Winterizing Scamp 13 single faucet - Fiberglass RV
Old 10-30-2016, 02:18 PM   #1
New Jersey
How much antifreeze do you guys use in your Scamp 13? I only have one line running to my faucet, no bathroom, hot water tanks, etc...
Bluetang99 is offline   Reply With Quote
Old 10-30-2016, 04:42 PM   #2
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Well, our 28' Bigfoot Silver Cloud with kitchen faucet, bathroom faucet, tub, and hand-held shower just took under 2 gallons today. You will probably only need one gallon, but I always have a spare just got in case.
Kevin A is online now   Reply With Quote
Old 10-30-2016, 06:14 PM   #3
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
We have the same rig. One gallon is more than enough.
WDavidG is offline   Reply With Quote
Old 10-30-2016, 06:39 PM   #4
New Jersey
Ok great, seems easy enough.
Old 10-31-2016, 09:23 AM   #5
Why is antifreeze needed? Can't you just drain the tanks?
BS
ravensrest is offline   Reply With Quote
Old 10-31-2016, 09:58 AM   #6
Vermont
BS
Even with draining, some water pockets can remain and do damage -- in traps, low spots in the piping, in the pump itself. You can use compressed air to blow everything out but for me its easier to use the antifreeze and flush the system in the spring. To be clear - use only RV water system anti-freeze, not the automotive variety.
Old 10-31-2016, 10:13 AM   #7
Thanks, David. I understand your response completely. Just for the record, I have never put antifreeze in any of my trailers if I could drain the tanks and lines, the reason being that water generally breaks pipes only when it cannot expand. Frozen water occupies a greater volume than its liquid counterpart, but so long as the freezing water is not confined as in a filled and closed pipe or tank, there is generally no problem.
Your mileage may vary, but that is the way I have always dealt with it and never have had a broken pipe.
BS
Old 10-31-2016, 10:23 AM   #8
BS
Its all has to do with LOCATION.
If I lived in Oregon I could probable get away without using anti freeze in my trailers system many winters just as I can here in Vancouver BC.
BUT all it takes is that one winter when the temps go down to freezing or lower and stay there for a number of days and all bets are off. Particularly in regards to water pumps & shower heads.
Can not tell you how many times I have gone out camping with friends on our first trip in the early spring and had one of them pop out of the trailer declaring they have a water leak at the water pump or the shower head. A water pump left without winterizing properly is more often than not the problem. To properly protect it you need to pump some anti freeze through it or blow air through the whole system as well as disconnect the lines to the pump and directly blow it out.
Old 10-31-2016, 10:25 AM   #9
Vermont
BS
Robert,
Some of us old engineers just can't shed the belts and suspenders redundancy approach to problem solving. The major value of the antifreeze may be for me to sleep better on a cold January night. Seriously, my biggest concern is water trapped in the pump internals with no room for expansion but your positive experience suggests it may be misplaced concern.
Old 10-31-2016, 11:31 AM   #10
New Jersey
Robert,
The pump is the biggest concern for me too. It's a costly replacement so i don't think the $2.50 that I would save on the gallon of antifreeze is worth risking.
Old 10-31-2016, 12:18 PM   #11
I really don't want to beat a moribund horse, especially since I am an old engineer living in Oregon and agree with everything that has been said. But my Scamp 13 (and I think the original poster's) has no pump and no shower head. The single conventional faucet connects only to the city water line. There is a hand pump that connects to the fresh water holding tank via a flexible plastic hose. There is basically nothing to contain water or break once the tanks and faucet/pump are drained.
BS
Old 10-31-2016, 02:05 PM   #12
I peek at the average low temp in Vermont in the winter months vs Oregon would suggest your concern is not at all misplaced ;-)
Old 10-31-2016, 09:51 PM   #13
Illinois
Winterizing
Before I Added an elect. water pump , I simply poured one cup of anti-freeze into the sink trap .
Jimp is offline   Reply With Quote
WANTED: single handle cold faucet jlbails Parts: Buy | Sell | Trade 7 06-11-2016 10:48 AM
looking for single fresh water faucet for 77 Trillium Dennis77 Plumbing | Systems and Fixtures 11 04-17-2015 11:39 PM
Need ideas replacing single faucet in Scamp!! stephbigs Plumbing | Systems and Fixtures 22 07-07-2013 01:43 PM
Single Faucet Randy D. Plumbing | Systems and Fixtures 11 08-06-2011 04:15 PM
Single Handle kitchen bar faucet Sheryl M Problem Solving | Owners Helping Owners 4 05-11-2008 08:56 PM
» Trailer Showcase
little t
Melanie
Taco
Nate R
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
