What holds the body to the frame? - Fiberglass RV
Old 10-18-2016, 11:21 PM   #1
Trailer: 1970 Boler
I have a 1970 13' boler and was wondering what the primary fasteners are that hold the body to the frame. I am replacing the floor in mine and have drilled the rivet heads off in the drop down floor area to remove the factory linoleum. My question is are these fasteners necessary to hold the body to the frame.
J-barn is offline   Reply With Quote
Old 10-19-2016, 01:39 AM   #2
If its original there are six bolts ,2 under the back benches, 2 under the front bench,and 1 under the fridge and 1 in the side closet .no those fasteners are not necessary .
Mikmay is offline   Reply With Quote
Old 10-19-2016, 10:55 AM   #3
I would suggest that you do find and pull the actual attaching hardware/bolts and examine them for rust. You'll find lots of posts on this website about this.Mine on our '76 Trillium were rusted mostly through and one was missing all together.
Randy J. is offline   Reply With Quote
Old 10-19-2016, 11:39 AM   #4
Kai in Seattle's Avatar
Yes, find 'em and inspect 'em!
When we drove our '73 amerigo home for the first time, we discovered only six bolts originally held it to the frame...and 4-1/2 of those were rusted away, leaving only the heads inside. the others were almost gone. So--what held it to the frame? 1/8" of old steel and luck.
BEST
Kai
Semper ubi sub ubi.
Old 10-19-2016, 11:46 AM   #5
Trailer: 1970 Boler
I will inspect and replace all steel fasteners. I just wanted to make sure my union was not also relying on those floor rivets. Thanks
Old 10-19-2016, 12:20 PM   #6
Larry C Hanson's Avatar
Bolts...
Old post regarding body/frame bolts...
Trillium Body Mounting Bolts
Larry H
Old 10-19-2016, 12:29 PM   #7
Trailer: 1970 Boler
I found the empty spaces for 1/4" bolts under the front bench, but there does not appear to be anything under the rear benches fastening the body to the frame except a few small machine screws. I climbed underneath and saw no holes for 1/4" bolts anywhere in the frame. I guess I will be adding some today. Weird?
Old 10-19-2016, 02:18 PM   #8
bullfrogeh's Avatar
My '73 Boler was a similar case. Some shell to frame machine-type screws/ (aka 'lag bolts') were missing, others were partially rusted away. I chose to weld a piece of 1 1/2 in. by 1 1/2 in" angle iron to each of the four corners of the frame and then drilled 3/8" holes to accomodate SS bolts, washers and nuts to hold-'er down.
bullfrogeh is offline   Reply With Quote
Old 10-20-2016, 12:02 AM   #9
Trailer: 1970 Boler
After really giving the body/frame union a look over it would appear that on my 1970 there was nothing attaching the two parts except the #10 square drive machine screws and most of those were stripped and loose or very deteriorated from rust. I drilled the four corners of the cabin to accept 1/4"-20 bolts with nuts fastening it to the frame and then upgraded the machine screws to a #12 with a hex head. I also used 1 1/4" washers since most the holes going through the would floor had been hogged out probably from vibrating around the loose rusted screws.
Removing body from frame Bcboler Modifications, Alterations and Updates 12 07-19-2017 04:30 PM
How do I remove the body from the frame? 1971 Trillium 1300 coalminecanary Modifications, Alterations and Updates 26 06-11-2012 10:41 AM
Bolts .... frame to body Roland H Problem Solving | Owners Helping Owners 6 09-11-2010 10:08 AM
Bigfoot body shifted on frame... advice? Bruce & Melissa L Problem Solving | Owners Helping Owners 16 08-17-2009 12:01 PM
Removing scamp body from frame Scott Corsaro Problem Solving | Owners Helping Owners 1 07-20-2008 12:24 AM
» Virginia Campgrounds
