07-09-2012, 06:15 AM
Trailer: 2011 Trillium 1500 & 2002 Airstream 34
Air Conditioning...
Fellow Egg'ers : As we've had a huge amount of heat this summer, and since not all of us have late model trailers with an air conditioner mounted on the roof, I have a question...
" How have you set up air conditioning for your egg" ??
Pictures please !!!
Cheers, P.
07-09-2012, 09:13 AM
Trailer: Compact Jr 1972
Greetings Paul,
I mount mine in the window...when I have AC power and the temperatures warrant. Otherwise it stays at home.
07-09-2012, 11:34 AM
Trailer: 2010 Scamp 16
This would be great to have the ideas all in one thread. Have seen pictures of so many AC mounts in different threads. In closet, under kit counter, through rear wall under the dining table, and front wall under custom front dinette for two. Plus a bunch of different window approaches. Hope all those people post a response.
No AC, can live without it but..... at 100 degrees I'm going to be out the $ for a motel so it is something I have considered at least a little.
07-09-2012, 11:37 AM
Trailer: 2007 Eggcamper & Homemade Tear Drop
I am working on one like this fro my U-haul. I will post picks when I get it finished.
07-09-2012, 11:41 AM
My trailer has wheels on it. This allows it to be towed to where the temperature suits me. A whole lot less fuss and bother plus not having to worry about the dreaded "hookup" pole.
07-09-2012, 05:15 PM
Trailer: 13' 2012 Scamp
Wisconsin
Bought a Frigidaire $110 window unit 5000 btu unit on Friday over lunch - Sears still had them in stock since I guess nobody ever shops there anymore.
Tossed in the back sliding screen window of the Scamp right after work and used it Friday night in 100 degree temps. Worked great. Didn't need it Saturday night and loved that it takes 3-4 minutes to install and remove (vs. the heavy roof mounted, expensive, hard to repair, prone to leaks over time unit - at least from my perspective where in most summers I may only need it 2 or 3 times).
07-09-2012, 05:27 PM
Trailer: 2010 Scamp 5th Wheel/2019 Toyota Tundra
Iowa
I stick a fan on him.
07-09-2012, 05:36 PM
Trailer: 2001 Scamp 13'
Did you use the standard included window hardware and with no additional supports? 3 to 4 min minutes sounds way too easy. But I overcomplicate everything and take way too long to get anything done.
07-09-2012, 06:46 PM
This was our solution...
Ingredients...
A small portable air conditioner (we bought ours @ Can Tire)
Two 6" marine "deck plate" ports
The pictures will follow...
P.
07-09-2012, 07:00 PM
Wisconsin
I should have taken a picture when it was mounted (next time). I bought the AC-80 support bracket from the home improvement store:
Amazon.com: Air Conditioning Window Unit Light Duty Support Bracket - up to 80 Pounds: Home & Kitchen
and a small bag of the black foam pipe insulation. A couple of SS bolts with locking nuts to have the "lip" of the bracket held on (the default install assumes you are screwing the lip into the window sill). I lined the window opening with the pipe insulation split lengthwise, slap the AC unit onto the bracket (which is nicely adjustable with a level for the proper tilt back for drainage). Once you have the bracket setup for the proper tilt, that never varies again so you don't have to ever mess with it again - it just folds down nicely for storage when you remove it. I cut a few pieces of 1x4" and that fits in the top "rail" of the unit on the inside and mates with some 6" threaded bolts with wing nuts onto the same size piece on the outside of the camper. Then I just wedge a few pieces of pipe insulation in anything else I can see through.
The 5000 btu units are overkill for the 13' scamps so the thing doesn't need to be air tight. I guess if I wanted it to survive the occasional rain storm without a leak I'd be more picky following a few of the really nice fabricated setups others have posted.
The Frigidaire FRA052XT7 works great and is cheap enough that's for sure. And I found it much more quiet than I expected it to be.
I assumed I needed to mess around with bumper pole support sticks and stuff, but honestly the unit is just not that heavy and the bracket transfers a lot of the weight to the area down near the belly band which seems plenty strong enough. I don't need to drive around with it mounted so not worried about that sort of stress.
07-09-2012, 07:04 PM
Here are the pictures of my "after market" solution to the problem of getting air conditioning into our Trillium...
Although we can't leave the portable air conditioner in the Trillium when we travel, this works perfectly & it can be almost totally hidden when not in use by simply replacing the screw in caps into the inside & outside ports.
P.
07-09-2012, 08:28 PM
I could totally use one of those "6" marine "deck plate" ports" for an air intake on my AC install.
Got a link to a good source?
07-09-2012, 10:55 PM
I'll get mine into my closet eventually, but temporary options may be useful until I'm ready to cut another a big hole in my Scamp.
07-10-2012, 07:10 AM
Dylan : Those "Deck Plates" are sold at "West Marine" stores & most every boat stuff stores...they're a very common item, although the 6" ones may have to be a special order at some smaller marine stores.
Cheers, P.
07-10-2012, 08:58 AM
Trailer: 85 Uhaul CT 13
Being new to FGRV this is my 1st post. After much reading on the subject I decided to install my $99/5K BTU unit under the front bunk. Knowing that 2 things are needed to operate properly, a fresh air intake and a hot air exhaust, I used 2 marine deck ports purchased at the local Bass Pro to serve these purposes. Then using insulation board and metal duct tape I created a chute to funnel the exhaust air outside via the front deck port; "works great". On very hot days maybe use a small fan to help circulate air. Have pictures and will post as soon as I firgure out how?
07-10-2012, 02:48 PM
Trailer: 1971 Boler 13 ft
I, like many others, decided to go with a small 5K BTU window unit. I wanted to have it permanently mounted and not lose any window openings so I decided to use some closet space.
I know Scamp and some other manufacturers have used a low mount in the past but I was worried about convection working against me and ending up with a sweaty brow and cold feet so I decided to mount at the top of the closet.
One advantage of the low mount is the ability to create a fresh air intake through the floor (without losing more closet space to a duct coming up from the floor). I decided to do some work to the back of my unit to divert the hot air out the top vent I had added while the cold air would come in via the bottom vent.
Russ
07-10-2012, 03:08 PM
I imagine that helps with that whole pesky heat rising thing. Looks good - I imagine the higher AC, the better it will operate.
Steve
07-10-2012, 10:28 PM
Cheers, P.
Thanks, I'll check around.
07-10-2012, 10:32 PM
Attachment 48821Attachment 48825
Attachment 48823Attachment 48824
Russ
Great reference photos!
How do you feel getting the cool air intake so close to the hot air out is working? I've considered that sort of install.
At the moment I'm considering getting cool air from the rear dinnette seat and putting in a vent like that "deck plate" that I can seal or open depending on AC use. Smaller vent/hatch on the side for just the hot air out. But, I'm still open to considering all configurations. I just don't see a great way to get air from below in the bottom of the closet. Pesky wheel well.
