What are your best camping tips and tricks? - Page 5 - Fiberglass RV
Old 06-29-2015, 11:49 PM   #57
Gilda's Avatar
Trailer: 2011 Scamp 13'
Those table clips are awesome in that they are adjustable! We often find the campground picnic tables can be 3 or more inches thick! My solution to keep the tablecloth from flying is to hammer 3-4 (1/2") grommets, evenly spaced on each side. Then I connect them by lacing a cord under the table and through the grommets. I'm thinking of using 3-4 bungy cords to connect directly across the grommets but I think it will create too much tension, thereby pulling out the grommets.
The Gleeful Glamper
Gilda (Jill-da)
Old 06-30-2015, 08:16 AM   #58
I'll second the usefulness of baby wipes.
Also, I've developed the habit of doing a 360-degree walk-around before the trailer moves. Inspect tires, wheels, windows, doors (give the latch a twist and a tug), vents, hatch openings, ground under and around the trailer, and, most important, hitch connections.
I do it every single time: when leaving camp, after gas stops and rest stops, any time I leave the driver's seat, even if briefly.
Old 06-30-2015, 01:38 PM   #59
CampyTime's Avatar
Trailer: Scamp 13' Standard
Agreed Jon. There are no shortcuts to safety. I do the same.
Old 06-30-2015, 01:57 PM   #60
Timber Wolf's Avatar
North Florida
Hook cords end to end and wrap all the way around table. Hurricane proof table cloth! Unless the whole table blows away, and then you may have bigger problems than worrying about the pick-a-nick table.
And plus 100 on the walk-around before leaving and every chance you get, inlcuding a glance at the top for secure roof hatches.
Old 07-04-2015, 02:24 PM   #61
I wouldn't call this one of my best ideas, but one of the easiest and quickest.
The one thing that I found annoying with the locking pin on the chain is that it swings while traveling and mars the door finish. To stop that, I put a small magnet on the side of the latch to hold the pin. Problem solved, now just need to clean the marks.
Jim
Scamper Jim is offline   Reply With Quote
Best RV club for low cost camping and where do I find a local camping club? ShawnKK General Chat 28 06-11-2015 01:21 PM
Tips, Tricks & Modifications; or maybe Not! Scamper Jim Modifications, Alterations and Updates 3 01-21-2014 05:38 PM
Bathroom cleaning tricks and secrets? Cheri in MN Care and Feeding of Molded Fiberglass Trailers 18 10-02-2012 07:04 AM
R.V. Tips n Tricks on UTube Doug Mager Care and Feeding of Molded Fiberglass Trailers 4 02-05-2011 05:55 PM
What tricks has your trailer taught you Gina D. General Chat 1 06-25-2008 05:45 PM
