Went to look at a ParkLiner - Page 2 - Fiberglass RV
Click Here to Login
Old 08-06-2013, 10:45 AM   #21
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I hope it doesn't take me a full day, but I don't doubt it might. I'll start early on a Saturday morning and hope to have it done by supper!
On the positive side, I did find out the wire color for the brake light switch - violet with a brown stripe! Everything else is standard stuff.
Frank
Old 08-06-2013, 04:04 PM   #22
Raz
Raz's Avatar
Frank
Take pictures and post what you do and how you do it. Others will be greatful. Raz
Old 08-06-2013, 04:24 PM   #23
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Thumbs up
...It will be the perfect RV for folks like us...
A couple of weeks will mark cari's & my 5th month of camping adventures with our Parkliner... still pinching ourselves each trip. It's a great fit for our style of camping.
Cheers,
Thom
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 08-06-2013, 05:15 PM   #24
Frank, you know you won't be satisfied unless you do it yourself, and I know that you do a perfect job on what you do. Ive had to redo a few "professionaly done" wiring jobs because to make money they were done in a hurry. As for Raz's comment about the wire loom, I use it myself, but have found it can cause a problem. Working on big trucks I have seen many times where the wires or air lines will vibrate inside that currogated loom, and you'll get all little grooves worn into the wire insulation exposing bare wire which then corrodes and breaks.
Old 08-06-2013, 06:12 PM   #25
frank_a's Avatar
Thanks for that Bob! By golly, yer an okay fella!
I'm not looking forward to it, but am planning for it and will do the best I can. I pretty much know where to run the wires, where stuff is I need to hook to, where to mount the controller. What I need to find out now is how to remove interior body panels and replace them with no damage.
After the financial shock of buying this tug, I can't afford the kit right now anyways, but soon. In the meantime, it's figuring out these panels.
But you're right - I'd really rather do it myself.
Take care you two!
Frank
Old 08-06-2013, 07:11 PM   #26
Frank, figuring out the panels can be a problem. Most newer vehicles don't use screws to make it easy for us, usually it's some snap together device, and it's where do I pull or pry to get it apart without breaking something. Good luck with it.
Old 08-06-2013, 07:14 PM   #27
Brian B-P's Avatar
Still on Escape wiring...
The brake controller manufacturers often supply wiring information - such as the colours of the wires at the brake pedal switch for various specific vehicles - as part of their support service.
Old 08-06-2013, 08:21 PM   #28
frank_a's Avatar
Better yet Brian, I called the Ford garage, and also had it verified on an Escape forum I joined. Violet with brown stripe.
As Raz suggests, I will post pics and an explanation when I do it.
Frank
Old 08-07-2013, 07:25 PM   #29
Brian B-P's Avatar
Better yet Brian, I called the Ford garage...
Since dealerships routinely sub out towing equipment installations to hitch shops, I wouldn't count on a Ford dealer having the answer; I'm glad that they did in this case.
Old 08-08-2013, 03:47 AM   #30
frank_a's Avatar
Well, to us, it was a towing equipment install, but to Ford, they need to know what all the wires do in all their vehicles. I knew they would have it somewhere, but no clue where. I would imagine everything is online nowadays, and that's where the 2013 Escape wiring diagram was. Used to be they would get dealer manuals years ago with complete wiring diagrams, and for all I know, they still do. But they had to know. They're the Ford garage!
Went up to my buddy's garage last night to get new tires on the truck I'm selling, and was talking with him about it. He couldn't believe Ford didn't have a plug in 7 pin adapter, or at least the wires taped up under the dash (that's the way my truck came, all the wires to hook in a brake controller taped to the top of the steering column). He's not a fan of tying into factory wiring, but of course, I have no choice in the matter. What was Ford thinking?
Frank
Old 08-08-2013, 09:11 PM   #31
Trailer: '07 Scamp 16' SD
Wisconsin
My wrangler is the same way, it's a pain in the butt
glennco is offline   Reply With Quote
Old 08-09-2013, 03:49 AM   #32
deryk's Avatar
New Jersey
My Rav4 has the tow package but same thing...not wired so I paid a local trailer place to do the install.
deryk
Old 08-09-2013, 04:07 AM   #33
frank_a's Avatar
I'm paying myself to do it. I don't charge much...
Frank
parkliner
How is ParkLiner doing? frank_a Problem Solving | Owners Helping Owners 47 10-17-2013 12:26 PM
WA: Parkliner Thomas G. Referrals: Molded Fiberglass Trailers 19 04-15-2013 09:37 PM
Looking for a Parkliner Jomoflymo General Chat 29 03-02-2013 08:12 PM
Went to see a Parkliner Ruthies Radiola General Chat 3 06-09-2012 06:32 PM
Parkliner, Anyone? GingerB Hi, I am.... 6 04-25-2012 06:56 AM
