All Bleach is Not the Same - Fiberglass RV
Old 08-30-2016, 09:21 PM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hi Friends,
Just passing along something I learned today. I went to sanitize my water lines today with the Clorox I had which was a scented version.
It says on label that it will not sanitize or disinfect, that regular bleach must be used. I had no idea, as I used it this spring to sanitize. Guess I never did!
So I googled it and apparently regular bleach is 5% solution of sodium hypochlorite while scented varieties are only 2.75%
Just passing along to try and help others avoid my blunders. I would have never thought so, and was a good thing I felt possesed to read the label today.
Cheers,
Wendy
Sent from my VS985 4G using Fiberglass RV mobile app
Old 08-30-2016, 10:16 PM   #2
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
It probably can't be strong enough to disinfect or it would kill the fragrance chemicals, too. But what good is it if it doesn't disinfect?
Old 08-30-2016, 10:55 PM   #3
They claim it does a good job of getting out stains in clothing without damaging colours & makes them smell nice and fresh ..... or something like that.
Clorox does make a regular bleach that does disinfect though.
Old 08-31-2016, 06:33 AM   #4
CampyTime's Avatar
Right. That's what I went out and purchased! Live and learn.
Old 08-31-2016, 08:10 AM   #5
None
While I'm thinking that, given enough time, the less concentrated would eventually disinfect, I think they probably don't want the liability of having folks use it for that when so many sources give the instructions based on a 5% solution. They are mostly attempting to not muddy the waters, so to speak.
At least that would be my contention. A 2.75% solution is still stronger than a 5% solution mixed at a 1:10 ratio of bleach to water which is the conventional dilution suggested.
Anyway, regardless of the above, my bigger concern would be adding the additional "scent" chemicals into my water supply - I wouldn't be comfortable with that.
LyleB is offline   Reply With Quote
Old 08-31-2016, 11:29 AM   #6
Kai in Seattle's Avatar
Agreed; wouldn't necessarily want to drink water with "woodsy-fresh scent!"
"Lemon-fresh" might be ok, though. 8)
Semper ubi sub ubi.
Old 08-31-2016, 11:32 AM   #7
Trailer: U Hall VT
Smile
Swimming pool chlorine is 5% will kill mold on most everything!
Roger Kimble is offline   Reply With Quote
Old 08-31-2016, 11:54 AM   #8
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Correct on all of the above.
One standard operating procedure to sanitize new water mains is to add enough Chlorine solution(bleach) to the main and flush that slug(typically greater than 50 ppm) to the other end until you smell the chlorine, let it sit for a day flush it with the normal water(typically 1-3 ppm) then do a bacteria test to prove its OK.For comparison 5% bleach is probably 40,000 ppm. The other issue is that the bleach chlorine constantly looses strength the older it gets so you should probably err on the high side when making the dilutions, just have to rinse more.
mmeyer is offline   Reply With Quote
Old 08-31-2016, 05:02 PM   #9
Ive never used scented chlorine for anything but its nice to know that isn't as strong as the regular stuff.
Lee
Captleemo is offline   Reply With Quote
Old 08-31-2016, 08:31 PM   #10
Rich and Rei's Avatar
Trailer: 1970 Trails West Campster and 2012 Lil Snoozy
Kansas
Good to know about Clorox.
Didnt know the scented was not as strong-never thought to look.
Thanks for the info.
Rich and Rei is offline   Reply With Quote
Old 08-31-2016, 08:41 PM   #11
CampyTime's Avatar
You're welcome. I thought it good info to share as I didn't realize it either. I had used the clean linen scent in spring and I never really disinfected the lines. Oops!
Old 09-01-2016, 12:25 AM   #12
I made chlorine as my work career even 2.5% will do the job if left a bit longer.
Old 09-01-2016, 05:38 PM   #13
CampyTime's Avatar
I'm sure that's true in the end, but I read the bottle and got the regular bleach. Call me a robot! Anyway didn't rinse enough first time as antifreeze went clear. Another day.
Suburban VRX-6X WH (Propane). Anodes the same for all? Losthwy Plumbing | Systems and Fixtures 2 05-20-2015 03:47 PM
Breakaway cable; are Bargman's all the same? paulitzlee2 Towing, Hitching, Axles and Running Gear 0 07-08-2010 08:31 PM
Do I add bleach to water tank ? Garret Walther Problem Solving | Owners Helping Owners 2 09-21-2009 02:34 PM
Absolute proof that ALL males are the same Gina D. Jokes, Stories & Tall Tales 9 11-19-2008 09:39 AM
I always use the same login ID for forums ... Karen H. Forum Admin, News & Announcements 2 07-05-2006 10:16 PM
» Virginia Campgrounds
