Which Trailers Have A Double Shell? - Page 4 - Fiberglass RV
Click Here to Login
Old 05-09-2013, 10:18 PM   #61
George Nagel's Avatar
Trailer: 16' Scamp SD, TV: Tacoma 4cyl
Northern Wisconsin
Condensation / proper ventilation and thermal transmission are two seperate issues.
George Nagel is offline   Reply With Quote
Old 05-09-2013, 10:46 PM   #62
Northern Wisconsin
Francesca, lots of solutions to the dilima, all depending on the construction of the unit. So many varations. i'm not familiar with the construction of these trailers. Maybe just the installation of a couple of computer sized fans for in and out air. A circulation is usually all that is necessary to curb condinsation in any space.
Old 05-09-2013, 11:01 PM   #63
Trailer: Class A Motorhome
Factors and Insulation
I watch the X-Factor AND have owned both a SCAMP 13' and a Lil'Bigfoot 13'. After watching a few episodes of X-Factor from the 3rd season it became apparent that the Bigfoot required less additional heat (at about 35 degrees) than did the SCAMP.
But, what you pointed out was that there could be a 25% reduction in heater operation and that's a good deal for me.
And I haven't got all that many hairs left to split...
Originally Posted by George Nagel View Post
As someone who has worked in a profession that delt with insulation, R factors, U factors, thermal transmission, heat loss/gain and whatnot for 45 years i'd just like to say that most of this is just splitting hairs. The differnce in these small cubic footage campers, with the various insulations and hull thicknesses is the difference between running your heater rhree minutes or four minutes to maintain. Not anything to worry about.
Old 05-09-2013, 11:12 PM   #64
Brian B-P's Avatar
Lower thermal transmission means warmer interior wall surface temperatures, which means less condensation for the same interior temperature and humidity... so they are not so separate. It's the same effect as double-pane windows.
Old 05-09-2013, 11:18 PM   #65
Northern Wisconsin
Gosh Bob, not having ever watched the "X-factor" , I can't really follow. I was just trying to contribute as best I could.
Old 05-09-2013, 11:24 PM   #66
Northern Wisconsin
Brian, good point, but i doubt these campers are insulated well enough to make a huge difference. A little ventilation is necessary I think.
Old 05-10-2013, 02:55 AM   #67
Northern Wisconsin
[QUOTE="George Nagel;386045"]Brian, good point, but i doubt these campers are insulated well enough to make a huge difference. A little ventilation is necessary I think.,considering the vapor barrier provided by the shell. Simply provide fresh air in and the (moist breath) out. The same problem existe in buildings (homes)...1990's ventilation and 2010's insulation and vapor barriers.QUOTE]
Old 05-10-2013, 07:49 PM   #68
BAMA & Pachyderm Posse's Avatar
Trailer: 2006 17 ft Casita
double hull
Originally Posted by Ken C View Post
Snoozy is not a double Hull as described above.
I am not Shure what you meant ? the snooz has an outer shell of fiberglass , and an inter shell of fiberglass and between the two there is a layer of closed cell foam to me that sounds like a double hull I have sample's of snooz hull believe me they are double hull
HERSCHEL AKA BAMA
BAMA & Pachyderm Posse is offline   Reply With Quote
Old 05-10-2013, 07:56 PM   #69
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I had the same initial reaction to Ken's post, Herschel, but decided that he meant that since the O.P. was inquiring about both double hulls and molded in cabinets, the Snoozy didn't answer to the purpose/question posed by the O.P.
Francesca.
Old 05-10-2013, 07:57 PM   #70
IMHO double-hull in the all molded towable means separate molds to make the components. Not an outer hull with components then built in the interior. But truly all parts molded fiberglass that are not removable. More like four molds.. complete molds, not individual fiberglass cabinetry, etc.
Old 05-10-2013, 10:31 PM   #71
X3 as above. Interesting note about the Oliver from their forum
"by technomadia on Thu Nov 05, 2009 2:53 pm
@JuniorBirdMan - That's an interesting consideration. However, when we asked the Oliver folks about what would happen if a leak just happened to occur - they told us that the shells were designed to drain any possible capture of water between them.... "
Old 05-11-2013, 09:35 AM   #72
sounds like a snooz
HERSCHEL AKA BAMA
Old 08-28-2013, 12:44 PM   #73
Good photos posted today of Oliver's double shell, wall, hull, yoke or however you prefer to call it .
https://www.facebook.com/pages/Olive...83250005063478
Double Axle or Not Nordst Hi, I am.... 14 08-30-2012 10:55 AM
Double tow camper1887 Towing, Hitching, Axles and Running Gear 17 07-08-2012 03:13 PM
Double Blowout Ami P Towing, Hitching, Axles and Running Gear 16 04-27-2009 02:38 PM
Mounting an Awning on a Burro (double shell) S Sato Modifications, Alterations and Updates 17 03-05-2006 08:16 PM
Double Axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 26 06-15-2003 01:37 PM
