1978 Surfside - Page 6 - Fiberglass RV
Old 04-02-2007, 10:14 PM   #71
ericmarlo's Avatar
Trailer: '77 Triple E Surfside
Wow, SurfSide city going on here! Regarding the door - after reading about Boler doors filling with water I gave my door a shake and it had a lovely splashing effect too. I drilled two 1/4 inch holes in the bottom and watched as gallons of water poured out. The door is now much lighter to swing and with the water out it must be much lighter on the hinges. My hinges are also screwy. Our door is also 'warped', it seems to be a characteristic of F/G trailers. I took the lock to a locksmith, who for $10 cut a new key and cleaned/lubricated the lock with graphite. Works like new.
Adam
You drilled holes in your Surfside door and water poured out ? - Wild.
Also, I do not have a key for my Surfside door lock. Do you or anyone else suggest that I remove my lock and get a new key made ? Is it not that hard to do ?
ericmarlo is offline   Reply With Quote
Old 04-03-2007, 06:48 AM   #72
Trailer: Surfside TM14 1978
Yes I highly recommend doing so, it was a lot of water, and water weighs about 10lbs/gallon, it really adds up and stresses things.
I didn't have a key either. If I remember right the lock is held by two phillips screws in the end of the catch plate, and two phillips screws that go from the inside into the outer plate. I removed them, popped the assembly out and into a ziploc bag. The locksmith in town cut two keys for me and cleaned/lubricated the assembly at lunch time in about 10 minutes for about $10. Now it locks, opens, closes, and should a kid lock them selves in, I have a key!
Adam
adamp is offline   Reply With Quote
Old 04-03-2007, 09:34 AM   #73
Chester Taje's Avatar
I drilled hole in the bottom of my Boler Door on my 13 fter.It too was filled with water.I was amazed at how much.
Old 04-03-2007, 11:00 AM   #74
ericmarlo's Avatar
I guess I'll have to try that out.
Here are some pics of my SurfSide.
Old 04-03-2007, 11:48 AM   #75
Shelley's Avatar
Trailer: 1977 Triple E Surfside
Yours looks the same as mine, Eric!
Shelley is offline   Reply With Quote
Old 07-15-2007, 06:44 PM   #76
Wow! Lots of nice SurfSides and good information.
Interesting trivia: Even though the SurfSide was built by Triple-E, it was designed by the same guy that started Beachcomber, also in Winkler, and was based on the Trillium. The marine themed names came from his frequent travels to Clearwater Beach, Florida. There were a few trailer companies in the Winkler/Morden area in the 70's. Odd how many of them were within a 100mi radius of Winnipeg at that time. Most of the owners, although competitors, were friendly with each other and shared materials. When the oil crunch came, whoever was able to get their hands on a barrel of resin shared at least a little bit of it to help keep the other companies running. Not something you'd see in business today.
R Jope is offline   Reply With Quote
Old 09-28-2007, 01:13 PM   #77
ericmarlo's Avatar
Mine is a 76 Surfside - built in Winkler Mantioba.
Made a new door in [b]space under the clothes closet (otherwise space is uneusable). Put new door in the space under the gaucho bench (end near door). [b]Deep cycle battery goes in there along with a very good marine qualtiy charger. Put in a [b]fuse (breaker) panel under the gaucho next to the furnace. Also a [b]propane alarm (just in case).
Alan
Hi Alan,
Hope you had a great summer. My Wife and our Dog, really enjoyed our SurfSide this summer. Now after a summer of camping I have a few questions for you.
I am curious what your post meant about making a new door under the closet area ? Is it possible to explain what you meant by this and or email me a few pictures of what you did?
Also you said you made a new door under the gaucho - I'd love to see that too. Finally, you mentioned you purchased LED lights for the back tail / stop / turn lights. Are you happy with them? Are they brigther and were they easy to install ?
Thanks for now.
Old 09-28-2007, 03:06 PM   #78
Trailer: Triple E Surf Side
Hi Alan,
Thanks for now.
Hi Eric:
We too enjoyed the summer with our large dog. We did Ottawa to PEI and then across NB to the "Boston States". Handy to have a trailer in the states as hotels rarely accept dogs and even campgrounds often will not allow dogs.
About the modifications; I'm not sure if you have the same model but in ours the closet is immediately to the left as you come through the door. The cupboard is positioned immediately above the passenger side wheel arch so the floor of th cupboard is quite high as a result. There is waste space around the wheel arch which I thought we could use. So I cut a hole in th side of the cupboard. The hole goes vertically from just above trailer floor level to just under the level of the floor of the cupboard. The cupboard is framed with 1"X2" framing. Horizontally I cut out all the space between the 1X2 framing. The resulting hole is approximately square. Hinges mount on one side and the friction catch on the other side. Using the Russian plywood described it looks like it was put there by the designers. There isn't a lot of space in there but I keep selected tools and rags and things I will need quick access to in this oddly shaped space that is not good for much else. It is easily accessed from outside the trailer.
On the other side as you come through the door is the gaucho bench which in my model is divided roughly in three parts. The centre section already had a hinged door giving access to a porta-potty. However the left and right thirds were accessible only via a narrow hatch under the gaucho cushion. Made it difficult to use the space as you have to remove the cushion to get into it. Just like on the other side I cut away the the skin (1/8" plywood) in the section nearest the door. Cutting back to the limits of the framing on top, bottom and sides. Then as on the other side I installed a hinged door. I use 1/2 of this space for a 100 amp deep cycle battery and high end marine charger. A bulkhead of thin plywood separates the electrical side from the other side which I use for storage. I replaced all the other doors as well. I didn't like the fake wood grain paper glued to it or the fake embossed plastic frames to make the doors appear thick and heavy. The Russian plywood doors are heavier than those they replace, and I worried about vibration causing them to come loose - especially the large doors and especially on rough road. This has not been a problem.
Then all the brown fake woodgrain walls (cupboard and around the fridge and furnace and everywhere it was found ) had to go. They were painted in an off-white that matched the paint used on the ensolite. Feels bigger and cheerfully bright inside now. The Russian ply doors are finished with colourless varathane that shows their very nice varied grain to good effect and contrast a little with the off-white walls.
I used the same Russian ply to make a shelf all the way from the back side of the cupboard to the rear of the trailer across the back and up to the side of the fridge. It is at the level of the top of the plywood window frames. This shelf has a 5" wall to help things stay in the "shelf/trough" and it works well except sometimes on the roughest of roads. So, I don't put anything up there that would not survive a fall unless I have it really well secured. This shelf is wider where it crosses the back of the trailer than it is on the sides (to avoid bumping the head). It is fastened to the fridge wall and the cupboard wall and the frames of both side windows and the rear window. This shelf is really useful for all kinds of stuff like clothes and towels and the like and over the cooking area ro cooking related stuff.
About the LED lights - they are really bright - almost too bright as some people have pointed out before, but they fit nicely in the same area as the originals although they will not cover both of the holes from the originals. I had to fill one of the holes from the original and drill new holes for the new lights. I think they are great. They look sensible like they are the right size for the space and could be part of the original design. The originals were always dusty/dirty inside and therefore very dim. They burnded bulbs a lot too.
The new ones came from Princess Auto and are a standard item usually in stock. Sometimes on sale for $25/each but usually about $34/each. I believe they are called 7" and they have some funny number of LEDs - like 39 or so.
If I have a chance I'll take some pictures tomorrow and post them in another message. Maybe someone could simply explain how to post pictures and the permissable size.
I hope this is helpful.
Alan
Alan P. is offline   Reply With Quote
Old 09-28-2007, 03:11 PM   #79
Alan
For sizing, etc. Photo Upload Tutorials, How-Tos
To attach to a posting Step by Step ~ Post Pictures help., Simon says, follow these ste
Old 03-08-2009, 09:24 AM   #80
Trailer: Surfside
Alan - love to see some pictures! I have a few windows with stripped cranks and am debating what to do with them. We bought a fixer-upper house in Calgary so have been busy but am looking forward to finishing my re-upholstery of the cushions and tackling so other trailer projects.
Also, someone on the site mentioned ZEP as a cleaner to tackle the outside - anyone seen it in Canada? I've tried Walmart and Superstore but no luck yet....
Where did Jana go - she was working on her Surfside too I believe?
I changed my window cranks it was super easy i think on the bolerama website i found the article, just cut the front of the frame bend it out and pull the old cranks out. I was just going to leave them but im glad i didnt.
kelly p is offline   Reply With Quote
Old 12-13-2015, 09:16 PM   #81
I have one and it shows 1600 lbs gvw that is trailer wet and stuff. dry weight was not listed
MAP 56 is offline   Reply With Quote
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Here's my new Surfside kentj Modifications, Alterations and Updates 5 04-14-2009 12:05 AM
Surfside 1978 tires - where to buy? Mel R Problem Solving | Owners Helping Owners 5 08-06-2008 02:22 PM
Surfside Legacy Posts Modifications, Alterations and Updates 32 02-07-2003 10:45 AM
Surfside 14 tm Legacy Posts Problem Solving | Owners Helping Owners 0 02-01-2003 08:55 PM
