'75 Trillium, Day 1 - The Clean Up - Fiberglass RV
Old 09-22-2012, 07:48 PM   #1
dylemma's Avatar
Name:	IMG_0119 (800x600).jpg
As we got into it we realized there would be a few questions. I hope to get some feedback here.
Name:	IMG_0120 (800x600).jpg
no cushions came with it so we bought a king elsfjord latex foam matress from Ikea in the clearance section for half price and hope to do the dinette bed and the couch with it. Meatballs were great
Name:	IMG_0124 (800x600).jpg
There are a few spots where the Ensolite has come away and shrunk quite a bit. We will attempt to stretch it back and glue it. Lots of great tips on this forum.
Name:	IMG_0123 (800x600).jpg
Found moisture around the back window and peeled back the Ensolite to find the window frame pretty much rotted out.
Name:	IMG_0135 (800x600).jpg
I think the leak problem may be here. As you can see the top frame piece is missing. Any suggestiones? Would this cause a leak?
More to come......
dylemma is offline   Reply With Quote
Old 09-22-2012, 08:20 PM   #2
dylemma's Avatar
Continued
Just realized I said leak was in back window but it was front
Name:	IMG_0132 (800x600).jpg
ID:	51394Click image for larger version
Name:	IMG_0133 (800x600).jpg
The woden frame pulled right off without removing screws. Most of the screws were corroded away to little stubs. I will use SS screws to replace. any suggestions on type of wood? Does ot make sense to replace with Pressure treated?
Name:	IMG_0128 (800x600).jpg
ID:	51396Click image for larger version
Name:	IMG_0131 (800x600).jpg
Couldn't keep the 3-way fridge lit on propane but it did get nice and cold on 120. Robyne has some ideas to replace front panel. I do have a question though...when I choose the 120 V setting I can't use the gas stove. What am I doing wrong?
I know the stove works when it is set to propane.
Name:	IMG_0129 (800x600).jpg
Lots more to do but ther is light....Click image for larger version
Name:	IMG_0137 (800x600).jpg
at the end of the tunnel
Stay tuned for day 2....replacing window frames
Old 09-22-2012, 09:11 PM   #3
David Tilston's Avatar
Originally Posted by dylemma View Post
Attachment 51391
Attachment 51393
It looks like you took down the front shelf to make putting up the Ensolite easier. Is there a back shelf? What are you going to use for glue on the Ensolite?
I am not sure what top frame piece you mean. Are you talking about the missing window rock guard?
I would say the rot was caused by leaks, and the leaks were caused by rot. Since the wood holds the windows against the fibreglass, the seal was probably lost as the wood no longer held the screws. I think that marine plywood makes sense in this application. I wonder if painting it before installing it would make it last longer.
Old 09-22-2012, 09:19 PM   #4
What model of fridge is that? The model number is usually on the name plate at the bottom of the door frame. You can only see it when the door is open. Keeping it lit on propane may require cleaning out the gas fittings of spider webs.
The stove only working when the fridge is on gas is a bit weird. Pictures of the gas valve on the fridge might help. Maybe trace out the gas lines.
Old 09-25-2012, 06:09 AM   #5
dylemma's Avatar
Hi David,
See my comments below
There are shelves front and back. We removed them for easier access to the ensolite and they were also attached to the rotten window frame.
We found a method we like here on the forum using contact cement to re-attach the ensolite. We hope to tackle that job this weekend.
You were right. The holes are from what's left of the frame for the stone guard. It looks like it was ripped right off with some force. I wonder if they forgot to close it before hitting the road Note to self.......
More to come on this......
Old 09-25-2012, 06:28 AM   #6
dylemma's Avatar
David,
Here is the fridge model number...
Name:	IMG_0149 (600x800).jpg
and the gas valve set to 110V...
Name:	IMG_0140 (800x600).jpg
ID:	51455 Click image for larger version
Name:	IMG_0142 (800x600).jpg
Still not sure how all this stuff works
Old 09-25-2012, 07:14 AM   #7
dylemma's Avatar
Day 2....meanwhile back at the ranch
Replacing the window frames...
ID:	51457Click image for larger version
Name:	IMG_0138 (800x600).jpg
We were able to match the old frame pieces by ripping pressure treated deck boards. perfect fit and should outlive me. We got two full frames for the front and back windows out of two 10' boards.
ID:	51459Click image for larger version
Name:	IMG_0148 (800x600).jpg
Guess what happens when you remove all the old corroded screws and pull off the rotten frame? That's right, the windows come out
Name:	IMG_0145 (800x600).jpg
ID:	51460Click image for larger version
Name:	IMG_0147 (800x600).jpg
Lots of nasty old putty on the window and on the fiberglass. scraped it off with a putty knife and flat head screw driver for the hard to get at spots and them cleaned off what was left with Goo Gone. Seemed to work. You want to have a nice clean surface for the new silicone to adhere to. Load up the track with silicone where the screws go around the window. Don't be stingy. You want to see the stuff oozing out of the screw holes and around the edges as you tighten the new screws. clean off the excess and voilą...
Name:	IMG_0151 (800x600).jpg
Old 09-25-2012, 07:15 AM   #8
Ed Harris's Avatar
I just used standard 3/4" plywood beveled exactly as the original parts were.
Once reinstalled and the window replaced with fresh butyl rubber and held with SS screws there should be no where for rot to start again for some time.
Pressure treated lumber often is heavily chemical treated and I would not want it in there where I sleep and Marine Plywood might be fine but not required unless it is already on hand?
I used 3M spray adhesive for Headliners on the Ensolite but if it has shrunk a lot that may be enough.
I remade all doors inside with Birch Plywood just Poly'd clear and you can get a 1/8" panel to slide right into the front of the fridge too.
Looks Good
Ed
Old 09-25-2012, 07:17 AM   #9
Ed Harris's Avatar
We must have posted at the same time!
In my experience Silicone Caulk will not stick well to fiberglass and it is pretty much suggested to use a Butyl Rubber tape to seal the windows, but I guess we will see?
Old 09-25-2012, 07:48 AM   #10
dylemma's Avatar
I am hoping that the pressure from 25 or 30 screws against the fiberglass will keep the seal. Fingers crossed.
Old 09-25-2012, 07:53 AM   #11
dylemma's Avatar
Actually there are over 40 screws around the frame
Old 09-25-2012, 08:17 AM   #12
dylemma's Avatar
Name:	IMG_0139 (800x600).jpg
My new tow vehicle. Don't wait up.
Old 09-25-2012, 08:54 AM   #13
It is a bit of a dark art. Understanding absorption refrigeration is on my bucket list. All you really need to understand is that heating the section of vertical pipe that the burner is under makes it all go. The heat comes from either a flame, or electric heating element. If it works on any heat source, then it is good. So if you plug it in, and it cools, then even if you don't get flame, you can fix it. If the cooling circuit has lost gas, it is not worth fixing.
Your RM24 is very much like an RM211. All the controls are on the back, and they look just like an RM211. Check the document center. There may be a manual for your fridge there.
Old 09-25-2012, 09:25 AM   #14
Raz
Raz's Avatar
Vermont
Hi Dave and thanks for sharing your project with us. I would suggest you do a little reading using the search feature on the use of silicone. Folks have not had good luck. Butyl tape seems to be the better approach. Just a thought, take care, Raz
trillium
Remembrance Day/Veterans Day Chester Taje General Chat 7 11-11-2010 11:09 PM
Clean up in aisle 3 Mark Shaffer Jokes, Stories & Tall Tales 2 08-10-2010 12:52 PM
How clean is clean? Liz&Kev Care and Feeding of Molded Fiberglass Trailers 13 06-12-2009 06:41 AM
Useless Trillium fact of the day Daniel V. Care and Feeding of Molded Fiberglass Trailers 14 05-05-2008 03:06 PM
