo, not that the truck was overloaded as delivered by Toyota before adding the coach. That makes sense.
That link also had some interesting comments on the dual wheels, and difference between what Toyota sold and what the RV makers sold the public. The genuine Toyota one-ton pickups had single rear wheels, and I found it strange that Toyota would let a vehicle out the door with front and rear hubs which did not fit the same spare!
Old 03-26-2007, 05:32 PM   #25
Trailer: Eco 12 ft
Except that under normal conditions, it's the same payload, and twice the truck.
Matt
Question Rob M Forum Admin, News & Announcements 3 10-26-2009 08:51 PM
TV Question Pat M Care and Feeding of Molded Fiberglass Trailers 21 05-04-2008 10:47 PM
Cat Question Ian-Vicki Problem Solving | Owners Helping Owners 13 08-20-2007 10:03 AM
GPS Question Darwin Maring Problem Solving | Owners Helping Owners 10 12-25-2006 12:19 AM
Answer a Question then Ask a Question CarolnJim General Chat 77 06-03-2006 11:39 AM
