What is the water tank drain for? - Fiberglass RV
Click Here to Login
Old 05-04-2016, 02:14 PM   #1
New Jersey
After patching hundreds of holes from previous owners that obviously didn't know how to do anything right I am trying to eliminate the need to drill new holes myself that don't need to be drilled.
My question is what is the water tank drain for? It is exactly at the same level as the outlet for the pump so why can't you just empty the tank using the pump?
I thought I should also mention the stupidity of one PO that actually drilled holes through the shell to install a paper towel holder!
Bluetang99 is offline   Reply With Quote
Old 05-04-2016, 03:03 PM   #2
So you do not need Voltage to drain the tank.
Old 05-04-2016, 04:14 PM   #3
The water tank drain is exactly what it is called. It drains the tank through gravity. It isn't reliant on having power to run the pump. Just curious why you want to even use the pump to drain the tank. Open the dump valve and you're done.
Old 05-04-2016, 04:22 PM   #4
New Jersey
I was just curious if it was really necessary since turning the faucet on is just as easy.
Old 05-04-2016, 04:23 PM   #5
Dudley's Avatar
Trailer: 1998 Casita 17 SD
Also good if your cooking outside, just use it like an external tap, great for a quick pot of tea I use it a lot.
Old 05-04-2016, 08:01 PM   #6
If your not connected to electrical turning on the faucet will drain power from the battery.
Old 05-05-2016, 08:46 AM   #7
Our 16 ft has the tank drain at the front and the outlet to the pump at the rear.
The tank has a flat bottom, and those outlets are up off the very bottom. So it is impossible to get all the water - or antifreeze - out. You have to tilt the rig down in front to get most of the juice out.
Old 05-05-2016, 08:59 AM   #8
You can do a time-test. Use the pump to clean, drain the tank etc. When it comes time to repair, compare it to a $.50 drain valve.
Old 05-05-2016, 10:00 AM   #9
Paul O.'s Avatar
That would not work on mine. The spigot is inside, under the seat, above the floor.
Also, that short drain pipe catches all the dirt from the road. But, of course, you could clean and sterilize it before each use. Learn from the dairy farmers!
Old 05-05-2016, 07:51 PM   #10
New Jersey
That's how mine is too. I installed a new 12 gallon in my 13 Scamp and it will be pretty tight to install the drain and water pump.
plastic knob to drain water tank rotted again Karalyn Plumbing | Systems and Fixtures 18 05-14-2013 06:21 AM
fresh water tank drain valve? MsRubyLu-Kathy Care and Feeding of Molded Fiberglass Trailers 19 09-29-2012 03:37 PM
Hot Water Tank Drain Tamid Problem Solving | Owners Helping Owners 13 05-17-2011 01:20 PM
Trillium water tank drain John Perry Problem Solving | Owners Helping Owners 5 10-15-2007 08:59 PM
Water tank drain Lee Hillsgrove Problem Solving | Owners Helping Owners 3 07-01-2007 08:41 PM
