Yet Another Way To Have a Bad Day Towing - Fiberglass RV
Old 01-21-2008, 06:54 AM   #1
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Quando omni flunkus, moritati
Old 01-21-2008, 07:26 AM   #2
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
That's a good one. Better the trailer upside-down than the car!
Patrick M. is offline   Reply With Quote
Old 01-21-2008, 07:47 AM   #3
Suz
Suz's Avatar
Boy, that sure brings back some memories. Fortunately, we made it home without incident, but many others did not. Whew! We did have a truck and a double axle U-haul, but it was still nerve wracking. We had already been on the road twice as long as it normally takes and we decided to spend the night 60 miles from home. Smart decision.
Suz is offline   Reply With Quote
Old 01-21-2008, 08:48 AM   #4
Joe Z's Avatar
New River AZ
Here's another...... that police officer was very lucky
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 01-21-2008, 09:19 AM   #5
HaroldB's Avatar
Trailer: Casita Spirit Deluxe 2005
Joe
Now that one shows what a sway control is supposed to prevent.
Harold
OUR PERSONALIZED CASITA
HaroldB is offline   Reply With Quote
Old 01-21-2008, 10:27 AM   #6
Harold
If you noticed the windshield wipers were going on the police car. That would mean wet roads possibly quite slick. Aren't you supposed to disconnect the anti-sway bar on slick roads? If the trailer balance is all wrong and had anti-sway connected would this have been the result?
Old 01-21-2008, 12:23 PM   #7
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
Joe
This is a graphic demonstration of an improperly loaded trailer.
John
John Perry is offline   Reply With Quote
Old 01-21-2008, 03:52 PM   #8
Trailer: Fiber Stream
Question
Definitely the instructions are to release the friction of a friction sway control bar during rain and while the roads are still wet after a rain.
Old 01-21-2008, 10:59 PM   #9
Pete Dumbleton's Avatar
My opinion is that even on a dry road with a properly adjusted friction sway the same thing would have happened. That probably waaay too heavy trailer was yanking the tow vehicle all over the road and the driver's corrections may have been making things worse.
Actually, this is the sort of result I envision when someone uses a bandaid friction sway bar to compensate for some fundamental underlying problem with balance or tow geometry and it allows them to be going faster when things start to go wrong...
Old 01-22-2008, 09:16 AM   #10
From my limited knowledge of forces it appears that friction anti-sway bar can cause more harm than help. An anti-sway bar stiffens the side to side movement of the connection between the TV and Trailer. The result of that is when you going into a corner there's a side loading on the trailer tires, hence the warning disconnect the anti-sway on less than Ideal roads. If there's anything causes the trailer to loose traction sideways the trailer is going to attempt to whip the TV. It's difficult to overcome the friction on a side loaded tire, but once the tires start sliding they want to continue sliding. From watching that video several times, I'm not so sure that there wasn't some kind of stiffening of the coupler joint.
Old 01-22-2008, 09:54 AM   #11
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
If a trailer starts swaying DON'T SLOW DOWN, step on the gas, this will straighten out the trailer. I 've towed many cars on a trailer and this worked for me. It's a bit scary to step on the gas when the trailer is swaying but it really works.
Kevin K is online now   Reply With Quote
Old 01-22-2008, 09:59 AM   #12
OR if you have trailer brakes, activate the trailer brakes and NOT the TV brakes.
Old 01-22-2008, 01:46 PM   #13
pjanits's Avatar
Trailer: 17 ft 1986 Burro
And so Byron THAT is the reason to have trailer brakes even if the TV has super duper brakes.
If that trailer get a mind of it's own ,accelerating ( if you can) or activating the trailer brakes is the only answer.
I was in a slide downhill on wet pavement with a U-haul rental so called surge brake trailer. Surge brakes are no good either as far as I am concerned. While sliding downhill toward a stop sign on a off ramp in KY. NOTHING worked. ABS was trying to stop the car but there was no "surge" hence no brakes on the trailer. Give me a brake controller any day, just a tap and it would have been less scary.
Eventually I stopped just past the stop sign but my nerves were shot for the next few hours.
Old 01-22-2008, 02:31 PM   #14
Trailer: 1989 16 ft Casita Freedom Deluxe
SharonNDean is offline   Reply With Quote
New to towing :D JonE Towing, Hitching, Axles and Running Gear 3 07-13-2009 09:05 PM
Towing Legacy Posts Towing, Hitching, Axles and Running Gear 13 07-26-2003 04:43 PM
Towing 101 Legacy Posts Towing, Hitching, Axles and Running Gear 22 05-08-2003 07:44 PM
towing General Chat 0 12-31-1969 07:00 PM
TOWING WITH A S-10 Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
