About ST Tires - Fiberglass RV
Old 11-03-2013, 12:13 PM   #1
Trailer: Class A Motorhome
About ST Tires
Moderator: Should this be made into a sticky?
Here's a fairly decent looking explanation about ST tires:
http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rjt
Old 11-03-2013, 12:57 PM   #2
honda03842's Avatar
Name: Norm and Ginny
Thanks Bob. Many could pick up a lot from this. Part of being careful, knowing that heat is a tire destroyer, we try to start and and our travels before the heat of the day.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-03-2013, 05:46 PM   #3
TomB44's Avatar
Trailer: Casita Spirit Delux
Virginia
Bob...thanks for the information. We purchased our Casita three years ago , used, and the tires still appear to be in good condition. I'm not sure when the tires we're put on the trailer. I'm assuming about one year before we purchased it. If that is the chase then my tires are four years old and I plane to replace then before the start of next camping season. The information you provided is very useful, leaving only two questions. What brand of tires meats all the standards required? Which brand is the best? Thanks TomB
TomB44 is offline   Reply With Quote
Old 11-03-2013, 11:05 PM   #4
Very Good. Thanks for posting this.
It appears that Carlisle has stated information in a much more clear manner. I noted that ST tire pressures are listed on sized vs maximum load as a pressure rather than a chart of pressures. I also noticed that they state clearly "Maintain tire pressure at the maximum PSI recommended on the sidewall"
Guess I'll have to look at Goodyear and see if they clearified things bit.
Old 11-04-2013, 06:23 AM   #5
MC1
MC1's Avatar
In my earlier days I worked for two major tire companies. By far we had a much higher failure/return rate with the ST tires than P or truck tires.
Wondering if folks followed the tire care guidelines as outlined in the article if the tires would stand up better???
Old 11-04-2013, 07:00 AM   #6
Roy in TO's Avatar
Although we've seen this article before, I'm still confused by the LT designation on trailer tires.
I quote:
An "LT" designation, when shown on a trailer tire size specifies load
range only, it is not designed for use on light trucks.
and
ST tires are branded with a load range (LRB, LRC, LRD, LRE and LRF)
on the sidewall, listing load range letters in the sidewall description.
For example, ST205/75R15LRD.
Can anybody explain this further?
Old 11-04-2013, 07:48 AM   #7
Steve L.'s Avatar
Roy, I'm reading the statement as saying if there is also an LT in a trailer tire's size designation it means load range. I've searched Tire and Rim and ETRTO (European) standards and can't find any precedent. Maybe it's in the Japan code but I can't find them at the moment.
Old 11-04-2013, 10:32 AM   #8
Its been explained to me by more than a few tire shops that its due to the usage of the tire not the tire itself.
ST tires are mounted on trailers that are often parked for long periods of time either in the hot sun (Ultraviolet rays weakens the rubber) or parted in a wet environment (rot from the inside).
Truck tires mounted on trucks which are normally used far more frequently avoiding the above issues.
Old 11-04-2013, 12:11 PM   #9
I believe it's mentioned someplace else on the Carlise Web site. There's some tire charts with tire size numbers. I think I saw LT in there.
Old 11-04-2013, 12:14 PM   #10
Vehicle tires will have the tread worn and will be replaced usually in less than 5 years. Trailer tires will show little if any tread wear in the same length of time. I replaced mine after 5 years and they looked new. Too many people judge the health of a tire by the amount of tread left.
Old 11-04-2013, 12:49 PM   #11
Bobbie Mayer's Avatar
Okay, I just went out and wrote down numbers from my tires. I've never been able to figure out this age thing and I still can't. These tires were installed in 2007- that I know for a fact. I don't remember having to replace any of them though I did have a leak repaired so it is possible I'm forgetting doing that.
I can find two four digit numbers. 3209E (after DOT X20B) and 232 1 after HF (or HP.)
Which, if either of these, is related to tire age?
Old 11-04-2013, 12:50 PM   #12
Goodyear Marathon have a 6 year limited warranty. Replacing at five years might be premature.
Old 11-04-2013, 01:23 PM   #13
Steve L.'s Avatar
Originally Posted by Bobbie Mayer View Post
...Which, if either of these, is related to tire age?
The last 4 numbers of the string that follows DOT. WWYY (WW =week of the YY =the year. 1307= thirteenth week of 2007.
Or in the picture: 42nd week of 2002
Old 11-04-2013, 01:46 PM   #14
So maybe I did replace that one tire. I guess I need to check the other one to see how old it is. Has to be at least 07.
Old 11-04-2013, 02:01 PM   #15
Roy in TO's Avatar
Thanks Steve,
I looked at the Carlisle tires on my boler. Here is some of the info on them if it helps.
145R12C 87/85L
Replaces 145R12LT Extra Load
Load Range D
Radial Tubeless
Replaces 8 Ply Rating
For Trailer Use Only
AQO3 Dot AQCC 0908
Sidewall 2 polyester
Tread 2 polyester + 2 steel
Max Load
555 Kg / 1220 Lbs single
525 Kg / 1155 Lbs dual
65 PSI cold
On edit: Also says Radial ST in big bold letters
Old 11-04-2013, 02:33 PM   #16
frank_a's Avatar
Trailer: 2012 ParkLiner #006
All I run on any trailers I have is radial trailer tires. The difference from bias belted is amazing!
Frank
2012 ParkLiner #006
Old 11-04-2013, 03:17 PM   #17
The other side also says 09. Doesn't make sense as I put them on when I got the trailer and I sure don't remember replacing two of them other than when I first put them on. I'll check with Les Schwab as they did it and they keep it in the computer- if they ARE 09 I'll leave them on.
Old 11-04-2013, 04:01 PM   #18
Marathon Quality ???
1. A 6 year warranty won't be much better than a 3 year warranty if, after 70 months a tire fails in the boondocks and the only replacement you can find is a Schnitzu Uberroader tire, that's made in Uszberkonia. (Yoz-ber-konia).
Goodyear knows that there is almost no chance of someone owning the same trailer for 6 years, warrantees are seldom transferable, and pro-rated warrantees are almost always based on full MSRP.
2. The Marathon tire family has not had that good a following as to quality, with lots of reported tire failures.
Google Goodyear Marathon quality and read up first
My apologies to any Uszberkonians I may have offended.
Old 11-04-2013, 04:04 PM   #19
The web will soon have you replacing your trailer tires every year.
Much of the Marathon web mania was unwarranted.
There. I just added to the wealth of web knowledge.
Old 11-04-2013, 04:57 PM   #20
Originally Posted by Bob Miller View Post
1. A 6 year warranty won't be much better than a 3 year warranty if, after 70 months a tire fails in the boondocks and the only replacement you can find is a Schnitzu Uberroader tire, that's made in Uszberkonia. (Yoz-ber-konia)..
Can attest to that! The options on tires in Needles California I discovered isnt all that great! Funny part was I ended up with a brand of tire I had never heard of but while attending the NOG spring meet this year another member looking at my tires and indicated they had the same tires - guess how they ended up with them & where from! LOL We had a good laugh over it.
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 28 09-01-2023 12:35 PM
Trailer tires or car tires? serious sam Problem Solving | Owners Helping Owners 4 05-15-2011 10:13 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
tires Don Meyer Problem Solving | Owners Helping Owners 7 06-18-2006 08:23 PM
