DE Looking at Scamp-what should I beware of? - Fiberglass RV
Old 07-11-2016, 10:04 AM   #1
Trailer: 16 Casita SD 2003
Delaware
Driving quite a distance to look at an 09 Scamp with bath, 13' with front bath. Are there any inherent problems I should look for?
Thanks,
Clamdigger
Clamdiggershucker is offline   Reply With Quote
Old 07-11-2016, 10:42 AM   #2
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
Originally Posted by Clamdiggershucker View Post
Driving quite a distance to look at an 09 Scamp with bath. Are there any inherent problems I should look for?
Thanks,
Clamdigger
Make sure all high ticket items work. Furnace, AC, frig, etc.
Check for old leaks under both rear compartments of the dinette. Look for signs of leaks under galley and from under the trailer.
Read the DOT born on date on the tires. Likely original which means they're past the replacement period. Check age of battery. $90 to replace. Bargaining chips??? Maybe.
Operation of all systems, including awning if equipped. Looks for signs of "cover up" of any leaks by use of excess silicone. Inspect frame for any cracks or rust.
Good luck in your examination!!!
bpfick is offline   Reply With Quote
Old 07-11-2016, 10:44 AM   #3
IllAnnoy
Thanks,
Clamdigger
For a better response, you could say what Scamp you are considering. (13,16, or19) also Standard or Deluxe.
Of course as with any Travel Trailer, you will want to see that each system is in working order.
As with any torsion axle equipped trailer you will want to check for excessive negative camber or inside tire wear.
Check all DOT lighting for safety before heading home.
You might check that the toilet bowl seal will hold water.
Check underneath for damage to plumbing.
(be sure the converter is plugged in!)
Old 07-11-2016, 11:06 AM   #4
Delaware
Where is the converter plugged in. Obviously I know nothing about all of this.
Old 07-11-2016, 09:54 PM   #5
IllAnnoy
it is under the LH (streetside ) bench on the 13, under the rear side dinette seat on models with a side dinette.
Putting the SCAM in Scamp...Beware troy c Classified Archives 2 08-02-2010 06:28 AM
Warning: Beware of large pizza pies Legacy Posts General Chat 18 07-21-2003 01:19 PM
Beware of Two Footitus Virus General Chat 0 12-31-1969 07:00 PM
