Vu Cube - Page 2 - Fiberglass RV
Old 08-11-2009, 07:20 PM   #15
Chester Taje's Avatar
Removes about $500 more of your cash
Just a guess......
More like $700 CDN
Old 08-12-2009, 07:20 PM   #16
theresa p's Avatar
New Brunswick
chester----is this something you are using both at home and while travelling? is it like a free-to-air satellite receiver? and do you need to purchase a montly subscription??
Old 08-12-2009, 07:40 PM   #17
At home we have normal satellite . We take our receiver from home with us when going to camp or traveling. The V Qube is a portable dish. This dish can be used at home or on the road. We pay monthly fees for our programming.Here is some info on these units.
http://www.kingcontrols.com/vu_qube/v10.asp
Old 08-14-2009, 10:46 PM   #18
Joy A's Avatar
Chester,
You need to figure a way to lock that puppy down.
Mine is all locked together and locked to the trailer or chained if put out remote from the trailer.
A friend made the plate with a bracket on the bottom which I attached to the VuQube by removing the legs and then adding the plate and putting the legs back on. The black piece inserted into the bracket is a foot for a awning like people use at Flea Markets. It's inverted. A fence pole fits into the awning foot. A hole is drilled through both with a lock securing them together.
Here's a view where you can see the plate/bracket and foot locked together and locked to the pole.
Here's the pole locked to the trailer chains.
Final product
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 08-16-2009, 04:12 PM   #19
I agree Joy----I was experimenting with what I had. I used it this last few days while i was traveling. I wanted to make sure it worked as planned. I will now make a steel plate so it can be locked.
Just so everyone knows----The VuQube is useless if stolen because they will need a remote. The remote is registered to that particular Vu Qube.
Old 08-19-2009, 03:08 PM   #20
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I like my Vue Qube although I'm not interested in mounting it to the trailer. I went with DirecTV since they had the easiest policy with respect to RV's. The only downside is it's not HD capable. DirecTV requires a special dish type for HD.
I made a little pad out of marine Starboard (UV resistant) that after I find the satellite I stake to the ground. When I pick up the cube because I'm gone for awhile, and then want to set it up again all I have to do is set the feet back in the little pockets to get perfect alignment. Just a little quicker the 2nd and 3rd times I place the qube during a given trip.
I also added a stainless u-bolt bracket to allow me to cable lock it to a tree or the trailer if either is close enough. (I made sure the inside threads didn't interfere with the dish rotating.)
Quando omni flunkus, moritati
Steve L. is online now   Reply With Quote
Old 08-19-2009, 03:11 PM   #21
Steve L.'s Avatar
Since it's only $5 a month for a regular sat receiver, I just went ahead and got another small non-HD receiver for the trailer. Both the home receivers are HD and aren't worth the trouble disconnecting and reconnecting them for a trip.
integral cube heater Legacy Posts Modifications, Alterations and Updates 15 01-14-2003 06:38 PM
