Your Vehicle Tow Rating. - Fiberglass RV
Old 12-24-2006, 12:33 PM   #1
Chester Taje's Avatar
Good Day All.
On this forum we have discussed many times vehicle tow ratings and the size of the units we are towing.I would like folks to post their vehicle tow ratings and what they are towing.
NOTE--This is not to be used to shoot someone down.
The reason I want to know is that it seems to be that other countries can pull just as much weight and have a much smaller tow vehicles.
I tow my Boler which weights 3500lbs ready to camp with a GMC Sonoma stick shift 4.3 liter motor.
Thank You
Old 12-24-2006, 03:20 PM   #2
CliveAlive's Avatar
Trailer: Boler American #3104
Good day to you Chester;
Still working on the re-fit here and will hopefully do some camping this year!!!
1973 Boler American that is currently a shell, no tanks even, but plan to add 12v/120v Fridge and small A/C. So loaded for camping I plan to stay relatively light and obviously plan to get it weighed. Nevertheless reckoning on coming in with an adequate margin for TV which is a Volvo 240 wagon which per Volvo's specs the 85% limit is 1161 kg. or 2550 lbs.
Might I ask, what do you have that adds up to 3500 lbs? And Happy Holidays BTW.
Old 12-24-2006, 03:45 PM   #3
Lex M's Avatar
Trailer: BIOD Bambi 1980
I would like folks to post their vehical tow ratings and what they are towing.
My Renault, 1335 kg, 1.9 DTI (diesel), 90kW is allowed to tow up to 1650 kg. I tow about 1100 kg.
1 lb = 0.45359237 kg
Happy trails,
RiLex
Travelled NA withBIOD 400TL 1990
Lex M is offline   Reply With Quote
Old 12-24-2006, 03:51 PM   #4
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
#1 Towing a Bigfoot 15B17CB 17' loaded... traveling weight about 3400 lbs with an '06 Kubota BX1850 18hp 3cyl diesel tractor with hydrostatic transmission, turf tires, and a Category 0 "N" three point hitch rated at 800lbs with a RedlandHill Handi-Hitch and no sway control (see avatar at left).
#2 Towing a Bigfoot 15B17CB 17' loaded... traveling weight about 3400 lbs with an '02 Toyota Tundra SR5 Access Cab 3.4l V6 4WD auto trans pickup, tow rating 4800 lbs, bare ball with a friction sway control.
#3 Towing a Bigfoot 25B25RQ 25' rear queen... traveling weight about 5700 lbs with a Y2K Ford Excursion LTD 6.8l V10 4WD auto trans, tow rating 10,000 lbs, with a Reese Dual-Cam with 800 lb bars.
Roger
Old 12-24-2006, 04:11 PM   #5
Gina D.'s Avatar
West Coast USA
Honda Element, rated at 1500 lbs, US. (2.4l, 160hp, auto, 4 banger)
Tows a 1980 Burro 13, last weighed in at 1450. fully loaded. Probably weighs a bit less now.
Soon to be towing with an 06 Jeep Liberty, rated at 5k lbs US.
Old 12-24-2006, 04:12 PM   #6
Hardwood floors-steel bunk beds-full water tanks when boon docking-2x6volt golf cart batteries-Microwave. All these extras over and above original specs add up real fast.
Old 12-24-2006, 04:44 PM   #7
I tow my Casita 17 foot, Spirit Deluxe with a Dodge Ram 1500 - 4.7 motor. Lots of power. Dwain
Dwain T is offline   Reply With Quote
Old 12-24-2006, 04:48 PM   #8
Trailer: Fiber Stream
Talking
I tow a 16' Fiber Stream double axle trailer weighing 2800 pounds loaded; but with empty water tanks...
with a 2003 Honda Odyssey LX minivan, 3.47 Litre engine, 5 speed automatic transmission. Class III receiver, Transmission & Power Steering Coolers, Weight Distribution Hitch with 350# spring arms & friction sway control, prodigy electric brake controller.
Maximum tow rating: 3500 Lbs / 1580 Kgs with 2 Occupants*... 2900 Lbs / 1310 Kgs with 6 Occupants*...
650 Lbs / 295 Kgs with 7 Occupants**...
*including Driver
**Limited to avoid exceeding rear GAWR
Old 12-24-2006, 04:57 PM   #9
jack maloney's Avatar
Trailer: 1986 U-Haul CT13 ft
My 2004 Mazda MPV is rated for 3,000 lbs., my UHaul CT13, fully loaded, comes in at 1585 lbs. Pretty good margin.
jack maloney is offline   Reply With Quote
Old 12-24-2006, 05:09 PM   #10
Pete Dumbleton's Avatar
I tow my (when loaded) 1,700 lb 1991 Scamp 13 with:
OLD 1982 Dodge D150 tow rating 2,000 lbs (marginal)
New 1998 Ranger 4x4/6 tow rating 5,960 lbs (overkill)
Old 12-24-2006, 08:02 PM   #11
Rick's Avatar
Name: Rick, would be a good guess.
Trailer: Bigfoot/Escape.
Had - 1998 Durango - loaded - rated 7400 lbs - towed a 1995 Bigfoot 21 @ 3490 dry.
Have a - 2007 Toyota FJ Cruiser - rated 5000 lbs - looking for an Escape/Casita - rated 2000 lbs dry - who needs more?
Rick is offline   Reply With Quote
Old 12-24-2006, 08:17 PM   #12
Trailer: 2003 Casita 17 ft Spirit Deluxe and 1989 Bigfoot 5th Wheel
Lightbulb
I tow my Casita 17ft SD with the 63 Pontiac Bonneville Convertible 389 v8 automatic with added Trans cooler and added 2700 cfm radiator cooling fan. I also use a single arm equilizer and a anti sway bar.
We also use the 1936 Chevrolet two door sedan 350cu engine 400 turbo transmission
with added cooler and radiator cooling fan.
I don't think that you will find towing capacities for either of my tow vehicles. But we have been from coast to coast and border to border with fiberglass rigs in tow and have had no problems. (Knock on Fiberglass)
Harv in Colo.
Harvey Craft is offline   Reply With Quote
Old 12-24-2006, 08:28 PM   #13
james kent's Avatar
Trailer: Boler 1984
I tow the 13 ft Boler with an extended cab '02 Dodge Dakota 4x4 with a 4.7 v8. Sometimes I think that there's nothing back there. Also towed a 17 ft bowrider and a 70 h moter.
Old 12-25-2006, 05:27 AM   #14
Al & Cindy K's Avatar
02 16' S16 Scamp which hovers around 3,000 lbs in full camping trim. Tow is 05 Tacoma 4WD double cab with TRD pkg plus Reese single arm friction anti-sway bar. Tacoma is rated at 6,500 lbs towing capacity.
Al
Al & Cindy K is offline   Reply With Quote
The dangers of exceeding the towing rating DonDeutsch Jokes, Stories & Tall Tales 1 11-19-2009 09:22 AM
Bunk Bed Weight Rating Trillium 4500 Donna H Problem Solving | Owners Helping Owners 1 09-01-2009 05:35 AM
Wheel rim load rating(s)? Car/truck/trailer Ken Vernon Problem Solving | Owners Helping Owners 1 10-20-2008 02:16 PM
My New (to me!) Tow Vehicle Kenny&Jackie General Chat 12 07-08-2008 07:40 AM
Converter amp rating David & Terry Problem Solving | Owners Helping Owners 16 11-07-2007 04:03 AM
