The belly band is one of the major jobs that every
Trillium needs to have done. It stems from how the top and bottom are joined. The two half's were lined up by riveting the belly band to steel plates on the inside of the trailer. For every rivet in the belly band, there is a steel plate. Then they run a strip of fibreglass around the inside. The problem is that, from the outside, under the belly band, there are pockets that the steel plates sit in. These pockets collect water. The water freezes in the winter and expands, making the pocket bigger. At the same time, the presence of water and the different metals of the steel plate and the aluminum rivet creates a reaction resulting in the steel plate corroding and expanding as rust forms. This also causes the pocket to become bigger. Eventually the pocket ruptures into the trailer, and you have a leek.
The solution is to remove the belly band and the steel plates. Then fill the resulting void with fibreglass bondo, sand and
paint. Personally I like the look with no belly band, but some then add an adhesive belly band on top of the repair.
I think that different metals are now used insted of the steel plates in the trailers made today. The same pockets probably exist.
