what to look for when buying a fiberglass RV? - Fiberglass RV
Old 04-05-2007, 05:47 PM   #1
Trailer: Trillium 13 ft
Hi, I am going to check out a 13" Trillium tomorrow and was wondering what should I be looking for?
any guidance is much appreciated.
I looked at the buyer checklist on the left but it doesn't tell you what to look for.
thnx
Mo
Mo22 is offline   Reply With Quote
Old 04-05-2007, 07:14 PM   #2
Trailer: Trillium 4500
A couple things to look for on Trilliums:
1. Brown(dark) staining and moisture in the storage areas below the seating benches. This brown would indicate leaking around the windows or along the back belly seam. While you are in the benches, there is fiberglass wraped plywood on the floor and should be inspected for rot.
2. Axle condition, there's lots on this subject here but age is probably a good rule of thumb for replacement. If its 20 years old, it will need replacing.
3. Frame condition. Early Trillium frames were prone to cracks in the area where the frame emerges from under the fiberglass body in the front. The solution is a doubler welded on to the frame in this area. Look for the doubler and any cracks. Also inspect the frame for straightness, no visable warpage.
4. Check for door fit and whether the door hinges are loose.
These are just a few of the biggies for Trilliums to supplement the list.
I do have a question for you. Was it your Mom or Dad that named you Mo22?
Good luck, Dave.
David Schroeder is offline   Reply With Quote
Old 04-05-2007, 08:13 PM   #3
Thanks Dave, that's great.
Any drawbacks to buying a fiberglass trailer? Russell, H General Chat 44 07-30-2009 09:26 PM
Buying Assistance bobcaldwell Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:23 AM
Buying T.V. for Trailer Chester Taje General Chat 35 07-30-2007 06:16 PM
Buying a Boler Legacy Posts Problem Solving | Owners Helping Owners 2 05-08-2003 01:35 PM
