Which Trailers Have A Double Shell? - Fiberglass RV
Old 04-28-2013, 03:05 PM   #1
Trailer: In the Market
Kansas
Again, I'm not sure what the correct terminology is but I just watched a new Scamp youtube video and they showed how the shell was made at the factory with a single shell. So, now I am realizing why Scamp has the rivets and Eggcamper doesn't, I think. I had thought the cabinets, etc. were molded into the Scamp but I was wrong on that. At this point, I am looking at the smallest of the small trailers so the Eggcamper is a little bigger than I want. I am guessing that Casita is single shell but that Escape and maybe Weiscraft are not. I'm going to do some research on this but wanted to post this in case someone else wasn't paying close attention to the manufacturing processes. I'm just used to stickies!
Cathy P. is offline   Reply With Quote
Old 04-28-2013, 03:08 PM   #2
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
The Escape is a single shell, however it is available with extra insulation. The Oliver is a double shell.
Old 04-28-2013, 03:12 PM   #3
Trailer: 28' Bigfoot Silver Cloud
Woodstock, IL
Burros and UHauls are double shell, too.
Old 04-28-2013, 03:24 PM   #4
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Possibly Cloud, the Burro ancestor, but we're not going see one of those round the corner every 15 minutes.
jack
Old 04-28-2013, 04:10 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
A single shell isn't necessarily an indicator of rivet use. It sounds like you're interested in molded interiors integral to the shell, a process some feel contributes to structural integrity.
Glassing molded cabinets directly to the molded shell, as is done with Trilliums (link), Outbacks ( link), and probably others is one way of achieving that result.
Both Trillium and Outback produce a trailer smaller and lighter than the Eggcamper.
Francesca
Old 04-28-2013, 04:20 PM   #6
Vicki A.'s Avatar
Trailer: 2014 Escape 5.0 TA
Perris Pacer does have a single shell, but cabinets are glassed in.
Vicki A. is offline   Reply With Quote
Old 04-28-2013, 04:23 PM   #7
Oswego, NY
And the Escape uses very few rivets - supports for internal cabinets, etc are molded into the shell. They do use rivets to attach the awning at the shell, and for accessory covers, etc, but not structurally.
Old 04-28-2013, 04:49 PM   #8
I an understand your interest in construction, but I think that the general consensus would be that it doesn't make that big a difference. Unless you are planning to buy a new unit, the first priority is usually finding one, any one, for sale.
FWIW: The 13' Lil' Bigfoot only has a few through the hull fasteners and has lots and lots of insulation.
Is your concern cosmetic or structural?????
Old 04-28-2013, 04:54 PM   #9
Oswego, NY
I can see one big advantage of a double hull - added insulation for cooler summers & warmer winters...
Old 04-29-2013, 05:32 AM   #10
Kansas
My main concern was structural. I watched the video and thought, "That's what I would get for all that money!". The unit looked great and I wanted one immediately until I saw the building process. I do like the look of the molded-in interiors but the deluxe wood that Scamp has is beautiful. I just feel the less things to work loose, the happier I would be. Thank you everyone for your responses.
Old 04-29-2013, 08:34 AM   #11
IllAnnoy
I have a 2004 Custom Deluxe Scamp which is now nine years old and has been towed 60,000+ miles Washington State, Maine, Minnesota,Florida etc. The wood interior is screwed into place, not riveted. Not one screw has yet to work loose, and the structural integrity is rock solid and as good as new. I have owned several trailers of each type of construction, and though they are all better than stick built, I would choose the Scamp Deluxe over any other type. Barring some terrible accident, I expect to leave my Scamp in my will. (if they refuse to bury me in it!)
Old 04-29-2013, 10:42 AM   #12
Have I told you lately how much I love, respect, and admire you, Floyd?
Francesca
Old 04-29-2013, 11:35 AM   #13
Trailer: Gathering Details
Illinois
Take a look at the Lil Snoozy. It is double hull with foam sandwiched between them so very solid. It also has wood interior that looks good.
Romad is offline   Reply With Quote
Old 04-29-2013, 11:50 AM   #14
US
Snoozy is not a double Hull as described above.
Double Axle or Not Nordst Hi, I am.... 14 08-30-2012 10:55 AM
Double tow camper1887 Towing, Hitching, Axles and Running Gear 17 07-08-2012 03:13 PM
Double Blowout Ami P Towing, Hitching, Axles and Running Gear 16 04-27-2009 02:38 PM
Mounting an Awning on a Burro (double shell) S Sato Modifications, Alterations and Updates 17 03-05-2006 08:16 PM
Double Axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 26 06-15-2003 01:37 PM
