WY 5th wheel Scamp 1994 $6500 in Wyoming - Fiberglass RV
Old 07-11-2016, 10:34 AM   #1
Trailer: Scamp 5th wheel 1994/Ram 1500 2004 2 wheel drive
South Dakota
WTS: 5th wheel Scamp 1994 $6500 in Wyoming
For sale in Gillette, WY 1994 5th wheel Scamp. Functional but needs some work. The sink and toliet work, the heater works and the refrig works. The water heater is new but is just electric and not gas. What needs repair is the black water elbow leaks where it pushes into the black water tank, it works as a flow thru but is loose and leaks water when the dump valve is shut, the dump valve holds water back. The elbow is loose and may just need to be glued in place, I am unsure that is correct way to fix it or if it justs needs to be tied up with a metal strap like the gray water tank? One of the rear LED taillights quite working on me. The bathroom window outside is missing but was covered by the PO. The kitchen does not have a stove but has a microwave instead. The 5th wheel hitch has been modified by PO so that a 2 wheel drive 1/2 ton pickup can pull it but the Scamp could use a lift kit, otherwise it does not tow level. I towed it 600 miles from Sioux Falls to Gillette without any problems and no sway but it would look better if it was level. The PO also replaced the stairs with storage and extended the bed over where the staris where, he also replaced the wood under the bed with good plywood. I have only used the trailer once and have decided to sell and get a 13 foot Scamp instead, I want something simple to pull, use and mostly as storage for my camping gear. It is currently in Wyoming at my sons place but as time permits I will take it back to Sioux Falls, SD where I live and take it back to the factory and have them repair and upgrade it. Until then I am asking $6500. Clear Title. Thanks for looking.
More photos here at photobucket.
http://s1056.photobucket.com/user/jb...%205th%20wheel
Jamesbucklin is offline   Reply With Quote
Old 07-21-2016, 07:54 PM   #2
mrs
Trailer: In the market
Illinois
5th wheel scamp
Is your 5th wheel Scamp still available?
mrs is offline   Reply With Quote
Old 07-21-2016, 07:58 PM   #3
South Dakota
Yes
Yes, still in Wyoming
Old 07-21-2016, 08:09 PM   #4
mrs
Illinois
Would you give me a phone number or email address so I might talk with you. We are coming to Wyoming. We are leaving Saturday morning to visit relatives there. We have been looking for the 5th wheel version of the Scamper for some time.
Thank you.
Old 07-22-2016, 09:14 AM   #5
South Dakota
Sent pm and email to you with info, contact me anytime.
FL | SOLD 1994 Casita Liberty Deluxe $6500.00 Ben Findsen Classified Archives 20 06-27-2015 12:22 AM
IN | 1994 16ft Scamp Deluxe $6500 adrian Classified Archives 5 04-17-2013 07:37 AM
MI | 1988 Scamp 5th wheel in michigan $6500 S Bradley Classified Archives 3 02-05-2013 02:53 PM
1993 Scamp 5th wheel. $6500 Camilla Referrals: Molded Fiberglass Trailers 1 11-16-2011 07:09 AM
SOLD! 1994 Scamp 5th wheel Standard Nita F. Classified Archives 1 07-21-2006 05:52 AM
