'86 Cadet - Page 3 - Fiberglass RV
Old 06-29-2006, 02:01 PM   #29
Lizbeth's Avatar
Andrew I love those Weferlingen! Too bad I can't read the website.
Old 06-29-2006, 03:49 PM   #30
Trailer:
If you enter the site URL into Babelfish*, you'll get a 'sort of' translation - when you can't understand what the translation is supposed to mean, you'll at least get a laugh from it. For example, Babelfish reckons the LC9 page on the Weferlinger web site says:
"The LC9 - 200 only a Oldie - caravan is not simple, no it is a cult object. At that time it was the only camper, which could be pulled with the satellite."
The problem here is that the name of the Trabant car translates as satellite - but equally it amuses me to think of taking your satellite into U-haul and telling them you want a Class 1 receiver fitted......
Andrew
*I find that Babelfish is better as staying in translation when clicking links, but Google do offer a translation service too.
Old 06-29-2006, 05:09 PM   #31
Brian B-P's Avatar
Okay, a Smart fortwo is too small for just about any travel trailer which is one can actually walk in, but if the Weferlinger is the trailer, maybe everything's in scale...
While the Weferlinger is a stickie, I noticed two things about this trailer (from the LC9-200 page) which seem relevant to our trailers:
  • this trailer uses another form of suspension with rubber springs (gummiferderblocke), but not pivoting arms embedded in rubber like the common "rubber torsion" design - is this another option for the customizer, and does it have any advantage?
  • this is substantially smaller than a typical 13' egg, yet looks usable, by using a one-sided dinette approach - is it? How does it compare to the dimension of the more conventionally arranged Cadet, Compact Jr., or Miti Lite, for instance?
The rubber-block suspension element looks like one block of the designs with stacked rubber and steel plates which I have seen used on trucks (especially concrete mixers): they are loaded in shear, so travel of the suspension slides one plate past the other, distorting the the rubber, while motion in the other directions is also controlled by the rubber block.
Guess at Translation of Specifications from L9-200 page:
  • Type code = HP 300.83/1
  • panel body length = 2000 mm
  • Overall length = 2830 mm
  • Total width = 1640 mm
  • Overall height (measured of the ground) = 2000 mm
  • Interior height = 1800 mm ("standing being located in the closed car")
  • Couch surface 1950 x 1120 mm (folded out as bed, I assume)
  • empty mass = approx. 250 kg
  • total mass with cargo = max. 280 kg
  • tyre size = 3.50-12 ("Berlin scooter")
  • towing vehicle requirement = minimum 500cc engine (Trabant, etc)
Unless I have misinterpreted something, that's a loaded complete trailer with cargo not to exceed 280 kg, or about 616 pounds. Makes my B1700 sound enormous! The Cadet seems merely large by comparison.
Old 06-30-2006, 10:04 AM   #32
Trailer:
This is substantially smaller than a typical 13' egg, yet [b]looks usable, by using a one-sided dinette approach - is it? How does it compare to the dimension of the more conventionally arranged Cadet, Compact Jr., or Miti Lite, for instance?
Hey, that's like a red rag to a bull for a man like me with trailer plans everywhere, so here is a selection. The Compact is my redesign to be made in wood and it may be a little narrower than the original Compact - otherwise I believe these are all accurately dimensioned. You can see how much smaller the Weferlinger is!
Andrew
Old 06-30-2006, 10:42 AM   #33
Brian B-P's Avatar
Hey, that's like a red rag to a bull for a man like me with trailer plans everywhere, so here is a selection...
Excellent Andrew, thanks! Is there a complete set of your plans available?
The Weferlinger gives up one side of the dinette to save width, and with the "cooker" (no sink?) and closet opposite, it can then have a body which is just bed-length.
The Cadet, on the other hand, is quite "traditional" in layout, and seems to be smaller only by squaring off the corners and keeping everything just barely big enough. While the "egg-shaped" appearance of the classic moulded fiberglass trailer may be aesthetically appealing, I think this comparison shows why it is not particularly efficient in its use of space. I find the rounded ends and bulging sides of my Boler B1700 frustrating, because they restrict useful space and add width without much benefit.
Old 08-22-2014, 05:03 PM   #34
Trailer: Currently Shopping
Massachusetts
Right click on your mouse. The menu will include "Translate to English". Click that and you should get a fairly good translation of the whole page.
KSD76R is offline   Reply With Quote
cadet
Cadet Owners Len Cater Care and Feeding of Molded Fiberglass Trailers 21 11-30-2010 10:00 PM
Cadet? Donnie Campbell Problem Solving | Owners Helping Owners 9 05-28-2009 05:49 PM
Cadet jerry p Wanted: Molded Fiberglass Travel Trailers 0 09-22-2008 08:28 PM
New to Us Cadet DonInChatt General Chat 25 01-30-2007 10:23 PM
1987 Cadet 13' Kanata1 General Chat 24 07-18-2006 11:03 AM
