TV in Scamp - Page 2 - Fiberglass RV
Old 06-18-2017, 06:46 PM   #15
TV mount
Tom,
Here's the mount I am currently using: https://www.amazon.com/Mount-MI-LCDC...+cabinet&psc=1
It functions fine except it is a pain to put up and take down.
llinderman is offline   Reply With Quote
Old 06-18-2017, 09:46 PM   #16
Trailer: Scamp has Arrived - Layout 7
Sorry Linderman. The mount I referred to is indeed a wall mount. I did install it on the partition and it looks like it will work well for our viewing.
If you do go with an under cabinet mount and you still want to dismount the TV you could try something like this. Many hardware stores have racks of containers with all sorts of nut, bolts, etc. Look for knurled screws with the same thread as the ones used for the VESA mount for your TV. Use the regular mounting screws provided with the mount at the bottom two screw holes but use the knurled screws for the top two holes. Screw the bottom two in just tight enough to allow the TV to be slid out of the large openings at the bottom of the mount, slide the TV into those two holes and then install the knurled screws into the top two holes. Move the TV up or down as required and then tighten the knurled screws.
To remove the TV from the mount, simply unscrew the knurled screws and slide the TV out of the mount. Get a couple of extra knurled screws because eventually you will lose one of them.
Sounds complicated but it should work.
Dan
Dan Jones is offline   Reply With Quote
Old 06-18-2017, 11:57 PM   #17
TomK's Avatar
It looks like the Q-D bracket I suggested would work fine on your mount, Larry.
Thanks for the picture and link for your set-up. That mount you have should work for me in the new trailer. Thanks!
TomK
