Originally Posted by camper1887
The 15x22 is listed on their website you can still purchase it. Mine is not in need of the 15x22 looks like it is the 17x24 Jensen with a piano hinge.
Yep, it was listed on the website when I went to order it. I'm pretty sure I heard the guy correctly that it was no longer available (or possibly that they didn't use that size anymore??). Since I knew I was gonna hafta either do some cutting or some kind of heavy 'prying' along with considerable cussin' in order to get the stainless sheet off, I just agreed & took the 18x25. Had thought I'd install a Fantastic Fan Vent in place of the original roof vent but that would've entailed considerable modding & 'fairing' of the old opening to add
fiberglass for the correct sized opening. I'm gettin' too doggone old to be standing on a 7' ladder (or any other height
) & leaning over the trailer trying to 'build up' enough 'body glass' to accept & hold the 14x14 FF. Much easier to measure (twice
), mark, & then use the multi tool to enlarge the existing opening for the new vent size. If I drill the correct holes & install the new inside framing/trim, installing the new size vent should be just a matter of placing the butyl taped vent & driving the stainless screws thru the
fiberglass roof into the framing, after dipping/coating each screw with lexel or other non silicone sealer of course
