A/C temp drop - Fiberglass RV
Old 08-15-2013, 11:00 PM   #1
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
A/C temp drop
Does anybody know the average temp drop of an rv a/c? I believe mine is still the original from '84, wondering if it needs to be charged, or if its as good as it gets.
Old 08-16-2013, 07:20 AM   #2
I know the temp drop figures for my home a/c & my TV's a/c, but not that on RV's. I'd bet it's available in a Google search though.
That said:
The bad news.... Hope it doesn't need recharging, this isn't like adding a freon shot to your TV's underhood system
Most RV a/c units were not designed to be recharged and don't have the necessary fittings to do so. This means that it has to come off the roof, new fittings soldered in, the unit recharged and then reinstalled. When a member of another site I am on had this done the bill was close to $400. And remember, everything else in the a/c unit, fan motor, electronics, relays etc, is still 30 years old.
The good news: For not much more you can buy a new unit and ferget about it for another 30 years (maybe...)
And, as an alternative: After 30 some years the evaporator and condenser may just be covered with oxidation and general crud and may respond to a good cleaning. There are special sprays available through a/c supply sources that do a fair job of this.
And Kansas in August without A/C??? Ouch.....
Old 08-16-2013, 08:25 AM   #3
cpaharley2008's Avatar
I was always told about 20 degree differential from outside, but more importantly dehumidification makes that difference feel even better.
Jim
Never in doubt, often wrong
Old 08-16-2013, 08:58 AM   #4
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Camping in July the inside temp of my Casita 17' was at 105 degrees. Turned on the AC and in about 1 HR the temp was down to 68 degrees. We had Ice cream and strawberries in the trailer and had to go outside to warm up.
Old 08-16-2013, 09:27 AM   #5
A/C temp differential
I think that you will want at least 20 degrees difference between the inside temp of the R/V and the output of the A/C unit.
That's the way house units are measured, Air supply vs. air return temp.
If it was 100 degrees outside, an outlet temp of 80 wouldn't be enough to cool your RV.
Old 08-16-2013, 10:27 AM   #6
Jared J's Avatar
Kansas
It could need cleaned, I haven't taken the cover off. It works, but not as well as I would like, I have t measure the temp drop yet. I might be wanting too much out of an ac from '84, though.
Electric water heater temp adjustment glennco Problem Solving | Owners Helping Owners 6 05-15-2013 07:23 PM
'84 Burro 13' temp floor repair TomZ Modifications, Alterations and Updates 0 03-02-2013 05:03 PM
What TEMP (High and Low) stops you from camping? Kevin K General Chat 29 09-19-2011 02:21 PM
Frig. Temp. Kevin K Problem Solving | Owners Helping Owners 5 08-22-2008 05:08 PM
Expected hi temp tomorrow... Doug Mager General Chat 14 04-13-2008 08:35 AM
