What kind of portable gas fire pit to buy? - Page 2 - Fiberglass RV
Click Here to Login
Old 01-30-2011, 07:59 PM   #21
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I know there are places where these are really nice... but it just seems like a waste of natural resources to me. I'd rather have a real campfire if I have one at all.
Scott S. is offline   Reply With Quote
Old 01-30-2011, 08:08 PM   #22
The connection that the Fire Dancer comes with is for a standard propane tank so you should not need ato buy any different connection unless you want to attach the hose to one of the real small throw away propane containers.
Old 01-31-2011, 08:49 PM   #23
Gina D.'s Avatar
I have a Fire Dancer and it gets used frequently. Its perfectly safe under an awning and, as other have mentioned, it is easy to light up in the morning.. no muss, no fuss, no bother.
I run mine in the yard at night when I let my pups out to.. play, yeah, thats it, play. I sit by the fire and keep watch. 5 mins or so, I am done, turn it off and go back inside without worry.
Old 02-10-2011, 09:41 AM   #24
Trailer: Fith Wheel
Alaska
Little red campfire
Originally Posted by Matt in SV View Post
We have one of these and really like it. But the logs are fragile so be careful with them. I think the price has dropped a bit recently. It's great for marshmallows and it does a great job heating a Firstup canopy.
Regards,
Matt
I just bought one and can not get the regulator to keep from freezing up. Anyone else having this problem... With the OPD I just can"t believe it is from overfilling? Runs great for 5-10 min then freezes up and no fire...
berwin is offline   Reply With Quote
Old 02-10-2011, 09:44 AM   #25
Trailer: Fith Wheel
Alaska
I just bought a "Little Red Campfire" and am having a problem with the regulator freezing. At first I thought it was an over filled bottle but then with the OPD tank I am not sure. Has anyone else had this problem? Runs great for about 5-10 min then the hose and regulator frosts up and not fire...
Old 02-10-2011, 10:06 AM   #26
Have you used this tank before ?
It sure sounds like you are bringing liquid to the regulator.
Bill K
Old 02-10-2011, 11:03 AM   #27
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Try wrapping (draping) a towel over/around the reg. That SHOULD help with the freeze up issue.
Old 02-10-2011, 04:19 PM   #28
Matt in SV's Avatar
Trailer: U-Haul VT16
Or, if it wasn't properly purged you may be have moisture in the lines causing the regulator to freeze up.
Regards,
Matt
Planning our next Escape!
Old 02-12-2011, 07:18 PM   #29
Pam Garlow's Avatar
Trailer: U-Haul 1985
The fire dancer comes with a 10ft hose, which isn't quite long enough for where I'd want to place it. Will adding another 5-10 ft of hose affect the performance?
Old 02-20-2011, 11:51 PM   #30
CharlynnT's Avatar
Trailer: Boler 17 ft
That's what I was thinking, too, Scott, but I guess a lot of people must camp where you have to buy wood (which could be green and not burnable, that's happened to us) and or where it is otherwise a big hassle.
We usually camp in non-campgrounds -- wilderness areas we know really close to home or on the way. We bring some seasoned wood in the truck, and pick up kindling by the armload right near the Boler, and use a bit of paper or some parafin firestarter, and volia! Instant fire. Kid was taught how to do a one-match fire age 7 or so.
But we are talking about places where big rocks are close by, along the river or shore, for the fire ring, and loads of dried kindling and chunks of cedar are handy to make a fire.
I guess not everyone has a gravel road to nowhere, but you still want to sit around a flame and watch the fire dance and talk.
CharlynnT is offline   Reply With Quote
Old 02-21-2011, 05:17 AM   #31
From what I understand, Quartsite... and the like... is a good place to use a propane fireplace. Wood is very expensive. Too, once you fire off wood it burns for quite a while. Sometimes you only want/need a fire for 30 minutes or so. Propane would satisfy that need.
Isn't it nice to be able to make personal choices?
Old 02-21-2011, 09:34 AM   #32
We actually do have a lot of gravel roads to no where but over the past few years the fire hazard rating in our province and Washington State has been such that a camp fire ban is in effect for a better part of the summer and often early fall.
Even when there is no ban the price of the wood has gotten pretty high. Suspect they would rather we not burn wood at all due to the enviornmental issues. Here if you build a new home you are not permitted to put a wood burning fire place in it.
What kind of Battery to buy. . . Marine Deep Cycle okay? Maggie S. Electrical | Charging, Systems, Solar and Generators 28 11-17-2011 10:46 PM
Recommend Small Portable Gas BBQ & Elec Htr? Elizabeth TXorMT General Chat 7 02-12-2010 10:50 AM
Fire, Fire Everywhere & No Volunteer Fire Dept Raunie Aasland General Chat 2 11-24-2006 09:05 PM
Washing Machine drum fire pit Taylor Kissinger Modifications, Alterations and Updates 3 03-12-2006 09:45 AM
